Valve cover gasket kit - BMW M5 Forum and M6 Forums
 3Likes
post #1 of 16 Old 17th April 2017, 05:22 PM Thread Starter
booster_
Both sides are leaking, do I order original BMW parts https://www.ecstuning.com/b-elring-p...11120001269kt/ or the ELRING brand from ESC https://www.ecstuning.com/b-elring-p...11120001269kt/? It's $163.82 vs $88.44..things are starting to add up now, lol. I don't want to have to deal with leaks, but I was planning to do Vanos springs, and possibly chain guides in a year or two.
booster_ is offline
post #2 of 16 Old 17th April 2017, 05:44 PM
jsdsm5
jsdsm5's Avatar
I like the original BMW ones and with a little permaseal RTV in the valleys of the gasket they rarely ever leak. The BMW ones have vitron material in them vs some of the other aftermarket ones do not and so they start to leak in a 1-2 years of operation.
Current Stable
2003 E39 M5
2003 E53 X5 4.6is
1985 E24 635csi Euro
2008 P80 Volvo XC90 R-Design Yamaha V8
M5 MODS
Dinan Suspension
Dinan 3.45 Diff
Dinan Exhaust
Style #65 Rears - four corners
jsdsm5 is offline
post #3 of 16 Old 19th April 2017, 06:11 PM
mech9t8
mech9t8's Avatar
mech9t8 is offline
post #4 of 16 Old 19th April 2017, 06:29 PM
technician117
technician117's Avatar
I use Mahle, who recently bought out Victor Reinz. My previous Victor Reinz valve cover gaskets lasted about 5 years and over 100k miles. When I did them again recently, they weren't really leaking but I needed to have the engine apart that far anyway, so I changed them.
Tim
UUC dssr and shifter
Supersprint headers with Tubi catback
Jailbreak tuning
Dinan 3.45
JED lightened flywheel
258,000 miles and counting...
technician117 is offline
post #5 of 16 Old 19th April 2017, 07:38 PM
xrviz
xrviz's Avatar
My indy where I buy parts tells me all the various gaskets were made from inferior material originally but now all are upgraded and durable , whether BMW labelled or otherwise. Who knows what is really in them though.
xrviz is offline
post #6 of 16 Old 19th April 2017, 10:38 PM
Rontgen
Rontgen's Avatar
I'd recommend OE BMW for the round rubber bolt gaskets. I attempted to go cheap on those and buy VR and they started leaking after about a year. Replaced with OE BMW and still no leaks.
I believe Goetze is the OEM for the BMW valve cover gasket. I bought those from Pelican and they've worked great. I could even see where the rubber "tag" that has the BMW roundel and part number had been manually cut off with a razor.
- Darrell
2001 M5 - Jet Black / Black Nappa
Dynavin N6, Dinan Exhaust, AutoSolutions SSK
Rontgen is online now
post #7 of 16 Old 20th April 2017, 01:39 AM
thekurgan
thekurgan's Avatar
Much of the time, the gasket itself isn't leaking, but the bolt/grommets leak, loose elasticity, etc.
Ilse: 2002 E39M5 / TiAg / Tubi Rumore Stg 2 / E60 shifter / PowerFlex / Intravee II / KCA-420i / Jim Blanton 40% 3.45 diff / NCS coding / StrongStrut STB / Coby Alcantara wheel, shift and e-brake / Rogue Tranny Mounts / Mk IV / RK Plenum Plates
Bruna: 2000 E36/7 Z3 / Schwartz / RE RSM / NCS coding / M3 FCABs
BMWCCA #453648
"We're surrounded. That simplifies our problem of getting to these people and killing them." — Lewis B. "Chesty" Puller
thekurgan is offline
post #8 of 16 Old 21st April 2017, 01:57 PM
Obioban
Obioban's Avatar
Obioban is offline
post #9 of 16 Old 22nd April 2017, 11:03 AM
TheShafro
TheShafro's Avatar
I'll never buy Victor Reinz gaskets again.
I've had both the Elring set and the OE BMW set and they are very, very similar. I think Elring is the OEM, but can't confirm. Anyways, I've used the Elring set more than 5 times, never had an issue.
-Shady H.
@theshafro
'02 TiAg/Blk E39 lllM5 - Pending Build
'08 JZB/FR E92
lllM3 - Daily Driver
TheShafro is offline
post #10 of 16 Old 22nd April 2017, 12:34 PM
Obioban
Obioban's Avatar
Needing it 5 times sounds like an issue to me, unless you've owned the car for 300,000+ miles!
Obioban is offline
DIY: Sheefo2k | Valve cover gasket & Fuel tank breather valve sheefo2k E39 M5 and E52 Z8 Discussion 22 19th July 2014 06:29 AM
Valve Cover Gasket Again? jemmie E39 M5 and E52 Z8 Discussion 7 19th April 2013 11:54 PM
valve cover gasket, codes, and other Q's schnell944 E39 M5 and E52 Z8 Discussion 3 27th September 2010 04:18 AM
Valve Cover Gasket darka///M5 E39 M5 and E52 Z8 Discussion 3 20th June 2008 06:53 PM
Valve Cover Gasket Leak hadas4 E39 M5 and E52 Z8 Discussion 12 11th January 2007 12:23 AM
