13th May 2005, 21:18
#1 (permalink)
A Tale of Extended Warranty, High Blood Pressure and Woe
I'll tell you right up front this story has no specific point. In fact the ending isn't even written yet. But it is fresh in my mind and I know you'll at least relate to the frustration.
My car, for the record, has 90K miles on it. Lately it has been making a few noises - one, a valve-train-speed tick - my diagnosis was a stuck lifter. Also, a jingly-marbley sound on initial acceleration, like a steel ball rolling around in the catalytic converter. Thirdly, I had noticed one of my rear axle seals was leaking (not the first time I've needed one replaced - anyone else have this problem?)
I have the National "Pinnacle" extended warranty, which is probably one of the better ones. But for those of you expecting to purchase an extended warranty, or who have one but haven't used it yet, this will help prepare you for "the way it works" which is in no way, shape or form remotely like the factory warranty.
I brought the car in on May 9, described my complaints in full to the service advisor. I suggested I go for a quick ride with a mechanic to demonstrate the jingly noise, but there was none available. One of the exasperating things about the extended warranty is that I have to commit to a $140 "diagnostic" fee for each complaint. If it turns out to be covered by warranty, the diagnostic fee is covered. If not, however, I have to pay. I've encountered this before, so I wasn't surprised. On the other hand I was pretty confident the ticking (the only "serious" sound), being (I thought) caused by "an internally lubricated part" - would easily be covered.
Day 1: I get a call that afternoon - "We are just getting into your car, we'll have to keep it overnight." I'm used to that. I'm lucky to have a borrowed car for as long as I need it. Otherwise I'm looking at $25/day worth of rental car. Why they make appointments for service they can't perform is beyond me, but it is par for the course, at least at my dealer.
Day 2's phone call - "The rear axle is indeed leaking" (Duh!) - It is covered by the warranty. Yes, the ticking noise sounds like a lifter - we have to open it up to find out. I need you to authorize $1885." I'm not happy about being on the hook to come up with this cash if the warranty company finds a way to wiggle out, but again, I'm reassured it is a lifter problem and, knowing I have never run the car out of oil, I know it isn't my fault. I authorise the tear-down.
Day something (I lost track) "OK, we inspected the lifters and they were all fine. It turned out to be a loose spark plug. So the warranty doesn't cover it. I am out for diagnostic, labor, a new spark plug and boot." "What about the jingly noise?" I inquire. "He says it is the Vanos accumulator. And since it is a noise, not a defect, it isn't covered.". I wonder aloud how it can possibly be the Vanos accumulator but I accept my fate and elect not to spend $500 for a new one.
Today I was told I could pick up the car. I went and did the paperwork, forking over $536.76. Then I asked to speak to a mechanic so he could explain the "accumulator" diagnosis to me. We sit in the car, I make it make the noise (right there in the parking lot) and he agrees - no way it is the Vanos. It is coming from further back on the vehicle. I believe the false diagnosis came from an assumption on their part that I was complaining about the M5's well-known, pre-ignition-like-noise on initial throttle blip, that IS related to the Vanos system. I chose to live with that a long time ago. Of course, I would have described that noise as a pre-ignition-like-noise on initial throttle blip, NOT a jingly-marbely like sound on any physical acceleration or deceleration (which is, in fact, how I described this noise and how the service adviser put it down on the work order.)
I told them there's no way I wasn't happy about paying $140 for a "diagnosis" that defied basic logic - and they had no choice but to agree. They're keeping the car and will re-diagnose the problem.
Meanwhile I lost two hours of my day, and I spent $530 on a freakin' loose spark plug.
 AAAAAAAAAAAAaaaaaaaaaaaaaaaaarrrrrrrrrrrrggggggggg hhhhhhhh!!!!! :
I guess there is one moral: If you hear ticking that sounds like a stuck lifter, check/tighten your sparkplugs!
P.S.- I think that its about time to shop for a good independent mechanic - if anyone knows of one on the peninsula, S.F. or Santa Rosa area, please let me know.....
13th May 2005, 22:48
#2 (permalink)
Re: A Tale of Extended Warranty, High Blood Pressure and Woe
Sorry to hear of the frustration...
...but you didnīt have to pay the $1800 for the teardown, did you? That is at least something.
Did the "ticking" sound go away completely when the sparkplug was tightened?
David
13th May 2005, 22:57
#3 (permalink)
****-it that irritating Greg. I had a loose plug in my old e34 525iT, it made more of a metallic knock sound that your ticking sound. Good luck with the other noise. It is frustrating when a SA sits there and listens to you spend 5 minutes explaing a fault, with hand motions, diagrams on napkins etc and then to type in "customer complains of rattle noise". I've gone as far as taking the shop 'hard copy' of the r/o and writing elaborate notes in my own handwriting, which at least lets them know that YOU know what you're trying to explain, and usually gets you a phone call to ask...
Me, i'm still waiting for CSAA to "authorize" my hit and run door repair, after sitting at the body shop since 8am monday (which i reported and informed them of my appointment over a month ago), and me in a dodge durango rental... Funny story (now) i locked the keys in it (the rental) with the engine running, and wipers going, this morning in my driveway... I wondered how long it could idle on 25 gallons of gas, or if it would overheat, or if the wipers would catch on fire from the friction... AAA actually showed up in 15min so no drama...
Engine:
Suspension:
Interior/Misc:
13th May 2005, 23:59
#4 (permalink)
Just think how you'd be treated if you didn't know the drill...People are just screwed day in and day out.
(Once done, you'll need to let us know if it's tinker bells buddy)
Knock on wood, but I've never had serious issues with the M...with other cars I insist on a drive/discussion with the mechanic. I know, they just wear you down with "sir, we'd be happy to have one drive, but they are all busy"...
Good luck
A
14th May 2005, 02:37
#5 (permalink)
Would it be possble to post a sound clip of the said noise?
14th May 2005, 04:54
#6 (permalink)
Best of luck with the repairs, I am sure as our cars age there will be many stories to come of un before seen problem. Josh
1/2 of the Southern Renegades....
I just love the smell of JP-5 in the morning
14th May 2005, 07:06
#7 (permalink)
I'm sorry Greg, if that was me I would be livid beyond all belief. On the plus side, no damage was caused by the loose plug. I had a plus losen up on my old GTI, and the resultant lean condition burned one of the exhaust valves. That was only $1000 is diagnostics and repairs...all for a $4 plug.
I understand why you wanted to tear it down though, as a stuck lifter can cause some problems. Not even to mention getting metal shavings in the oil depending on how badly it was abused. It's just too bad that wasn't the issue. Hopefully the blood pressure will slowly go down, as burst veins do nothing for appearances.
-Brendan
'01 540/6
14th May 2005, 16:00
#8 (permalink)
Administrator
Annoying! Yup, sounds like you are on the right track to go to an independent mechanic who you can trust that knows what he is doing (and you know what he is doing as well!)
"Of course, I would have described that noise as a pre-ignition-like-noise on initial throttle blip, NOT a jingly-marbely like sound on any physical acceleration or deceleration (which is, in fact, how I described this noise and how the service adviser put it down on the work order.)"
14th May 2005, 18:34
#9 (permalink)
Greg,
Sorry to hear your tale of woe. I bought a top-of-the-line extended warranty and the company promptly went belly up.
The last 6 months of my ownership, mr car was out of regular warranty. Every time I went to the stealers (that that was very frequent) I had to authorize $180 for diagnostic. It was highway robbery. Unfortunately, my independent mechanic lacks the tools to zero in on the failed parts even with fault codes. It is not his fault, few has the $million set up that allows one to know if its the O2 sensor, or the MAFS sensor that went bad.
I love an M5, but the thought of one not covered by a reasonable warranty (like the original 0-50k miles wararnty) REALLY scares me. To the point that I have now decided that I will not pick up another M5 again. I have yet to hear if the CPO program makes you fork over the diagnostic fees. And many recent threads asking about nagging issues with higher-miles cars did not help matters. These cars are so complicated that in many cases, I have little choice but visit the dealers, and they do not run 'shy' service departments.
It goes beyond money. If I was Bill Gates (and I'm not) I would still be mad. It is the aggrevation and the knowledge that I was taken for a sucker that galls me.
CP
CP
00 Titanium Silver: 6/00-1/05 RIP
95 Black Metallic RUF BTR-2
07 Meteor Grey Cayman
