Old 24th May 2005, 16:04   #1
Andrey///M5
Andrey///M5's Avatar
Garage: M5 E34 3.8 arctis silber
Brakes issue - need your advice
Hello to everybody reading
I have M5 e39 with the stock brakes and never have been satisfyed by these brakes.
As i found out, AP Racing brake kit is the cheapest option i can find here, and i almost have no chance to find Brembos at the same time/place.
Does anybody have ze experience with AP Racing brakes? Can anyone compare these brakes with Brembo?
And also i would like to know whether the solution exists for suspension upgrade in order to let E39 to be driven as good as E34
We have actually some special conditions here in terms of auto business, and this is why i am asking for your good advice, not many M5s are driven here and not much experience to exchange.
Thank you in advance,
Andrey
M5 E39 (young wife)
M5 E34 (lovely wife)
Andrey///M5 is offline
Old 24th May 2005, 19:06   #2
jordantii
jordantii's Avatar
Garage: !988 M3 Hennarot
Re: Brakes issue - need your advice
AP may be better than Brembo. They are at least in the same league. Make sure they have dust boots on the pistons to keep dirt out.
Jordan
jordantii is offline
Old 24th May 2005, 19:58   #3
DavidS
DavidS's Avatar
Garage: 2000 M5 LeMans blue
Sales Feedback: (4)
Andrey,
I am no brake expert, but if think the AP breakes are very good.
Check out Zeckhausen Racing among the board sponsors.
BTW are you sure the stock brakes are ok? Maybe there is a need to
bleed the DSC unit. See:
Soft Brake Pedal - Bleeding tricks?
David
DavidS is offline
Old 24th May 2005, 20:25   #4
bmwusa
bmwusa's Avatar
Garage: Waiting?????
Just curious, how much are the AP brakes compared to Brembo? Josh
1/2 of the Southern Renegades....
I just love the smell of JP-5 in the morning
bmwusa is offline
Old 24th May 2005, 22:20   #5
foxyboym5
foxyboym5's Avatar
Garage: BMW E30 M3 1987 & 996 TT 2002
Send a message via MSN to foxyboym5
Dont rule out stoptech - theyre excellent too, and can fit 355mm discs under stock front wheels and are great value for money
do a search on the board - you'll be here all night!!
cheers
2002 BLACK 996 TURBO
TRACK TOY/PROJECT 1987 E30 M3 Black. Roll cage, Leda/Koni adjustables, Koni springs, camber plates, sparco seats & full race harnesses, Splitsec MAF kit, EVO2 engine, Schrick Cams, 245bhp.
PREVIOUS CARS:
1989 BMW M5 E34
2000 BMW M5 E39
1998 BMW 323Ci
1990 BMW 325i
1981 BMW 635CSi
1995 BMW M3
1995 BMW 328i
1990 BMW 525i
1988 BMW 316
foxyboym5 is offline
Old 25th May 2005, 12:43   #6
Andrey///M5
Thanks to all of you, guyz!
I have read through some threads you noticed - and have to clarify something:
i have firm enough brake pedal, but i am not at all satisfied with braking intensivity (braking acceleration? not sure about the right term) when i have to brake from 180 km/h and higher speed - it brakes very slowly (in my personal opinion), while lower speeds are quite acceptable for braking generally. Thus i would suggest that i don't need bleeding out the brake system, but have to upgrade the brakes somehow.
I use original brake padz only - does not anybody think that this problem may be solved by simple replacing of the brake pads?
As for AP Racing brakes - well, i yesterday misunderstood local AP dealer and as it is appeared, there is the price of usd3200 for front brakes only, what actually makes them quite expensive for all wheelz...
Good luck
Old 25th May 2005, 12:55   #7
foxyboym5
foxyboym5's Avatar
Good luck
Most of the braking is done on the front as the weight shifts there when decelerating, so 4 wheel system is not really necessary. One of the selling points of the stoptech is that it is well balanced when using stock rears.
Brake pads will make a difference i believe, but more to heat issues than actual ******ation.
I'll leave the tech stuff to Dave Zeckhausen!!
Do a search for Dave's posts and you'll learn loads about brakes etc.
cheers
PREVIOUS CARS:
1989 BMW M5 E34
2000 BMW M5 E39
1998 BMW 323Ci
1990 BMW 325i
1981 BMW 635CSi
1995 BMW M3
1995 BMW 328i
1990 BMW 525i
1988 BMW 316
Old 25th May 2005, 13:11   #8
DavidS
DavidS's Avatar
Sales Feedback: (4)
Andrey,
Have you driven another E39 M5 to compare yours with?
Have a look at your rear rotors. Are those a little less shiny than the front ones? More black spots?
If you drive at 20 MPH and rapidly step as hard as you can on the brake pedal, the car should get into ABS regulation on both front and rear wheels immediately and stop extremely fast.
If you drive at 20 MPH in reverse and step as hard as you can on the brake pedal, the car should act the same.
If the braking when going in reverse is weaker than when going forward there may be a problem with the rear brakes, or with the brake force distribution regulator.
David
http://www.m5board.com/vbulletin/showthread.php?t=54788
http://www.m5board.com/vbulletin/showthread.php?t=88323
DavidS is offline
Old 25th May 2005, 16:46   #9
Andrey///M5
DavidS,
Thank you for your advise, will try to check brake distribution the way you discribed
And will let you know, or will apply directly to Dave Z.,
Thank you anyway,
Good luck
Old 25th May 2005, 17:47   #10
NAT
NAT's Avatar
Garage: E39 M5 LE MANS BLUE
I have to say that i find exactly the same deficiency with my brakes as well , and i am considering an upgrade but dont know what to get and i definetely want to keep the standard wheels.
At speeds below 80 MPH the brakes are very adequate , however the other day i had to stop from 130 MPH and i have to say i didnt think i was going to stop...........there was no feel , no bite and i can only describe the feeling being the same as the feeling you get when your brakes have overheated ( and mine hadnt ). All my components have been checked recently and everything is in good working order. I do think its just the way they are ...............anyone care to differ/comment ?
DavidS,
Thank you anyway,
Good luck
NAT is offline
Bad brakes? ponloeu E39 5 series Forum 1 26th November 2003 23:25
M5 brakes / clutch are bollocks! slider E39 M5 and E52 Z8 Discussion 4 7th October 2002 23:46
Stop tech big brakes for sale! (Cheap) Rave E55 For Sale or Wanted 2 12th May 2002 04:08
19" wheels on the M5: Why? kgk E39 M5 and E52 Z8 Discussion 44 23rd August 2001 09:27
Hamann brakes = Movit brakes? tfung E39 M5 and E52 Z8 Discussion 3 29th April 2000 22:23
Page generated in 0.17043 seconds with 11 queries
