Think my fuel pump died... Pointers? - BMW M5 Forum and M6 Forums
 2Likes
post #1 of 12 Old 23rd December 2016, 02:18 AM Thread Starter
travish325
Car was running fantastic then I shut it off and came back an hour later and it won't start. It will try but sputter and barely run then die. Now it is to the point where it just cranks and tries to sputter. I jumped out the fuel pump relay or so I think I did (it's the bigger relay on the passenger side in the trunk right?) Anyway the pump did not turn on when jumped and I had good 12vdc going in. However, I couldn't feel the relay clicking when I had my friend turn the key over so that is leading me to believe something else is wrong, maybe my hand just isn't sensitive enough... Anyway, is there anything else I can check to be sure it's the pump?
travish325 is offline
post #2 of 12 Old 23rd December 2016, 02:48 AM
bcampbe7
bcampbe7's Avatar
Suddenly stranded? Testing your fuel tank levels, fuel pump relay, and fuel pump in 10 minutes with a piece of copper wire
2000 M5 - Evolve Alpha-N tune; DGR coil overs; Updated headlights with angel eyes; 16:9 screen with MKIII; Custom K&N CAI; OEM First aide kit; Storm Motorwerks radio knobs, e-brake handle and shift knob; Slimmbones Euro sliding/tilting armrest; Slimmbones XL Fog light covers; Slimmbones rear finned diffuser; AC Schnitzer front splitters; Rear Style 65 on all 4 corners; Daily driver
bcampbe7 is offline
post #3 of 12 Old 23rd December 2016, 02:51 AM Thread Starter
travish325
That's the procedure I followed, but I never could feel the relay click when turning the key. I'm just worried I'm going to purchase a new pump and find our it was the wiring or relay
post #4 of 12 Old 23rd December 2016, 03:08 AM
xrviz
xrviz's Avatar
It won't click. It's not a mechanical relay but a solid state control module. If you jump the pins and you don't hear the pump running then your pump is dead or less likely the fuse is blown. You can hook a voltmeter to the pump while you turn the key on to prove the relay is sending power to the pump.
xrviz is offline
post #5 of 12 Old 23rd December 2016, 03:19 AM
xrviz
xrviz's Avatar
xrviz is offline
post #6 of 12 Old 23rd December 2016, 03:47 PM Thread Starter
travish325
Aha I see, that makes sense then. I went back about 2 hours later to trailer and the damn thing started right up, I could hear the fuel pump running this time. Looks like ill be changing it out this weekend.
-E39 M5 (DD)
-94 Land Cruiser (Stock For now)
-01 Bullitt (800whp toy)
post #7 of 12 Old 23rd December 2016, 07:49 PM
100%Cocoa
100%Cocoa's Avatar
Very common E39 bug. Symptoms are spot on for a pump failure. You can always get it to start by thumping it with a hammer It'll go for months longer that way, but it gets a little frustrating lifting the back seat each time you want to start the car...
It's an easy swap. You just have to be happy to have one hand stinking of petrol for a while if your tank is still full.
100%Cocoa is online now
post #8 of 12 Old 23rd December 2016, 08:02 PM Thread Starter
travish325
Good thing I have less than a quarter tank!
-E39 M5 (DD)
post #9 of 12 Old 24th December 2016, 05:30 AM
billydhakid
Its the pump. Happened to mine during the summer. Was driving for 30 min, went into a store for about 40 min. Come back out and would fire up but then die instantly. My relay was fine, the pumps i guess just do that randomly. Sucks because it was my DD and i was frustrated for a good week, due to towing and figuring out how to get a pump as fast as I can.
billydhakid is offline
post #10 of 12 Old 24th December 2016, 05:33 AM Thread Starter
travish325
Well I got the pump and filter changed out, but... When I was putting the sending unit back in, the plastic piece that hangs off broke off. I grabbed the piece and set it aside, I was pretty pissed so I said "screw it" and put the unit in and sealed it up. When I started the car and ran it the fuel level read the same as it did the day before so I'm not sure if that plastic piece is important or not.
DIY: Suddenly stranded? Testing your fuel tank levels, fuel pump relay, and fuel pump in 10 minutes with a piece of copper wire JoeFromPA E39 M5 and E52 Z8 Discussion 91 11th March 2016 01:06 AM
Fuel Pump Died Will 540 pump fit? manualshifter E39 M5 and E52 Z8 Discussion 23 12th April 2014 04:32 PM
Fuel pump died, now C9 peake code MA3HOK E39 M5 and E52 Z8 Discussion 20 10th September 2012 06:48 PM
Beast Died Today "Fuel Pump Relay" CarterM5 E39 M5 and E52 Z8 Discussion 7 25th November 2010 12:06 AM
Fuel pump died... Nicolas E39 M5 and E52 Z8 Discussion 3 10th February 2007 02:30 AM
