Re: I just had the MAFS replaced after using K&N ail filters for about 10,000 miles
That's what I have been saying for years, but there is a whole group of people who swear by them. They do breathe well, but they let way too much oil in. Sorry to hear that, but glad you got it fixed.
02 Imola/black M5 "going up for sale"
91 Acura NSX *Sold*
Previously had - Porsche 928 S4, MB CLK 430, C5 Vette
I know that it sounds bad...but, I would rather clean the MAFs than lose the 10 to 15 RWHP
Mark
Super Sprint Headers (coated), X Pipe and mufflers
UUC V12 Power clutch and flywheel
Evo III SSK with DSSR and tranny mounts
Shadowman Velocity stacks and software
Shadowman rear differential with changed static and dynamic lock up, stock ratio
275's on front with a dinan rear bar and Beastpower brackets
Hard wired V1
Dual transponder Lidatek LE-30
Eurodash
Evosport Pulleys
Ground Control coil overs with adjustable camber plates
AA CAI, with AFE filters...the K&Ns ripped open
Relocated IATS
StopTech BBK on front, slotted rotors, with SS brake lines on all four corners
Mark
10-15 RWHP ?? On what planet? And is it 10 or 15? You do realize what a gain of 10 or 15 RWHP equates to?
Slowly drop the crack pipe and back away...
-Jeff
84 911 Carrera (track car)
01 M5 Lemans Blue (for sale)
01 Land Rover Disco II
05 Yamaha FZ6
06 Jeep Grand Cherokee SRT/8
06 M Roadster (on order)
I tried the K&N filters and the stock filters with the AA CAI. I could never FEEL a difference in performance when comparing the two, so I left the stock filters in.
"The richest people in the world build networks. Everyone else is trained to look for work" - Robert Kiyosaki, Rich Dad Poor Dad
Originally Posted by tranck
OK so you gain 10 HP (which is a real stretch, btw) - that will be for about 500 miles before the MAFS get contaminated then you will LOSE horsepower.
So, what is the point?
I've seen 1st hand what they have done and my only reason for this thread is to warn other members.
Not only are they NOT worth it but, you'll lose HP as a result longterm.
Ive had the K&Ns on my car for over 2 years and have never had a problem. I just serviced/cleaned them last month. With no problems. You must be putting to much oil on them.
Boz
-Jeff
IIRC Mark actually did a filter swap on the dyon stand and saw a dramatic increase in whp when he took out fairly new paper filters.
There have been many to use k&n's without problems, many who had problems. I've had my dinan intakes, which use oiled filters (look like k&n's but have a big D on them ) for almost 2 years without issues as well. Must be the special dinan oil filter oil that is mafs friendly.
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
