7th June 2005, 16:40
#1
BMW M5 Le Mans Blue
H&N filter vs cold air vs ram air
I've just intalled the H&N air filters. I don't know if it just my mind but it seems a little more torqey and I hear a more whiney sound. That being said, what are the performance differences, if any, between the three options?
Seems that the cold air intakes pictures I've seen still take in air the same way as stock but ram air is a more direct and voluminous intake? Besides the different look, what is the difference between the H&N filter and cold air filter results? Don't want to toss away $$ for noth'n!
Le Mans Blue with blue panels
Brake ducting
Stoptech big brake kit (black)
Slotted front/rear Aero Rotors
stainless steel front and rear brake lines
Dinan CAI w/stage 2 software
Dinan Stage III suspension w/JRZ
Dinan Front Strut Brace
275 fronts/rears
Nitto NT01 Track tire
Beast Power Rear Sway Bar Brackets
Powerflex Poly Bushings
Hawk HT-10 (for track, Axis Ultimates (street)
Eisenmann race exhaust 80mm
TEC cupholder
Euro arm rest
Autosolutions 25% short shift kit
Valentine One radar detector
AJ-USA Alluminum pedal set
Shroth harnesses (track)
<embed src="http://videos.streetfire.net/vidiac.swf" FlashVars="video=2bc84021-a84b-4ea5-9ac6-61c725f72e93" quality="high" bgcolor="#ffffff" width="428" height="352" name="ePlayer" align="middle" allowScriptAccess="sameDomain" type="application/x-shockwave-flash" pluginspage="http://www.macromedia.com/go/getflashplayer"></embed>
Jaguar E-Type V12 1973
7th June 2005, 17:00
#2
2000 M5, Ti-Silver
Re: H&N filter vs cold air vs ram air
Would that be K&N?
I jsut did the AA cold air intake together with the IATS relocate kit and there is definitely a difference in performance!
Well worth the cost and I get brake cooling as a bonus.
7th June 2005, 17:34
#3
BMW M5 Le Mans Blue
Yes, I meant K&N. Since I've already opened up the front ducting by drilling holes and installing flex tube, I'm looking only at the air benefit of the K&N vs the cold air and ram. I know the kit you installed and I still might do it if the ram effect is better than the K&N effect. The brake cooling evens out.I've read a few interesting posts on the negative effects (supposed) of the K&Ns.
7th June 2005, 17:39
#4
I hate to burst your bubble but, I'd take those K&N's out.
The oil residue from them will foul the MAF'S.
They did mine - I just ordered new MAF'S today as a result.
7th June 2005, 18:00
#5
2000 M5, Ti-Silver
The kit also come with the K&N filters so your benefit would be the ram air effect.
I did have the K&N filters foul up my MAF.(they were replaced under warranty)
So right now, I'm running the AA CAI with the stock air filters.....Still works well though.
7th June 2005, 18:03
#6
2001 Titanium Silver
Before I got my M5 I owned a '95 540i sport. I was going to switch to the K&N filter to try and up my performance. Here's a web site that I found that made me change my mind. Hope it helps.
http://www.bmwe34.net/e34main/upgrade/Air_filter.htm
That's my opinion, although I might not agree with it.
2001 M5, Titanium Silver, Black, Stock. (sold  )
2005 Audi S4 Cabriolet, Moros Blue, Light Grey Interior
2003 X5 3.0, Grey Green Metalic
1994 B757-200
2001 B757-300
1999 B767-200ER
2002 B767-400ER
7th June 2005, 18:18
#7
I would agree. Even though I have the AA CAI with K&N filters, I wouldn't use them again due to this problem occuring to more than just a few people. I clean my MAF's every 6 months, but I'm probably going to get rid of them and just use the stock filters from now on.
Steve
'02 M5 LeMans Blue:
Supersprint Headers and cats
BeastPower sway bar brackets
Dinan front strut tower brace
RMS short shifter
Llumar window tint (35%)
7th June 2005, 18:26
#8
BMW M5 Le Mans Blue
So is the reply to all this by K&N not the truth? Boy, it's really hard to figure out what the real deal is on this issue. I'm thinking as a compromise to put in the K&N for my track days and use the stock when street driving. I would think that where one lives and drives might exacerbate the problem ie dusty Texas, Nevada etc. I live in CT where it is not dusty.
7th June 2005, 18:37
#9
Rob, I seem to recall an article that stated that the stock paper filters flow as well as any after market filter. Maybe it was Dinan who checked this on a dyno. .. perhaps some other board member can help.
As for fouling your MAFS, well there are too many members here who have had that experience and that would be enough for me to stay away from the K&N's..
And then re the Ram Air effect.. just my opinion, but I figure for the AA system to really work, you would have to driving a little faster than the 55mph limit we are allowed to drive before you got any benefit...
I would install it only for the eye candy appeal and any hp boost that resulted would be cream for me ..
Andre
E 39: CB / Black - most tasteful options (fondly missed)
E 60: IB/Black - Everything except vented seats and split rears (gone)
997 C2S with X51 power kit: Black on black, most tasteful options I think
Life is not measured by the number of breaths we take.. but by the moments that take our breath away.
7th June 2005, 18:48
#10
M5 Jet Black
Not a really good example...but...doesn't Dinan use K&Ns with blue dye on all of their CAIs?
Mark
Super Sprint Headers (coated), X Pipe and mufflers
UUC V12 Power clutch and flywheel
Evo III SSK with DSSR and tranny mounts
Shadowman Velocity stacks and software
Shadowman (Quaife) rear differential with changed static and dynamic lock up, stock (3:15) ratio
275's on front with a dinan rear bar and Beastpower brackets
Hard wired V1
Dual transponder Lidatek LE-30
Eurodash
Evosport Pulleys
Ground Control coil overs with adjustable camber plates
AA CAI, with AFE filters...the K&Ns ripped open
Relocated IATS
StopTech BBK on front, slotted rotors, with SS brake lines on all four corners
Jet Black 2002 M5
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
