Old 13th May 2005, 14:12   #1
rigsby
Garage: M5 Carbon Black
How do I change the gearbox oil?
Slightly different tack on the Gearbox Oil inquisition, just wanted to know if there is a description/instructions somewhere on how to do the oil change? I had a quick search but only found debates on which oil to use.
thanks
rigsby is offline
Old 14th May 2005, 07:26   #2
hudson
hudson's Avatar
Garage: 2000 M5 Anthracite/Black
Re: How do I change the gearbox oil?
rigsby
Hope this helps
Joe
hudson is offline
Old 14th May 2005, 08:35   #3
greer
greer's Avatar
Garage: 2003 M5 Ti. Silver
thanks
From the consensus on the Board, which is the best gear box oil?
greer is offline
Old 14th May 2005, 09:43   #4
Need4Spd
Need4Spd's Avatar
Be sure to remove the fill plug (number 2 in the picture) BEFORE removing the drain plug. The plugs are very tight from the factory and I needed a breaker bar and a lot of muscle to get mine off. If you remove the drain plug and then can't get the fill plug off, the gearbox will be empty and you'll have what's known as a non-driveable car! I read that the plugs should be torqued to 50 nM (37 ft-lbs.). You will need a hand pump to pump the new fluid in, as there isn't any way to just pour it in.
The consensus seems to be to use OEM LTF-1 or the newer LTF-2 if you're not into taking risks, and to use Royal Purple if you don't mind a bit of risk. No one seems to want to risk using Redline.
Need4Spd
Need4Spd is offline
Press Release no 2: The new V10 engine in the BMW M5: A masterpiece in engine cons... Gustav Most Memorable Threads' 31 4th July 2004 22:23
Anyone ever loose oil pressure from an oil change? madyspop E39 M5 and E52 Z8 Discussion 9 22nd April 2004 10:46
Gearbox oil change - Mobil 1 Urban Myth ?? IvanDias E34 M5 Discussion 8 25th April 2002 23:54
My 1200 mi service - no oil change greg E39 M5 and E52 Z8 Discussion 6 24th April 2000 04:12
Page generated in 0.11163 seconds with 12 queries
