S62 "Rebuild" - BMW M5 Forum and M6 Forums
 19Likes
post #1 of 17 Old 1st February 2017, 05:04 PM Thread Starter
J.Almonte
J.Almonte's Avatar
S62 "Rebuild"
Decided to do a separate thread from my "Revival of an Imola".
2017 Update!!
So what happen was....
Since I bought the car I noticed oil smoke from the exhaust when coming to a complete stop on deceleration downshifting.
This situation had me concerned and the more I looked on the forums, it looked like it was a kind of common issue.
The was no oil on the plenum but nonetheless I replaced the oil separators and all the hoses. Problem was still present.
This was not affecting performance whatsoever and was more of an embarrassing issue.
At the end of 2016 I started making plans to install a ESS supercharger but before doing this decided to tackle the smoke situation and decided to refresh my S62.
Note: Before opening up the engine I did compression and leak down test to discard piston rings as the culprit of the oil situation.
All the results (5% leak) where very good and close to each other.
This left me with the assumption that my valve stem seals were the problem.
Here is the plan:
1- Tear down the S62.
2- Send the heads to the machine shop
3- Put it back together
4- Pray...
5- Drive
Parts to be used:
1- Head gasket set 11121407805
2- Bottom end gasket set 11111407804
3- Rod bearings
4- Rod bolts
5- Vanos seal kit (Includes Beisan o-rings, solenoids o-rings, etc...)
6- Chains
7- Chain tensioner
8- Chain guides
9- Crank dampener bolts
10- Water pump, thermostat, etc...
11- Head gasket
12- Cylinder head bolts
13- Bunch of overpriced BMW o-rings...
Will also be doing a Heat Exchanger delete.
This "while in there" motto, did some serious damage to my Supercharger funds...
Worth to mention that I will be doing all the work myself with my buddy Mike that owns Euro Spec Automotive in Tampa, FL.
Any advice is welcome!!
Some of the parts.
On to the pictures!
This is it so far.
The heads will be ready for pick up next Friday.
Questions:
1- Should I replace the piston rings? If I do... do I need to do anything special to the block bores?
2- Can I remove the pistons to clean them and reinstall? (I will make sure they go back in the same spot)
J.Almonte is online now
post #2 of 17 Old 1st February 2017, 07:43 PM
Thumper600
Thumper600's Avatar
I am laughing out loud, thanks for sharing your unique camshaft holding in place tools. And here I thought using a couple of old valves was unique. As for the rings, I'd check with an Indy about what grit stone to use in a honer because I'm under the impression you need to do something in order to get the rings to seat just not sure how abrasive the "something" needs to be. Enjoy your project and keep us posted
Thumper600 is offline
post #3 of 17 Old 2nd February 2017, 04:08 AM
kashill
kashill's Avatar
kashill is offline
post #4 of 17 Old 2nd February 2017, 04:30 AM
herrubermensch
m5board.com Site Sponsors
herrubermensch's Avatar
Originally Posted by kashill View Post
Yes, replace the rings and hone the block.
And re-expose the silicone to the requisite rPk and RA values. Good luck.
--Peter
Managing Member of
Partee Racing, LLC , The S62 Shop, LLC, and The S54 Shop, LLC
herrubermensch is offline
post #5 of 17 Old 2nd February 2017, 08:50 AM
Comfort
Comfort's Avatar
Cool tread, nice pictures. I`m might bee doing this myselves one day.
I used electrolythe cleaner to clean the pistons last time I changed piston rings (Cosworth YB engine in 1999).
I`s also mandatory to either only hone the cylinders or bore (if cylinder is oval) them before instaling new rings.
Why do you do the heat exchanger delete? Are you installing external oil cooler??
Comfort is offline
post #6 of 17 Old 2nd February 2017, 11:01 AM
Sailor24
Sailor24's Avatar
I like your idea, but if you want to rebuilt, send it to a rebuilder like peter or Mr. super human like his handle says. The results will be different,
Sailor24 is offline
post #7 of 17 Old 2nd February 2017, 10:30 PM
herrubermensch
LOL. I know, that handle was picked when I was a tad younger and had a little less humility. Thanks for the reference, Sailor!
--Peter
Managing Member of
post #8 of 17 Old 4th February 2017, 02:23 PM
Sailor24
Sailor24's Avatar
From what I understand from some sources you maybe living up to your handle at the new shop.
Sailor24 is offline
post #9 of 17 Old 4th February 2017, 04:58 PM
herrubermensch
That is great to hear! We are striving to be decidedly different from other engine shops. Candor and an obsessive interest in the outcome of our work help us do better.
--Peter
Managing Member of
post #10 of 17 Old 5th February 2017, 09:48 PM
zaid
zaid's Avatar
impressive. i wouldn't dare doing such a job . i will take the engine out and take it to a shop to do it. good luck and hopefully we will see a video for the car running soon
zaid is offline
Broken "Lower Right Engine Compartment Cover" and "Stabilizer Support" wrecks E39 M5 and E52 Z8 Discussion 10 10th November 2014 03:22 PM
Red Cogs, Yellow Cogs... "Transm. malfuntion" & "Engine malfunction" AutoVation E60 M5 and E61 M5 Touring Discussion 20 16th January 2013 06:01 AM
"Engine Malfunction: reduced power!" & "Increased Emissions" OTDoc E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 16 2nd November 2008 12:15 AM
"Engine Malfunction; Reduced power!" & "Increased Emissions" OTDoc E60 M5 and E61 M5 Touring Discussion 16 9th August 2008 03:25 AM
S62 is a "HEMI-like" engine? billrM5 E39 M5 and E52 Z8 Discussion 35 26th March 2007 11:44 PM
