Old 12th May 2005, 23:09   #1
glenn///m
Garage: e30 e39 m5 v8
newbie..............help
first of all, hello
secondly can anyone help with a problem i have with my m5 engine transplant,
i have installed an e39 m5 engine, box clocks exhaust,etc into an e30.
it is about 70% completed.
the problem is that when i start the engine, everything is ok until the temperature gets to about a third of the way up the gauge (the rev lights are out to about 5500rpm) , it starts to choke up(over fuelling), wont run without holding it above 3000rpm, if i let it go below 3000rpm it splutters and cuts out.
any body got any idea's ???
glenn///m is offline
Old 13th May 2005, 00:30   #2
s62fan
s62fan's Avatar
Garage: Jet Black
Re: newbie..............help
You stuffed an S62 in an E30? Please post some pictures. The electronics are your most likely culprit. I'm sure other folks with more knowledge will weigh in on this thread.
Good luck!
Eric
s62fan is offline
Old 13th May 2005, 00:35   #3
Gustav
Administrator
Gustav's Avatar
Check out this one, identical to yours
S62 (M5 E39 engine) powered E30 M3!
Gustav is offline
Old 13th May 2005, 00:52   #4
Jayson
Jayson's Avatar
Garage: m5
Send a message via AIM to Jayson
HOly ****!!!
Thats gonna be real front heavy now, but what a rocket if you can get it to hook up.
Jayson is offline
Old 13th May 2005, 19:03   #5
Ashok Arora
Ashok Arora's Avatar
Fastest E30 in Wales - that's for sure! Welcome aboard Glenn
Ashok
Let me tell you what SMG stands for...
Ashok Arora is offline
Old 13th May 2005, 20:13   #6
boostmiser
boostmiser's Avatar
Garage: 2002 Alpine White M5
Well, I was about to tell you to call a local shop around me but you're not in the States. This shop I'm speaking of is installing the S62 into a 635Csi. Good luck.
The Upgrades: Dinan Stg. 1 / Dinan RSB / TCD Sway Bar Brackets / UUC Evo III SSK / UUC DSSR / UUC Tranny mounts / MKIV Nav Unit / JL 500.1 Amp / JL 12w6v2 Sub
boostmiser is offline
Old 14th May 2005, 00:56   #7
DavidS
DavidS's Avatar
Garage: 2000 M5 LeMans blue
Sales Feedback: (4)
Great Project!
Great project!
Get yourself an OBD-II fault-code reader with real-time data plotting capability. Not very expensive. Then you will know at least what the DME thinks is wrong. That is, if the DME is at all aware something is wrong...
Btw, are you positive you have ignition on all cylinders?
David
DavidS is offline
Newbie..Buying Used from a Private Party birdie74 E39 M5 and E52 Z8 Discussion 2 27th April 2005 18:02
Stupid Newbie Question #2 - Can the autolocking doors be overridden?? wolfturbo E39 M5 and E52 Z8 Discussion 4 19th October 2004 18:45
Newbie Car Wash and Wax question ron4sc E39 M5 and E52 Z8 Discussion 12 2nd August 2004 01:55
newbie questions BMWBOY79 E90 M3 Sedan, E92 M3 Coupe, E93 M3 Convertible, E46 M3 and E36 M3, Z4 M and Z4 M Coupe 2 12th November 2003 12:39
Potential M5 newbie asks a lot of questions. Verschuur E34 M5 Discussion 3 22nd August 2002 12:12
Page generated in 0.11582 seconds with 11 queries
