Highest Mileage before doing chain guides - BMW M5 Forum and M6 Forums
 2Likes
post #1 of 29 Old 17th April 2017, 03:00 AM Thread Starter
KRAM5
KRAM5's Avatar
Like the title says, I'm curious mileage people have gone without finding plastic in their oil pan, or, everything seems fine with or without checking.
I ask because I just bought one with 140k on it.
Car has no record of new tensioner and makes no noise to indicate it needs replacing.
I have a new lower one in the box and will swap it in anyway.
Car has records of LM 10-60 oil changes every 5k or less over the past 70k miles and is quiet on start-up and makes no rattles or noises that many seem to talk about here.
When I changed the oil after purchase I found the drain plug near stripping.
I bought a lower pan gasket and plan to drop it after I put a couple thousand miles on the fresh oil to see if anything's in the pan while I fix the stripper plug. Hopefully I find nothing, how about the rest of you?
Also if anyone has a link to the correct way of fixing the plug, I appreciate that!
KRAM5 is online now
post #2 of 29 Old 17th April 2017, 04:06 AM
dannyzabolotny
dannyzabolotny's Avatar
The S62 isn't really known for having chain guide issues, that's more of an issue with the M62tu in the 540i/740i/X5. Most S62's can get to 200k+ miles on original guides, they're pretty robust motors overall.
2000 540i Touring - current DD
2000 M5 - sold
dannyzabolotny is offline
post #3 of 29 Old 17th April 2017, 04:43 AM
Ibmotoren
Ibmotoren's Avatar
Originally Posted by dannyzabolotny View Post
The S62 isn't really known for having chain guide issues.
Danny, I thought it's something we're supposed to be vigilant about ? A quick search shows several threads from those who've expierenced this issue. The most recent here
KRAM5,
Here's some links for the drain plug. Unfortunately, as often the case, many of the pics are no longer available.
DIY -Repair stripped oil pan drain plug
DIY Stripped oil pan drain plug repair - Helicoil method
Fixed my stripped oil pan drain plug with Time Sert and I have question about the torque numbers for the drain plug.
Last edited by Ibmotoren; 17th April 2017 at 06:02 PM. Reason: Changed wording (less alarmist)
Ibmotoren is online now
post #4 of 29 Old 17th April 2017, 04:49 AM
stark6935
Imo its overblown. Theres thinking that chain tensioners being broken caused a lot of these issues. If you retroactively replace it and check your oil pan for plastic it seems like you should be ok.
stark6935 is offline
post #5 of 29 Old 17th April 2017, 05:44 PM
tomloans
My 740i m62tu daily driver had broken guides at 112k. I am also curious about my M5. I am pushing 160k miles. Should I be concerned? When looking up the M62tu engine, everyone agrees. But S62 has varying opinions with most leaning towards not to worry about it. Which one is it?
tomloans is offline
post #6 of 29 Old 17th April 2017, 05:48 PM
jsdsm5
jsdsm5's Avatar
Good quality oil and frequency of oil changes seems to give these guides long life. I have personally seen over 200K on these engines with no guide wear/deterioration indications but those engines have received frequent oil changes 5000K or less and a good quality oil. I think your case the maintenance is there and probably little to worry about. just keep of the measure of maintenance.
Current Stable
2003 E39 M5
2003 E53 X5 4.6is
1985 E24 635csi Euro
2008 P80 Volvo XC90 R-Design Yamaha V8
M5 MODS
Dinan Suspension
Dinan 3.45 Diff
Dinan Exhaust
Style #65 Rears - four corners
jsdsm5 is online now
post #7 of 29 Old 17th April 2017, 07:22 PM Thread Starter
KRAM5
KRAM5's Avatar
I appreciate all the replies will be doing a time-cert on the pan when I take it off.
My maintenance is on par with most OCD/enthusiasts and I have a tendency to replace too much at times.
Given the amount of work involved and the fact that most guide failures don't ruin valves/heads, I'll be holding off until I have solid proof of need to replace.
KRAM5 is online now
post #8 of 29 Old 17th April 2017, 07:54 PM
jdauria
jdauria's Avatar
S62 does not run nearly as hot as the M62s. Do an oil anaysis first before opening up the motor. If she isn't making noise, no point in my opinion.
National Capital Chapter #465420
2000 ///M5 ///M Registry
Oxford Green Metallic II (430) | Caramel Nappa Leather (M3CR) | BMW Individual Birch Anthracite Trim |
DINAN Stage 1.5 Suspension
Tuning Tech Tune by Frank Smith (http://www.tuningtechfs.com/)
Supersprint Headers + X-Pipe
Storm Motorwerks Products
2003 X5 4.6iS - | Black Sapphire Metallic | Black Sport Interior | Titan Trim | DINAN Transmission Tune | DINAN Stage 1 Engine Software | E39 M5 Cluster Swap + White LEDs FOR SALE!
2011 X5 35d | Alpine White | Beige | Wood Trim |Sports Package - OEM Style 214 | Cold Weather | Premium | Technology | 3rd row
jdauria is offline
post #9 of 29 Old 17th April 2017, 10:12 PM
dannyzabolotny
The lower running temperature, thicker oil weight, and double timing chain all contribute to a much lower rate of chain guide failure in the S62. You have to remember that the guides are physically different in the S62— they're twice as wide and the forces are more evenly distributed with the two main timing chains, hence the lower guide wear.
I'd say the rod bearings are more of an issue with the S62 than the chain guides due to the higher rev limit and thicker oil, but those are largely based on what the owner does. A well-maintained S62 that's allowed to warm up to temperature properly won't have rod bearing issues, whereas an S62 that's redlined on a cold start will have rod bearing issues very quickly.
2000 M5 - sold
post #10 of 29 Old 17th April 2017, 10:49 PM
gzig5
If you don't want to mess with the time-cert, I have an exchange pan that is repaired with a SS bushing ready to go. Described around post #44 in this thread. Have a few tweaks since then. Let me know if you are interested.
_____________
2000 M5 Carbon Black
Dinan 3.45 Differential
Evolve Tune
Dinan Springs w/ Koni Yellow Sport shocks
Dinan Rear Sway Bar
E60 545 SSK
275 PSS on OEM 9.5" all around
Home-built Muffler Delete
gzig5 is online now
New timing chain and guides. jajo E39 M5 and E52 Z8 Discussion 4 23rd June 2016 12:24 AM
Why you should inspect your chain guides Elekta E34 M5 Discussion 6 22nd November 2014 04:10 PM
timing chain guides Angrydog E39 M5 and E52 Z8 Discussion 9 5th January 2014 10:49 PM
Timing Chain Guides doolie E28 M5 Discussion 0 27th September 2006 05:52 PM
E28M5 Owners Check In - Mileage & Timing Chain/Guides SeattleE28///M5 E28 M5 Discussion 13 13th January 2006 02:09 AM
