Old 12th May 2005, 22:43   #1
FAST 5
FAST 5's Avatar
Has anyone changed their front headrests with the ///M3 headrest ?
Hi Guys,
I just got a new set of M3 front head rests, which has the ///M logo embedded into the leather material. I'd like to swapp out the stock headrests for the M3 headrests.
Can this be one? I looked at the fork like travel pins for the stock version head rests and they are very different than the M3 taveling pins. The M5 headrests have deep grooved notches on both sides of the pins and the M3 headrest pins have very small sized grooves when compared to the M5 pins. Last question, I pushed the power button upward to raise the headrest all the way up until it stopped on its own. I pulled straight upward on the headrest trying to dislodge it from its position but it didn't budge. Does do these headrests come off from the seat back??? Thanks for your help and any information on my situation. The first two PICs are the M3 headrest, and you can see the pin posts are different than the M5 pin posts. See the notches, as they are very different.
Robert
FAST 5 is offline
Old 12th May 2005, 22:52   #2
Audioguy
Audioguy's Avatar
Garage: Indianapolis M6
Re: Has anyone changed their front headrests with the ///M3 headrest ?
Robert;
I know on an E38 car you've got to pull a retention pin on the headrest posts in order to get them out. this is done by gaining access to the seat back. I'm not sure if the M5 follows suit, but I would think so. I'll do some poking around tonight.
-Audio
2006 M6 Indianapolis Red / Sepang Bronze
2004 SL55 Brilliant Silver / Berry Red
2000 M5 Carbon Black / Silverstone (Retired)
- Iforged Aeros
- Stoptech Reds
- BB Tri-flo
- 6000K
- Rogue SSK
Audioguy is offline
Old 13th May 2005, 00:26   #3
MT JTN
MT JTN's Avatar
Garage: 2002 Carbon Black BMW M5
I am pretty sure I have seen a Beast with the ///M embossed leather headrests. I just assumed they were taken off an M3 and put in, so I would bet that this would work...
-Matthew
'02 M5 -- Carbon Black/Imola
____Supersprint X-Pipe & mufflers
____Dinan short-shift kit
'03 MINI Cooper -- Pure Silver/Black
MT JTN is offline
Old 13th May 2005, 00:38   #4
FAST 5
FAST 5's Avatar
Anyone have clear detailed instructions on who to remove the stock M5 headrests ???
Thanks.
FAST 5 is offline
Old 13th May 2005, 00:40   #5
MT JTN
MT JTN's Avatar
If not here, perhaps a quick phone call to the local dealer service department would fit the bill?
-Matthew
MT JTN is offline
Old 13th May 2005, 01:57   #6
FAST 5
FAST 5's Avatar
I work at a BMW dealer. The crazy thing is the techs are brain washed or trained to ONLY do "things" by the BMW book, and if its not in there it can't be done. My BMW techs are very anal. the only thing that they will do is Dinan related work, outside of normal BMW procedure/work. BMW must be putting something into their water cooler.
FAST 5 is offline
Old 13th May 2005, 02:52   #7
kiwi M & M
kiwi M & M's Avatar
Garage: '01 ///M5 Silverston/ LeMans Interior
Remove front headrest.
Just PULL HARD. You probably don't have to raise the mechanical part all the way up either.
While trying to figure out how to adjust the headrest, I found that I can just pull it out if I apply enough force on it (quite a bit so don't hurt yourself).
Hope this helps.
-Jay
"You've gotta have a lot of balls to play golf like I do."
'01 / / / M5 Silverstone/LeMans/Titanium
'95 / / / M3 Cosmo Black/Black SOLD
kiwi M & M is offline
Old 13th May 2005, 03:04   #8
boostmiser
boostmiser's Avatar
Garage: 2002 Alpine White M5
Hope this helps.
-Jay
I believe that I too, just pulled hard to get them out. They kind of snap out. However, be careful when putting them back in. I banged on it too hard and broke the plastic mount that holds the travel pins, as you call them. See, the plastic mount is connected to the motor so it can slide up and down. I needed a new mount after that. If you remove the seat back (two torx screws at the bottom) you'll see what I mean. If the travel pins on the front headrests are like the rear, you can unscrew them out and put them in the M3 headrest.
The Upgrades: Dinan Stg. 1 / Dinan RSB / TCD Sway Bar Brackets / UUC Evo III SSK / UUC DSSR / UUC Tranny mounts / MKIV Nav Unit / JL 500.1 Amp / JL 12w6v2 Sub
boostmiser is offline
Old 13th May 2005, 03:11   #9
DavidS
DavidS's Avatar
Garage: 2000 M5 LeMans blue
Sales Feedback: (4)
Here is how I would do it: Run the headrest to its topmost position, then pull with force upwards while wriggling it back and front.
(This is how it is supposed to be done on my MY2000 car. Use info at own risk. I will assume no liability should anything break.)
David
{Kiwi and Bootmiser, pardon my redundant post - you posted while I was typing. Lots of windows open right now... }
DavidS is offline
Old 13th May 2005, 11:22   #10
Tin
Tin's Avatar
Garage: M5 - Avus Blue
Cool idea Rob, but how about getting the m colours painted in the 3 stripes? and the "M" in silver to match the colour of your car? even more unique
Let us know if the headrest pulling technique works, want to take them out for some aftermarket work too
Kelleners ECU remap, Kelleners uprated Sport Camshafts, Kelleners Custom 3.45 Rear Diff, ACS DFC Suspension, 19" ACS TypeIII's, Brembo GT Kit (F:8pot/380mm front,R:4pot/345mm), Supersprint RHD headers,100cel sport cats,x-pipe and 90mm backboxes, ACS Rear Diffuser, Evosport lightweight pullies, Dinan Front & Rear Strut Bars, Dinan Rear SwayBar,ACS pedals & handbrake, GruppeM induction kit, AA CAI,IgnitionSolution PlasmaCoils, Rouge SSK with weighted rod, BeastPower brackets, NAV-Tv, MKIV Widescreen retrofit,2x10" M-Audio Subs, Hardwired V1,Xenon interior lights
Tin is offline
OT New Z06 rebel1 E39 M5 and E52 Z8 Discussion 86 12th January 2005 01:43
BMW M6 Press Release no 5: Body, Design, Equipment: Light and Safe, Sporting and... Gustav E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 9 15th December 2004 22:25
Looking for Track Brake pad options for factory brakes Lscman E39 M5 and E52 Z8 Discussion 46 15th March 2004 08:22
Page generated in 0.18488 seconds with 12 queries
