m5board.com Advertisers are: Download GTBoard.com Supercar Shootout 1 + 2 in HD 1920x1080 503 Motoring (OR) Angel iBright ASR Engineering Bavarian Soundwerks Bimmer Performance Store BMS BMW service CA Automotive CNS Racing Dinan Cars EisenmannNA ESS Tuning Eurosport Design Evosport GTboard.com < "Supercar Shooutout II: 40+ car in action incl. BMW M3 E92" Hartge (Member discount) HRE Wheels Kreissieg Medford Tools (OR) Meist GT modbargains.com Neez Powerchip Group Race Precision Revozport TireRack BMW M5 Upgrade Garage for wheels, tyres and suspension Tubi Style North America Turner Motorsport Umnitza UUC Motorwerks Zeckhausen Racing BLACK LIST OF NON-APPROPRIATE VENDORS Be an m5board.com Advertiser!
Old 20th May 2005, 16:37   #1 (permalink)
david enock
Burning Oil
Hi everyone,
'00 with 75k+ miles and oil consumption is now 1 us qt (5w30) at just under 1k miles.
Normal? Unusual? Anything I should/can be doing about it?
Would appreciate feedback. I haven't posted in a long time but I do check in a lot.
Thanks,
David E.
david enock is offline
Old 20th May 2005, 16:43   #2 (permalink)
jlindy
jlindy's Avatar
Re: Burning Oil
I have never understood why some cars burn 1 quart of oil every 1500 miles while others go though it every 10,000 miles and it is considered normal for the M5.
I know the 2000's go through a lot more oil, but shouldn't the 2001+ last longer than 1500 miles?
02 Imola/black M5 "going up for sale"
91 Acura NSX *Sold*
Previously had - Porsche 928 S4, MB CLK 430, C5 Vette
jlindy is offline
Old 20th May 2005, 16:43   #3 (permalink)
kcdoyle
kcdoyle's Avatar
View my '01 M5 Imola Red
Re: Burning Oil
Originally Posted by david enock
Hi everyone,
Thanks,
David E.
Morning David-
Just visited with my BMW SA and he said they only worry about oil consumption when it exceeds 1 liter/litre every 800 miles. For what it's worth. I am moving to the 60 weight now that it is summer here. Last thing I want is 5 weight getting REALLY thin in the Tulsa heat! KCD
Jimmy broke the curse, I was there.
kcdoyle is offline
Old 20th May 2005, 16:49   #4 (permalink)
david enock
Re: Burning Oil
Originally Posted by kcdoyle
Morning David-
Hi KCD,
Any ideas as to what can be done at the worry level?
D.
Old 20th May 2005, 16:53   #5 (permalink)
tranck
tranck's Avatar
Re: Burning Oil
Definitely switch to the 10-60 oil.
tranck is offline
Old 20th May 2005, 17:26   #6 (permalink)
kcdoyle
kcdoyle's Avatar
Re: Burning Oil
Hi KCD,
D.
Dave-
Sorry it took so long. I knew I had just read something on this but couldn't remember the post! (turning 40 next week, memory going!) You might check it out.
Thank God for Extended Warranty (Again)
kcdoyle is offline
Old 20th May 2005, 17:30   #7 (permalink)
ard
ard's Avatar
Re: Burning Oil
Hi everyone,
Thanks,
David E.
Uh, why are you using 5W30???? What does your owners manual call for?!
AFAIK, Castrol TWS 10W60 is the only oil BMW specs for your car.
My guess is carbon build up in the rings and lands increasing your oil use- the ring design of the 00 already was suceptable to high consumption. THere is a product you might try for cleaning (AutoRX) but many here will disagree (I think).
In any event, you must use the oil your car's manufacturer requires, at a minimum.
A
PS I like that BMW doesn't "worry" about consumption until it gets to a liter per 1000km.... I'd be worried way before then- BMW doesn't "fix" it until it gets that bad, but I'd be "worried"
ard is offline
Old 20th May 2005, 18:20   #8 (permalink)
david enock
Re: Burning Oil
A
ARD,
The oil spec on my car is 5W30. It's a June '02 build and I have had this issue come up several times. Even had to point it out to the service manager at Country Imports where I have had my car serviced for the last five years. Sticker on the radiator says 5W30.
D.
Old 20th May 2005, 18:24   #9 (permalink)
ard
ard's Avatar
Re: Burning Oil
Your post said " '00 with 75k+ miles"... was this a typo or did you put an 02 engine into an 00?
I cut my oil use in half with a cleaning... my car had th 5-30. I will be switching with the next oil change.
ard is offline
Old 20th May 2005, 18:24   #10 (permalink)
david enock
Re: Burning Oil
Dave-
KCD,
Thanks for the heads up. I am going to pass the post on to my service advisor.
D.
Old 20th May 2005, 18:54   #11 (permalink)
Arxtech
Arxtech's Avatar
Re: Burning Oil
I had the same issue twice; one turned out to be the gasket that needed to be replaced; and the second time, it turned out to be a faulty solenoid in VANOS system, which caused oil to leak out.
Symptom timeline: stable oil use, then a gradual increase in oil burned. Topping off a half quart every 1000 miles; then progressed to half quart per 700 miles. The entire process was about 6+ months long.
I took the car in when it ran loud and rough one morning and I knew the VANOS was acting up.
I recommend taking in to the dealer to check it out.
Arxtech is offline
Old 20th May 2005, 18:57   #12 (permalink)
DC187
DC187's Avatar
Re: Burning Oil
I have an '01 and use 5w30. I burn 1 quart at least every 2-3 weeks (I really do push my engine). The great thing about this car is that it barks at you the second something is off. I always check my level, but I can’t tell you how many times I get interrupted by my cars chime asking me to check the oil level. Every time I hear this I don’t even need to check, I just add the whole quart. Also always remember to check your tire pressure ever 2 weeks….especially if you push it-
DC187 is offline
Old 20th May 2005, 19:17   #13 (permalink)
DavidS
DavidS's Avatar
View my 2000 M5 LeMans blue
Sales Feedback: (4)
Re: Burning Oil
Hi everyone,
Thanks,
David E.
Why do you run 5w30 in a MY 2000? I thought all MY 2000 should have 10W60?
Has the oil consumption increased with time?
David
