Catastrophic Engine Failure??? - BMW M5 Forum and M6 Forums
 45Likes
post #1 of 48 Old 27th March 2017, 09:25 PM Thread Starter
M5NSX
Well last week I'm driving to the gym (2002 E39 M5 with 84,000 miles)and suddenly I get the message "STOP OIL PRESSURE". I immediately get off the road and turn off the car and have it towed to my mechanic. Oil level was okay when I stopped. There was some whitish stuff on the top and bottom of dipstick. The car has been getting louder than it's normal Vanos knock lately but running like a scalded ape!! Mechanic just informs me that there is metal(aluminum) and bearing material in the oil. He said the car probably lost oil pressure and suffered a catastrophic failure. Of course that made my ******* day!! Just put a bunch of money into rotors, brakes, wheel bearing, CSB for the driveshaft.... any words of encourage or am I fucked?? Feel like I just lost a family member������
M5NSX is offline
post #2 of 48 Old 27th March 2017, 09:44 PM
///M3Augy
///M3Augy's Avatar
First I would open up the oil filter and even drop the oil pan to see how much/what the shavings look like and go from there. I am local to you and could help out possibly...
///M3Augy is offline
post #3 of 48 Old 27th March 2017, 10:00 PM Thread Starter
M5NSX
M5NSX is offline
post #4 of 48 Old 28th March 2017, 02:12 AM
gsfent
gsfent's Avatar
Find out what is going on before you get too bummed out. For example, if rod bearings and no damage to the crank, then you have about a $1500-$2000 repair bill. Not cheap, but not the end of the world.
If the motor is really toast, then if it were me, I would look for a good used motor and sell the old motor as spare parts to Clemster.
Keep posting, lot of experience here to help you out, no matter what it turns out to be.
Dinan Stage 3 suspension, SS jet coated headers, ESS SC kit w/ 1 range colder NGK's, 92mm pulley, 440 Big Greens, TTFS alpha N tune for meth, RK plenum plates, Sachs high performance PP and CCC proprietary clutch disc, stock DMFW, open brake ducts, Hamann front splitters, TEC cupholder, U.S.(Euro style) tilt/slide armrest, 6k HID fogs, 6k super white low beams, V1/Stealth1, dual head LI, 2.65 diff w/40% lockup/2x dynamic, compact spare, Euro trailer hitch, Mocal oil cooler, ACS type rear spoiler, Rogue custom SSK and tranny mounts, ST 355 BBK (fronts), BP sway bar brackets, Bluetooth retrofit, Speedhut boost gauge, Dinan TB's and VS, KB BAP, Howerton/HFS-3 Aquamist WI trunk setup.......
gsfent is online now
post #5 of 48 Old 28th March 2017, 03:17 AM
ME_264
FWIW, I was burning a quart every 250 miles when it got worse... I had the Clemster install a used motor into my M5 (my wife made me let him do it...) and it's running better than ever!
ME_264 is offline
post #6 of 48 Old 28th March 2017, 04:50 AM
KevinM
KevinM's Avatar
Originally Posted by M5NSX View Post
Well last week I'm driving to the gym (2002 E39 M5 with 84,000 miles)and suddenly I get the message "STOP OIL PRESSURE". I immediately get off the road and turn off the car and have it towed to my mechanic. Oil level was okay when I stopped by some whitish stuff on the top and bottom of dipstick. The car has been getting louder than it's normal Vanos knock lately but running like a scalded ape!! Mechanic just informs me that there is metal(aluminum) and bearing material in the oil. He said the car probably lost oil pressure and suffered a catastrophic failure. Of course that made my ******* day!! Just put a bunch of money into rotors, brakes, wheel bearing, CSB for the driveshaft.... any words of encourage or am I fucked?? Feel like I just lost a family member😞😞😞
Sorry to hear...seems like you have owned this car since 2002, so I definitely understand how you feel. Agree with Jerry - best to wait to find out the whole story. I would be freaking out as well. Keep us posted.
Kevin
2016 F80 M3, Mineral Grey/Golden Brown/6MT - ED delivery 6/3/2016 http://f80.bimmerpost.com/forums/sho....php?t=1291837
2007 Z4M Coupe Silver Gray/Black
Too many kids' cars...
KevinM is offline
post #7 of 48 Old 28th March 2017, 03:35 PM
///M3Augy
///M3Augy's Avatar
M3Augy,
We are probably going to do that. Where are you located?
Dan
I am in Clarkston, work in Warren.
post #8 of 48 Old 28th March 2017, 08:20 PM
Sailor24
Sailor24's Avatar
Absolutely correct. No sense in getting excited until you know.
3 or 4 years ago I had a car towed to me that presented near identical symptoms. Found metal in the pan but looked further and what appeared to have happened was the oil pump tensioner failed and the chain climbed the gear which bent the shaft and destroyed the pump. The failed tensioner makes then noisy. We found lots of aluminum and bushing/bearing material. Logic was if the pump failed ,and all the material was from it, that would have prevented any material going into the engine. We looked no further the owner was prepared to just throw a pump on it and see. That seemed to do the trick, because last I heard it was still a DD.
Besides there seem to be quite a few engines available for these cars now as a lot have had wrecks in recent years. Certainly not the death of the car but heart surgery is still expense.
Sailor24 is offline
post #9 of 48 Old 28th March 2017, 10:20 PM Thread Starter
M5NSX
Thanks!! I hope that is what happened to my car. It was getting pretty noisy could actually hear the ticking and rattling inside the car and until about 2500rpm. The car was running strong. We will see. Unfortunately my mechanic is basically a one man show and is backed up 15 cars. This could take a while.....
M5NSX is offline
post #10 of 48 Old 29th March 2017, 06:04 AM
herrubermensch
m5board.com Site Sponsors
herrubermensch's Avatar
Or better yet, spend a little more and get a newly rebuilt S62 that costs substantially less than a new motor from BMW and is substantially better. Then instead of a mystery engine, you have something you can rely upon for 150-200k miles.
--Peter
Managing Member of
Partee Racing, LLC , The S62 Shop, LLC, and The S54 Shop, LLC
herrubermensch is offline
So This Happened This Morning: Catastrophic (N54) Engine Failure, In Dramatic Fashion ucsbwsr E60 M5 and E61 M5 Touring Discussion 22 24th March 2016 08:16 PM
Catastrophic engine failure - seeking advice Thomp E60 M5 and E61 M5 Touring Discussion 24 14th September 2015 01:57 AM
E39 For Sale: My Dinan Beast - Top Dollar Mods but w/ Catastrophic Engine Failure rockd Cars For Sale or Wanted 38 26th January 2011 04:56 PM
Catastrophic transmission failure M5Doctor E60 M5 and E61 M5 Touring Discussion 10 26th August 2010 10:31 PM
