Old 11th June 2005, 19:56   #1
///M_Addict
///M_Addict's Avatar
Garage: BMW M5
'00-'02 M5 Sirius Install Tips
Introduction: This document is intended to fill in some missing pieces in the process of retro-fitting Sirius satellite radio to 2000 and possibly later M5s. The process is simpler for 2003 M5s. I must give credit to all the great sources of information that did all the real hard work. I am just trying to fill in some small gaps. Those sources include (Forgive and contact me if miss someone!):
Martin Bishop of www.bimmernav.com
Ard
El Mono
Gustav
Mottati
mdernst
References:
www.bimmernav.com
www.m5board.com
Navigation Forum of bimmerboard
BMW Install Instructions:
Sirius Receiver Installation Kit
New Generation Radio Retrofit Kit
Sirius Magnet – Mount Low Profile Antenna Kit
Parts(list from bimmernav):
Mark IV Navigation Computer with firmware Version 3.0 or higher
BMW Trunk Mount Radio: 65-12-6-927-910. There may be other radios that work. I am certain that this one will work.
Sirius Satellite Radio: 84-11-0-153-365
Old to New style radio wiring harness: 61-12-6-913-957
Old to New style radio antenna harness: 61-12-6-913-955
Old to New style audio input adapter: 61-12-6-924-785
Six Wire CD Changer cable (6 ft): 61-12-0-140-716
Sirius to CD Changer adapter cable: 84-11-0-141-978
Additional Parts:
Install kit: 84-11-0-141-975
Antenna (BMW): 84-11-0-392-099 (There are other options that might work as well such as the TERK SIR3 with TERK SIR-SP and the Nissan SIGMA)
Overview: The combination of Gustav’s post of Ard's write-up and the bimmernav web site provide most of what you need to do this retro-fit. What is missing for pre-2003 M5s is some details on how to wire-up/connect the new radio as well as the Sirius radio and CD changer. Here is the big picture. You will replace your trunk mounted radio with a new radio that is Sirius “aware” and is capable of switching inputs between the Sirius radio and the CD Changer. In order to connect the new radio to car’s built in wiring harness you will need to use the adapter harnesses listed above. You will then change how your CD Changer connects to the car. You will go from using a direct digital connection to your DSP to an analog connection daisy-chained through the Sirius radio up to the radio. This means that the Sirius radio and CD changer will share the same connection to the AM/FM radio. A thought before you start is that you might want to do this install twice. Once to just get the pieces connected and working and a second time to do it pretty and taped/secured.
Open Issues:
1) It appears that older CD Changers might not work with this retro-fit. Mine did not. I had everything hooked and working but when I selected the CD Changer, the sound was low and “scratchy”. I checked with some of the experts and they had experienced the same behavior. The recommendation was to replace the CD Changer with one that would have come from a 2004 X5. I found this BMW Changer P/N: 82-11-0-028-760. The sound was much better! However issue two is still there but very minor.
2) From posts on the M5 Board, several owners (even those with ’03 M5s) have reported that the CD Changer continues to play after the mode switches to another input. My new Changer also has this behavior. Given how awesome Sirius is, it is a small price to pay. If some one knows the P/N of an OEM changer that does not have this problem, please share it with us. Another option is to install an MP3 in place of the CD Changer. Many have done this and not reported any problems. Board member BrainS has reported that radio part # 65-12-6-964-398 fixes this problem.
Details:
I recommend removing all existing equipment from where it currently mounted. The link provides some good instructions. Be sure to disconnect you battery before disconnecting any wiring.
http://www.bimmernav.com/5MKIV.htm
With all the equipment out of the car, now might be a good time to run the antenna cable. You have some choices here. The two major choices are to install it on the roof, in which case you should drill a hole in the trunk to run the wire from the outside to the trunk(see the second link below for a pdf on how to do this). Or, if you choose to install above/below the parcel shelf you can either fish it from below up along the C-Pillar or drill a hole from below.
There has been a lot discussion about where to place the antenna on the M5 board. Check these links out:
Sirius Antennas
For those who have SIRIUS radio, Where's the optimum spot for ther antenna ?
Time now to begin re-assembly. Find the built-in radio harness this is where you connect one end of the adapter harness to connect the new style radio. Here is a picture of it. You now need to build the adapter harness.
Here are the steps:
1) Complete the Six Wire CD changer cable. You will use this cable to connect the Sirius radio to the AM/FM radio. It comes partially assembled as shown below
You will need to plug in the loose wires in the following locations on the small black block(The holes are numbered if you look closely):
Pin Cable Function
2 White-Brown Audio common from 6CD player
8 White-Red Audio Left Channel from 6CD player
9 White-Blue Audio Right Channel from 6CD player
Next snap the black block into the larger white block. See item A) in picture below.
2) Connect the audio input adapter to the radio wiring adapter. The audio input adapter is “double-headed”. This can be confusing as you will only use on of the two cables. You will use on the cables that have the black plastic connector. The other cable with the white connector will not be used. You can tape it off with electrical tape as you complete the assembly. Here is the audio input adapter:
Plug the end with the black plastic connector in to the “new” end of the radio wiring harness (the end with slots). You want to put it into the slot on the side opposite the radio wires. The other end with a metal case plugs into the block connector on the existing harness. Where this gets tricky is that there are two ways to orient the connection. If you get it right, you will be able to hear the navigation voice and tape player. If you get it wrong, you won’t (so flip it over!). You should also check out the diagram in the Installation Kit for new generation radio pdf for a hint.
3) Plug in the Six Wire CD changer cable into the other slot.
4) Connect the adapter harness to the built-in harness. If you are SURE of your connections you can tape it all together. You might want to test the whole setup and then go back to pretty things up.
5) Connect the Aerial adapter harness to the built-in harness.
6) Replace DSP and brackets.
7) Install new radio using adapter harnesses and secure with brackets.
8) Install Sirius brackets if you have the install kit and mount the Sirius radio.
9) Connect the Six Wire CD Input cable from the AM/FM radio to Sirius radio.
10) Connect the 3 wire power cable that had been connected to CD Changer to Sirius radio.
11) Connect the Sirius adapter cable to slot in the Sirius radio.
12) Plug the Six wire connector to the analog port on the CD Changer and the 3 wire connector into the power port on the CD Changer.
13) Mount CD Changer.
14) Connect Sirius Antenna following directions included with antenna.
15) Check everything. You completed setup should look something like the picture below.
16) Re-connect battery
17) Pull the car out to location that has a clear view of the sky.
18) Turn-on car and set new radio to USA mode. If your radio is not set to USA mode, you will not see a Sirius Mode on your NAV display. Here are instructions from Martin Bishop:
“Turn the radio on and immediately push and hold the SEL button for 5-10 seconds until the radio serial number is shown. Using the <> key scroll until you find the area mode- it may be in Europe or Noarea. Use the number keys to select USA, maybe #1 or 2.”
19) Select Sirius mode on display and see if you hear anything…
20) If so, Success!! Get your Sirius S/N and call up to activate. I recommend telling them that you have a BMW OEM receiver that you need to activate it. With luck you might be able to get a free year’s service, I did. I have heard some people where not so lucky. You might want to hang up and
try another service rep.
Whew! That's it! Sirius Rocks! Thanks to all who made this possible!
Good Luck!
Dave
2008 M5 Gray/Black
2000 M5 Silver/Black (sold)
///M_Addict is offline
Old 12th June 2005, 02:09   #2
mdernst
mdernst's Avatar
Garage: 2003 M5 Jet Black
Re: '00-'02 M5 Sirius Install Tips
Nice write up Dave.
One item of note. I have hardware version 1.0.1 of the Mark IV (DVD) navigation and Sirius works fine. Here's a picture of the sticker on my NAV unit:
Me loves me Sirius! :^)
Mike E.
2003 M5 Jet Black
mdernst is offline
Old 12th June 2005, 17:28   #3
///M_Addict
Garage: BMW M5
Mike,
Thanks for the feedback! So you must have a newer version or close varient of the Mark IV. Very good to know!
Thanks!
Dave
Old 2nd May 2009, 05:29   #4
Hdhntr23
Hdhntr23's Avatar
Garage: 2002 Titanium Silver E39
Sales Feedback: (13)
Send a message via MSN to Hdhntr23 Send a message via Yahoo to Hdhntr23
Thread digging here... Most of these part numbers seem invalid, do you guys know how I can find the replacement part #'s? Thanks!
One can be spelled as NEO.
There is no spoon.
OEM E39 M5 exhaust cans for sale <--- Click the link!
Current Interior Mods:
MKIV, Sirius Retrofit, BlueTooth Retro-Fit, E60 SSK, ACS Aluminum Pedals, 30% Window Tint, TEC CupHolder, 2X's Ultimate Cup Holders, Full LED upgrade (Thanks Timmay77), "M" Stitched Alcantara Shiftboot and E-Brake boot, CF Steering wheel trim (Thanks CGRM5), Euro-Dash (Thanks Raz and Timmay77), Hella TC-400 TPMS, Scosche BlueTooth 2.0 A2DP Adapter (Thanks btmlinedan)
Current Exterior Mods:
"Always-On" DRL Predator ICE LED 6000K AE's (Thanks Timmay77 and NavCoder), C-Fiber Kidney Grills, ACS C-Fiber Roof Spoiler, ACS Flipper style C-Fiber Front Splitters, C-Fiber OEM Trunk Spoiler, C-Fiber Eye-Lids (Thanks CGRM5), Custom "vented" C-Fiber Rear Diffuser (Thanks Timmay77, ATLANTAM5 and Diny), Euro Headlights, (Thanks CGRM5), C-Fiber 6 piece window sills, 7 Piece C-Fiber Blue/Grey Roundels,
Current Performance Mods:
Dinan Exhaust cans (Thanks Timmay77 and btmlinedan), Brake duct mod with "Black Chrome" custom rings (Thanks Timmay77 and Diny), Dinan RSB with BeastPower brackets (Thanks Firehire, MFreakin5 and btmlinedan)
Planned Exterior Mods:
Stainless vented custom Fog-Light frames (Awaiting Install), Hamann style sideskirts w/ CFiber Inserts (Awaiting Delivery/Install) PIPEDREAM.... Vorstiener vented CF double sided hood
Planned Interior Mods:
Backlit Door Sills, Hardwire V-1, Stealth One, Replace instrument cluster (Pixels dropping out), Add a dedicated amp for the "M" Subs, Euro-Style Armrest
Planned Performance Mods:
Dinan Front Tower Brace, Headers (Looking for input)
Hdhntr23 is offline
Old 5th May 2009, 02:54   #5
El_Mono
El_Mono's Avatar
Garage: M5 - Carbon Black
If you called Crevier, or Circle .. or your favorite "online" BMW parts distributer, I'm sure they can give you the up to date and latest part numbers. Additionally bimmernav.com is still up, while I didn't recurse the website, I'm sure the info is still there as well.
2003 Carbon Black / Silverstone - M5 (duh)
All the fixin's
Bluetooth - SE w810
Miltek Exhaust
Aux Input - Not sure why I installed this, Sirius RULES.
Sirius - The only way to go ...
El_Mono is offline
Old 15th January 2010, 19:07   #6
DaveKraft
Garage: 2001 M5 Anthracite
Any updates or new suggestions I have a 2001 M5 with Nav Thanks a million Dave Kraft dkraft1950@prodigy.net
DaveKraft is offline
Old 15th January 2010, 19:22   #7
RichardP
RichardP's Avatar
Garage: E39 M5, Carbon Black
Intravee and SIRALP-1 tuner is an alternative. Fully integrated, but not quite as much functionality as the OEM system. You don't need the new radio module or Nav computer.
RichardP is offline
Rumours about the E39 M5 pre 1998. Gustav F10 M5 Discussion 15 21st October 2009 01:11
M5 E39 Body Style S62 engine FACTS...Long V-10 4 Me E39 M5 and E52 Z8 Discussion 53 22nd March 2009 16:12
M5 vs. 996tt orangemarlin E39 M5 and E52 Z8 Discussion 21 28th July 2006 01:36
Potential M5 newbie asks a lot of questions. Verschuur E34 M5 Discussion 3 22nd August 2002 12:12
Page generated in 0.18720 seconds with 11 queries
