Old 31st May 2005, 18:27   #1
DavidS
DavidS's Avatar
Garage: 2000 M5 LeMans blue
Sales Feedback: (4)
How to test the MAFs yourself and How MAFs work
The MAFs are vital to the proper function of the S62 engine. The engine can never work better than its MAFs.
The MAFs (Mass AirFlow meters) are located in the M5 and Z8 air intake tubes. The MAFs report to the Engine Electronics (DME aka ECU) the amount of air that is drawn into the engine, and what temperature this air is. The DME uses this to calculate how much fuel to inject.
Vital as the MAFs are, those have to be _really_ bad before you actually get a stored fault-code.
The functional test by the BMW tester just tests the MAFs at idle with the car standing still. IMH experience that says absolutely nothing about how they perform at WOT (Wide Open Throttle).
I think there is an economical (warranty) reason why BMW does not want the MAF fault code to trigger as soon as the MAFs start to be less-than-perfect, rather than only when there is extremely poor MAF function.
MAFs typically last 50000 miles before getting so contaminated it affects S62 engine performance.
There are two methods to test the MAFs yourself:
Method A - using the instrument cluster of the car *********
Read post #11 in:
Gadget Freaks II: Fun you never knew you could have [secret menu]
Follow those instructions, and select the mode for fuel consumption per hour.
With the engine fully warmed up, drive several WOT (wide open throttle) accelerations. Notice the fuel flow per hour numbers. If everything is ok the numbers should increase continously to about 140 litres per hour at WOT at 7000 RPM. (donīt worry about bouncing into the rev-limiter)
The fuel-flow is directly proportional to the MAF reading reported to the Engine Electronics, so if the Fuel-flow is correct, the MAFs are most likely correct too.
To be able to compare your fuel-flow readings with other peopleīs readings,
you need to correct the data for temperature, barometric pressure and altitude. This is easy: look at the table attached at the bottom of this sheet.
Look up the two factors matching your temperature, barometric pressure and altitude. Then multiply the reading from the instrument cluster with both those factors. The result will match what the fuel flow number would have been at sea-level, +20 deg C and normal barometric pressure.
Method B - using an OBD-II scan-tool *******************
1. Get a graphing and data-logging OBD-II scantool. If you already have a laptop PC, it will cost you about US$ 100 to buy one. Worth every cent. (I use the one called "ISO" from www.obd-2.com which I am very pleased with)
2. Plug it into the car and go for a drive
3. Look at the graph for CLV (calculated load value). This is basically the MAF signal expressed in percent of the expected maximum at each RPM.
When you accelerate WOT this number should immediately go to 100% and stay there until you release the throttle or hit the rev-limiter .
4. If the CLV reading it is low at all RPMs, try new air filters.
5. If it is ok at low RPMs, but lower at higher RPMs, try the MAF cleaning procedure and the retest immediately. If this improves the numbers you know 100% there is (or if the cleaning was very successful used to be) a MAF problem. This does not say it is the only problem, but the car can never run better than its MAFs.
Symptoms of bad MAFs ************************
In degree of malfunction of the MAFs possible symptoms are:
High Lambda values at idle (lean air-fuel-mixture)
Engine hesitation at high RPM
Engine misfire at high RPM
Engine going into limp-home mode at high RPM
MAF cleaning procedure ************************
http://www.louv.tv/cars/m5/MAF/
(by m5board member Louv)
How the MAFs work ***************************
The MAFs have a non-heated temperature sensor and heated temperature sensor. The latter is made of a very thin wire of platinum metal. The wire is heated to about 200 deg C, and its temperature is continously monitored and the heating current is controlled so as to keep the wire at this temperature. The more air that passes the wire on its way into the engine, the more the wire will be cooled. The electrical current needed to maintain the sensor wire at 200 deg C, is directly proportional to the amount of air that passes it, and also depends on the temperature of the air (hence the non-heated temperature sensor).
The electrical current and the air temperature are measured, and the corresponding air-flow is calculated and reported to the engine electronics.
How MAFs clean themseves ***********
Once in a while the MAFs will run a very high electrical current for a few seconds through the platinum sensor wire, so the wire gets red-hot (1000 deg C). This burns off much of the contaminants, and probably help keep the MAFs working much longer between manual cleaning or replacment intervals.
How MAFs fail *********************
With time the MAF platinum-wire gets fouled with contaminants settling from the rapidly passing intake-air. These contaminants acts as thermal insulation on the wire. The effect is that the wire will not be cooled as much as it should by the air-flow, and thus reports too low air-flow to the engine electronics. The engine electronics in turn uses this too low air-flow number when calculating how much fuel to inject. The fuel injection will be to low, and the air-fuel mixture in the cylinders of the engine will be lean.
Many M5 owners have reported K&N oiled intake air filters to cause MAF contamination.
What to do if the L/H fuel flow numbers are low?
1. Have you corrected for altitude/barometric pressure/temperature and humidity?
2. Numbers still low? Most of the time, with a L/H reading very low, either the fuel pump/fuel pressure regulator and/or the MAFs are shot.
Most likely the MAFs.
To check the MAFs for severe contamination:
CHECKING MAFS
Either run the BMW DIS / GT-1 tester procedure for MAF testing at idle and inreceased idle RPM, or use this (IMHO far more accurate and reliable) procedure to measure MAF output voltages with engine off:
(Better still use both methods: road test L/H, and direct voltage. Then compare the results.)
MAF TESTING - DIRECT VOLTAGE METHOD
0. Remove tie-wraps holding wire protection tubing in place at the MAF connectors. Pull tube back and find the applicable wires. Connect to these using insulation piercing needle-and-hook type test leads(or just plain needle type test leads if you donīt mind risking to prick yourself).
Make ceratin to have the mulitmeter set to DC volts and that you have not connected to the AMPs connectors on it. (The signals you are connecting to go straight to the DME so be careful not to short-circit anything.)
1. Ignition on
2. Engine not running
3. On each MAF measure DC voltage between
pin 3 (ground, brown wire) and pin 5 (signal, yellow wire)
4. Reading should be 1.000 +- 0.040 V. The closer to 1.000 V the better. the dirtier the MAF the higher the voltage will be.
5. If reading in step 4 is off by more than 0.020 V then measure voltage between pin 3 and pin 4 (+5V reference from DME, yellow/green wire). This reading should be 5.000 +- 0.200 V.
6. If not check the battery voltage, and connect a charger if needed and redo the tests.
7. Put the tubing back in place and secure it with new black 2.5 mm wide tie-wraps. (Make sure you have narrow enough tie-wraps to fit on hand before cutting the old ones.) To avoid sharp edges, after the tie-wraps are in place cut the excess with a flush (one side only beveled) pair of cutting pliers.
If you donīt have that kind of cutters, just cut the tie-wraps with any sharp cutter and the file the sharp corners. Only takes a minute, and might save some of your blood next time you do something in that area on the engine compartment.
The reading in step 4 should be exactly 1/5 of the reading in step 5.
If this procedure gives a reading in step 4 that is outside tolerance the MAF is definitely contaminated or otherwise damaged.
FUEL PRESSURE
The other plausible possibility is the fuel pressure.
To measure the fuel pressure is very easy: he will need a BMW adapter for fuel pressure sensing (BMW special tool 13 5 220. This is a kit containing 13 5 221 and 13 5 222. This is common for all E39 5-series, so the dealer probably has it already) that connects to th efuel pressure regulator, and to the pressure test sensor on the DIS.
The procedure is very easy and is described in detail in TIS 13 31 029.
The thing to be aware of is that BMW states the fuel pressure as the difference between the absolute pressures in the fuel rail and in the intake tract (downstream of the throttle butterflies).
At idle the intake ports will be at -0.5 BAR. Just measure the atmosphere-relative pressure of the fuel-rail, and then add 0.5 BAR to get the reading relative to the intake ports.
In other words: hook the fuel test port up to the DIS, read the (athmosphere relative) pressure the normal way, and if it is 4.50 +- 0.05 BAR everything is fine so far.
Then disconnect the vacuum hose from the fuel pressure regulator, plug the hose, leave the fuel-regulator vacuum port open, start the engine again, and measure the fuel-rail pressure once more. It should now be 5.00 +- 0.05 BAR.
(The difference between these two readings is due to the vacuum pressure in the intake tract.)
BTW, this would be a good time to measure the vacuum too while you are at it as you have access to the hose anyway.
Warranty *************************
As the MAFs influence the air-fuel mixture and cause high Lambda values (lean mixture), it is possible to fail emissions testing due to non-perfect MAF sensors. When the vehicle fails emissions testing the Emissions Components Warranty may be applicable.
In the us see:
http://www.epa.gov/obd/warranties.htm
The mandatory warranty covers everthing relating to emissions for the first two years, and the OBD, ECU (DME in BMW language) and the Catalytic converters for eight years.
So in the US the MAFs are covered for at least 2 years by law, but not for eight years.
David
UPDATE NOTE 2006-Oct-24:
I have updated the Excel-file, so calculations are now automatic. Just enter your numbers. Much more conveinient to use.
UPDATE NOTE 2006-OCT-25:
I have fixed a bug affecting calculations in metric units in the Excel file. Current version is 3. Please, do not use ver 2.
File Type: xls Correction_for_peak_fuel_flow_data_ver_3.xls (48.0 KB, 1254 views)
Last edited by DavidS; 26th October 2006 at 04:01. Reason: Added link to EPA. Added MAF self-cleaning description. Corrected link to www.obd-2.com
DavidS is offline
The Following 9 Users Say Thank You to DavidS For This Useful Post:
-BEASTMW- (11th April 2009), Busta (4th February 2009), Fiori (21st July 2008), havasusteve03Beast (3rd February 2009), iconoclast (17th June 2008), IMVIP (12th March 2009), Neil Mukerji (14th September 2008), RichardP (19th November 2008), Terabass (27th April 2008)
Old 31st May 2005, 23:01   #2
IceGBG
IceGBG's Avatar
Garage: M5, Carbon black
Re: How to test the MAFs yourself and How MAFs work
Fantastic coverage.
Explanation was very much needed.
Thanx.
IceGBG is offline
Old 31st May 2005, 23:40   #3
XrayMD
XrayMD's Avatar
Garage: LeMans Blue M5,Silver X5 & Dk. Silver Mini S
Great post! Good job. Thanks!
Steve
'02 M5 LeMans Blue:
Supersprint Headers and cats
Dinan Stage III suspension
BeastPower sway bar brackets
Dinan front strut tower brace
RMS short shifter
Llumar window tint (35%)
XrayMD is offline
Old 1st June 2005, 00:06   #4
bmwusa
bmwusa's Avatar
Garage: Waiting?????
Nice write up, thanks for consolidating the info, Josh
1/2 of the Southern Renegades....
I just love the smell of JP-5 in the morning
bmwusa is offline
Old 1st June 2005, 00:07   #5
Ocean's M5
Ocean's M5's Avatar
Garage: 2002 M5
That was really great! And I appreciate the effort. However, if one does suspect the Mafs going bad wouldn't it be easy to just replace them instead of cleaning them?
I know they are expensive like $380 ea. but why wouldn't BMW just clean them if they are still under warranty. It would be cheaper for BMW. Can the Mafs or any part of them wear out and need to be replaced?
I heard of a few people trying to clean them and their M5 still didn't run correctly until they were replaced. Then Waa-Laa runs fine...
I am asking as a layman.
2002-05 Build Carbon Black ///M5
First Aid Kit ~ Warning Triangle ~ Full BMW Tool Kit
Rear Cupholders ~ Stubby Air Stems ~ Rear Shades ~ PDC
M Audio ~ Fold-Down Rears ~ Black Sport Int.~ Yokohama Advan Sport~
Beast Power Sway Brackets ~ Tinting-80% Strip Windshield
Center Armrest *Storage Bin ~ ///M Black Trunk Mat
Ocean's M5 is offline
Old 1st June 2005, 00:32   #6
DavidS
DavidS's Avatar
Sales Feedback: (4)
Thanks, everybody!
The BMW TIS (workshop manual) very specifically forbids any kind of disassembly or cleaning of the MAFs. The reason for this, I assume, is that Bosch cannot guarantee the function of the MAFs if handled. Since the MAFs are critical to good emissions levels, there might be regulatory matters involved too.
On the other hand the BMW test procedure for MAFs is a joke. You can have pretty much MAF-contamination induced high-RPM power loss, and still not get a MAF fault code, and pass the BMW idle-speed MAF test.
David
http://www.m5board.com/vbulletin/showthread.php?t=54788
http://www.m5board.com/vbulletin/showthread.php?t=88323
DavidS is offline
Old 1st June 2005, 00:43   #7
DavidS
DavidS's Avatar
Sales Feedback: (4)
I think there might be financial considerations involved. The MAFs surely donīt cost BMW hundereds of dollars each.
Over the lifetime of the vehicle, if BMW can sell a pair of MAFs every 50000 miles it adds up nicely.
Similar to why you canīt buy a set of syncronization rings (syncros) for the gear-box. You have to buy a new gear-box instead...
David
DavidS is offline
Old 1st June 2005, 01:26   #8
Kin Mak
Kin Mak's Avatar
Garage: BMW E46 M3
Sales Feedback: (3)
Send a message via MSN to Kin Mak
Originally Posted by DavidS
1. Get a graphing and data-logging OBD-II scantool. If you already have a laptop PC, it will cost you about US$ 100 to buy one. Worth every cent. (I use the one called "ISO" from www.odb-2.com which I am very pleased with)
David
I think the link is http://www.obd-2.com/ is anyone is wondering...
- Kin
BMW E46 M3 SMG Carbon Black/Cinnamon
BMW E39 M5 Avus Blue - SOLD
KinMak.com - Loads of Photos - Elara Online
Kin Mak is offline
Old 1st June 2005, 01:41   #9
DavidS
DavidS's Avatar
Sales Feedback: (4)
- Kin
Oops.. You are absolutely right! Big Thanks for pointing it out.
I have corrected the link in the first post.
David
DavidS is offline
Old 1st June 2005, 02:51   #10
DejaVu
DejaVu's Avatar
Garage: M5 Imola Red
Good post, thx DavidS
Dean
BMW M5 1999 Imola-red/Imola-interior
Kelleners K.sport Speed-Modul (release of top speed restriction - Top Speed 296 kph)
Kelleners Sport Pedals
Kelleners Rear Deck Emblem
Active Autowerke Front Grille
AutoTecknic "M" Grille Emblem
AutoTecknic Carbon Fiber Roof Spoiler
Bimmian Xenesis Tru-Match Bulbs (Fog-lights)
Plasma Ultra White Race Sport Bulbs (High-Beam)
Momo Seat Belt Pads (Tuning Black/Red)
Evovector BMW M Engine Oil Cap
/// DéjāVu //
DejaVu is offline
Page generated in 0.50327 seconds with 11 queries
