Old 18th June 2005, 08:29   #1
Sweetsound2001
Sweetsound2001's Avatar
Garage: 00 Dinan S2
Send a message via AIM to Sweetsound2001
Suspension woes...experts opinion needed.
Greetings all.
I have a 00 MY and my shocks were gone @ 77k. The car felt really unsettled over bumps and had a lot of body roll. Additionally, when I would hit a bump, the whole rear end would move side to side. It almost felt like it would lose control.
I had brand new Koni adjustables installed with the stock springs. I had them set at 1/4 turn from full soft. Now the car rides really stiff and the rear end is still doing that side to side motion. It also feels very bouncy when I hit speed bumps, etc.
Is there something else going on in my suspension that could be causing this problem? Sometimes I also experience a vibration between 50-65mph when driving. Are the Konis supposed to be so much stiffer than the stock shocks even on the almost softest setting? How can I make my suspension feel much tighter and composed...any thoughts are greatly appreciated.
Anton
Sweetsound2001 is offline
Old 18th June 2005, 08:54   #2
basil
basil's Avatar
Garage: Anthracite
Re: Suspension woes...experts opinion needed.
Poor alignment can cause the rear to feel 'loose' when changing lanes, etc. Is that what you’re referring to?
Also, your rear swaybar may have pulled from one of its mounts adding to a softer, more bouncy feel.
Vibration? It could be several things.
Find yourself a local tire and brake shop that handles the local race crowd if you can and have them put their most qualified to the task of a full checkup with test drive.
basil is offline
Old 18th June 2005, 13:48   #3
quickenough
quickenough's Avatar
Garage: M5 Silverstone
Originally Posted by Sweetsound2001
Greetings all.
Anton
The vibration between 50-65 is it there all the time or just when braking?
quickenough is offline
Old 18th June 2005, 14:28   #4
DavidS
DavidS's Avatar
Garage: 2000 M5 LeMans blue
Sales Feedback: (4)
1. Check the sway-bar brackets and links both front and rear. Look for broken brackets, cracks and play.
2. At 77 k miles, the rubber bushings (at least rear) are very likely ready for replacment.
Put the car on a lift. Have a really strong and heavy guy push and pull at each wheel in turn with full force, while a skilled mechanic checks for play in the rubber bushings. There should be zero play, just smooth damping.
David
DavidS is offline
Old 18th June 2005, 15:52   #5
Osodog
Osodog's Avatar
Garage: M5
I had the exact same symptom of body roll and it turned out to be a broken rear sway bar bracket. Once it was fixed, it was like night and day. I also had my front bushings replaced (at 32K) and a control arm as well.
Visit my web site to help raise funds for LLS:
http://pages.teamintraining.org/sf/Yosemit109/jmilne
Osodog is offline
Old 18th June 2005, 20:30   #6
Sweetsound2001
Garage: 00 Dinan S2
Thanks guys.
Actually, one of my sway bar brackets was replaced about 6 months ago. I checked them again last night and they're both good. The weird thing is that even with brand new Konis in the rear, when I go over a bump, rear end feels loose. On large bumps, not only does it go up and down like it should, but it feels like the whole rear of the car moves sideways.
I used to have a vibration in the steering, and had my front control arm bushings replaced, which cured most of it. Are there similar bushings in the rear that may be worn out and causing this problem?
Old 18th June 2005, 20:33   #7
Sweetsound2001
Garage: 00 Dinan S2
It seems like there is some slight vibration under hard braking.
Old 19th June 2005, 16:35   #8
DavidS
DavidS's Avatar
Sales Feedback: (4)
As the shock-absorbers (dampers) gave up, everything else in the suspension has been working hard too.
Apart from the rubber bushings, it could also be a loose or missing bolt among the rear-subframe or diff bolts.
Although unusual, it could even be a broken sub-frame. Look for cracks at the mounting points.
Does the car feel symmetrical between left and right hard turns?
David
http://www.m5board.com/vbulletin/showthread.php?t=54788
http://www.m5board.com/vbulletin/showthread.php?t=88323
DavidS is offline
Old 19th June 2005, 16:50   #9
Lscman
Garage: E39
The Koni shocks are not the problem, unless the mechanic doing the work accidently set them to 1/4 turn from full stiff. They are great when set under 1 turn from full soft...or lower. Your rear Konis don't create such overdampening symptoms, even when installed on 525i cars that weigh 500 lb less. That said, the Koni's will NOT offer you a wallowing, underdampened ride quality like you felt with your blown out 77K mi shocks. If you became accustomed to that ride quality, you will only get that in a Lincoln Town Car or shocks with no hydraulic fluid in them.
I would advise you to have a professional mechanic test-ride and examine your car for problems. There is no way to diagnose this problem peering thru a PC on the web. An experienced E39 driver with Koni's could test drive and advise you whether the mechanic erroneously set them near full firm.
If the rear end of the car is side-stepping on the street as if something is defective, you have a serious suspension problem. My car did not even do that on-track hitting bumps at 120 MPH with Koni's foolishly set over 50% stiff.
Lscman is offline
Question for suspension experts, I'd like to know your opinion please...... FAST 5 E39 M5 and E52 Z8 Discussion 19 1st January 2005 00:11
BMW M6 Press Release no 4: The Chassis and Suspension of the BMW M6:Agile, Fast, Safe Gustav E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 0 15th December 2004 01:21
M5 "floating" at high speed / suspension topic SandBeast E39 M5 and E52 Z8 Discussion 11 11th August 2004 03:12
Press Release 4: The suspension of the M5: Ensuring a high degree of agility Gustav E60 M5 and E61 M5 Touring Discussion 0 4th July 2004 22:03
Press Release 4: The suspension of the M5: Ensuring a high degree of agility Gustav Most Memorable Threads' 0 4th July 2004 22:03
Page generated in 0.15744 seconds with 11 queries
