• Latest threads
    • Custom feed
      • News
        • Updates
          Old 21st May 2005, 05:10   #1 (permalink)
          jkarp
          jkarp's Avatar
          metallic rattle from right passengers side front
          I've seen a couple of posts on this issue, but nothing definitive. When driving slow (10-20mph) over somewhat bumpy roads I hear a metallic sounding rattle coming from the right hand side front. I took the wheel off but found nothing unusual. I've heard others talk about bushings possibly. The car feels fine.
          Any thoughts or tips on what to look for?
          thanks... josh
          jkarp is offline
          Old 21st May 2005, 11:20   #2 (permalink)
          DavidS
          DavidS's Avatar
          Re: metallic rattle from right passengers side front
          Knock on the passenger side side-pillar where the height adjustment for the seat belt is. It might be that mechanism that rattles.
          David
          DavidS is offline
          Old 21st May 2005, 18:44   #3 (permalink)
          mottati
          mottati's Avatar
          i'm thinking that you're referring to the suspension area, not the door pillar, right?
          I, and a few other board members have had some things "loosen up", specifically the lower control arms and thrust arms. A once over with a torque wrench seemed to cure the problem.
          I'm not sure about anything more specific, i had complained to my dealer (under cpo warranty) and they took care of it. Nothing was replaced howeve, just tightened.
          Engine:
          Suspension:
          Interior/Misc:
          mottati is offline
          Old 21st May 2005, 23:34   #4 (permalink)
          Ashok Arora
          Ashok Arora's Avatar
          It could be the fire extinguisher clip hanging loose!
          Ashok
          2002 E39 Carbonblack/Caramel M5 (past)
          2005 E60 Blue Onyx/Caramel/Light Figured Ash M5 (past)
          2007 E90 Montego Blue/Black Alpina D3 (present)
          Beware the Red Cog of Death!
          Ashok Arora is offline
          Old 22nd May 2005, 00:26   #5 (permalink)
          hudson
          hudson's Avatar
          Josh,
          Try checking the front sway bar links. It's a common problem and they rattle when loose like the sound your describing.
          Joe
          hudson is offline
          Old 23rd May 2005, 05:15   #6 (permalink)
          warhaven
          warhaven's Avatar
          Actually, the problem tends to be road debris. Look for pebble sized debris in the front right wheel brake shielding. You'll have to pull the tire of course.
          Warhaven's 2002 Dinan S2 M5
          11/22/04 Dyno: 336.2RHP/329.2T (Exhaust only)
          03/15/05 Dyno: 334.38HP/326.24T (+CAI)
          06/22/06 Dyno: 348.76HP/331.33T (+ MAF)
          Jet Black/Black
          Super Sprint X-pipe
          AA Front Grill
          TC Racing Pedals
          TCD Sway bar brackets
          MK4 V28.1 NAV upgrade
          Zenon 8000K Stage II upgrade
          warhaven is offline
          Forum Jump
          Nowack Tuning Report, The Truth (Long Version) CharlesW E39 M5 and E52 Z8 Discussion 60 28th June 2006 21:46
          Audi RS6 presented, 440 HP! Gustav E39 M5 and E52 Z8 Discussion 52 11th March 2002 01:51
          Once again BMW saves lives TigerM5 E39 M5 and E52 Z8 Discussion 27 6th March 2002 03:22
          Missing front side airbags? wundercar E39 M5 and E52 Z8 Discussion 3 9th November 2001 17:32
          Good crashmovies of E39 5 series front and side Gustav E39 M5 and E52 Z8 Discussion 2 14th September 2001 14:32
          Page generated in 0.19115 seconds with 11 queries
