How to test the MAFs yourself and How MAFs work - Page 10 - BMW M5 Forum and M6 Forums
Like Tree2Likes
Old 29th August 2005, 16:27   #91
grp
grp's Avatar
Garage: M5 Black ('99)
Re: Scan tools
Nope, not the navigation - the procedure refers to the two buttons inside the instrument binnacle...
Gary.
Originally Posted by E39 MFIVE
I have a MKII navigation..
WHen refering to the " right " " left" button.
are they refering to the Volume and Nav button??
Because I tried the procedure in the Link.. But I
can't seem to get it to work..
Gary
M5 Carbon Black / Black '99
XC90 2.5T AWD '04
grp is offline   Reply With Quote
Old 29th August 2005, 16:46   #92
E39 MFIVE
E39 MFIVE's Avatar
Garage: E39 M5, T78FD3S
Re: Scan tools
Ahhh Hhaaaaa..
Thanks..
Gonna be changing the oil, and I shall report with the Data points..
Gary.
E39 MFIVE is offline   Reply With Quote
Old 29th August 2005, 18:40   #93
bmwusa
bmwusa's Avatar
Garage: Porsche Turbo
Re: How to test the MAFs yourself and How MAFs work
I have had some major drivability problems with my car and SES lights, it has been at the dealership since last wednesday and they called this morning and said they believe the MAFS are bad, when the MAFS arrive and they install, if it corrects the problem I will post all of my symptoms so that we can have another data point or at the very least another example of symptoms and corrective action, Josh
1/2 of the Southern Renegades....
I just love the smell of JP-5 in the morning
bmwusa is offline   Reply With Quote
Old 29th August 2005, 18:49   #94
ard
Super Moderator
ard's Avatar
2003; 35k miles
2nd and 3rd gear pulls
75F, approx 25% RH
128, 135 in 2nd
136, 140 in 3rd
Old 29th August 2005, 19:00   #95
gsfent
gsfent's Avatar
Garage: 01 M5 Black/caramel
Sales Feedback: (3)
Originally Posted by ard
2003; 35k miles
75F, approx 25% RH
128, 135 in 2nd
136, 140 in 3rd
Hmm, where can you get redline pulls in 3rd?
Old 29th August 2005, 20:26   #96
E39 MFIVE
E39 MFIVE's Avatar
GOT a ISSSUEEEEEEE....
SPORT: OFF
DSC : ON
OBC Temp: 92F
2nd Gear pulls: 138/140ish L/P
3rd Gear Pulls : ONLY up to 84 L/P...
Has me very very concered.. WHY are my l/h in 3rd gear to REDLINE
only 84...? and its FINE in 2nd...
DOES SPORT BUTTON EFFECT the Litr/h
thanks
Old 29th August 2005, 20:58   #97
E39 MFIVE
E39 MFIVE's Avatar
Re: Scan tools
Re-read the first page..
and I think DavidS states at Idle you are supposed to get 1.xxx L/H.
WELL.. I get 0 L/H at Idle with no load, no ac. = good/bad??
and im only getting 80 something L/H at WOT in 3rd gear to 7K rpms?
Maf or Fuel problem???
Old 29th August 2005, 21:03   #98
gsfent
gsfent's Avatar
Sales Feedback: (3)
SPORT: OFF
DSC : ON
OBC Temp: 92F
thanks
Readings don't make sense. They should be similar at WOT at or about redline. If anything, they should be slightly higher in a higher gear.
There is no L/P, only L/100km and L/Hour. Not sure where you can get redline 3rd gear pulls, but if not at or about redline, numbers would be off. 2nd gear numbers look great. Any drivability issues?
Sport button only affects the gas pedal position relative to the butterflies (and makes the steering less boosted). The sport button opens the butterflies quicker with any throttle opening, or for a given throttle opening, the throttle butterflies open more. At WOT, all is the same.
Old 29th August 2005, 21:21   #99
centom5
Garage: Carbon
This one was very timely. I just had my car in at the dealer for other work and they found that these needed to be replaced or parts of them anyway. My car has 52k and this was covered under Massachusetts emmissions law. Which was good.
centom5 is offline   Reply With Quote
Old 29th August 2005, 21:27   #100
E39 MFIVE
E39 MFIVE's Avatar
Pardon me.. all the " L/P " suppose to be " L/H"
Litre per hour.. I m kinda flustered, on why im getting this
wierd readings..
WOT @7K in 2nd Gear.. IM getting good readings 137-140 l/h.
WOT in 3rd, highest reading im getting are in the 80's l/h
and the same on all 4 runs..
Plus you are " supposed" to get 1.XXX l/h at idle with no load.
Well IM geting " 0 "
should I be worried?
while i was unlocking the OBC.. my Nav got all screwed up also.
So had to power it down/disconnect the battery.. Thank god
it came back to life again...
