Brake fluid - BMW M5 Forum and M6 Forums
 1Likes
post #1 of 13 Old 19th April 2017, 04:22 PM Thread Starter
booster_
Brake fluid
I need to replace the clutch slave cylinder and line. As a result I will have to add fluid and bleed the line.
What type of fluid can I use? Can different kinds be mixed? Can I get away with any DOT4 fluid?
I don't want to have to flush the brakes lines until I'm finished because the car is too close to the wall on one side preventing me from getting the wheels off.
How long can a can sit after it's been opened?
booster_ is offline
post #2 of 13 Old 19th April 2017, 07:42 PM
xrviz
xrviz's Avatar
xrviz is offline
post #3 of 13 Old 20th April 2017, 08:09 AM
griffincox
griffincox's Avatar
Any DOT 3 or DOT 4 is fine. Castrol DOT 4 is a good value.
After opened, depending on the environment, I would not use after a few weeks to few months max.
griffincox is offline
post #4 of 13 Old 21st April 2017, 12:28 PM
TheShafro
TheShafro's Avatar
ATE Typ 200.
Replacing the line is pretty tight job. I recommend having another person help.
-Shady H.
@theshafro
'02 TiAg/Blk E39 lllM5 - Pending Build
'08 JZB/FR E92
lllM3 - Daily Driver
TheShafro is online now
post #5 of 13 Old 21st April 2017, 01:51 PM Thread Starter
booster_
Originally Posted by TheShafro View Post
ATE Typ 200.
I'm flying solo. The tranny is out for a clutch, so it may make it easier.
booster_ is offline
post #6 of 13 Old 21st April 2017, 09:24 PM
TheShafro
TheShafro's Avatar
No it won't. I did it with the whole drivetrain removed and it still wasn't easy. You'll see lol
-Shady H.
@theshafro
'08 JZB/FR E92
post #7 of 13 Old 22nd April 2017, 01:30 PM Thread Starter
booster_
Why so negative, lol?
So far the hardest part for me was getting the tranny down. That thing got stuck between exhaust header and the tranny tunnel.
I can't imagine feeding a line through a piece of rubber harder than lying in your back trying to get the tranny down.
booster_ is offline
post #8 of 13 Old 22nd April 2017, 01:49 PM
TheShafro
TheShafro's Avatar
I am not being negative. I'm trying to save you the trouble so you don't start trying to fit it and realize you need another person to help. Maybe you'll get it by yourself, I don't know.
You're replacing the line, correct? It's a hard line from the pedal to the firewall. You need to remove the panel above the pedals, and the dead pedal. Then you have to bend back the carpet and then push the line out. It has a 90° bend and the space is tight, so it's hard to do it if you're inside or outside of the car at once.
But I maybe I'm being negative.
-Shady H.
@theshafro
'08 JZB/FR E92
post #9 of 13 Old 22nd April 2017, 03:12 PM Thread Starter
booster_
I appreciate your advise.
I will give it a go, and if I'm struggling I'll and my wife to help.
I already got everything exposed and ready, I just have to drain the line and disconnect it.
booster_ is offline
post #10 of 13 Old 22nd April 2017, 05:51 PM Thread Starter
booster_
Well, not to be a d1ck, but that was super easy.
I'm not sure if you were just playing with me, but if you were the joke is on me.
I now have to order the second part of the line and the bracket, between the slave and the line I replaced.
I can't get the old one separated.
booster_ is offline
Replaced brake fluid - Not the same feedback on the brake pedal! bikks E60 M5 and E61 M5 Touring Discussion 8 3rd December 2013 07:54 PM
Brake Fluid Flush + Stainless Steel brake lines whatheheck E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 17 16th February 2013 03:48 AM
How much brake fluid does it need potassium E60 M5 and E61 M5 Touring Discussion 6 3rd March 2012 07:57 PM
RE: Brake Fluid!!! DooRow_88 E60 M5 and E61 M5 Touring Discussion 1 10th August 2011 10:45 AM
Brake Fluid Job DIY - Question - Brake Flush & Bleed J Irwan E39 M5 and E52 Z8 Discussion 2 8th June 2007 08:15 PM
