B9 , Exhaust camshaft Vanos position control - BMW M5 Forum and M6 Forums
 3Likes
post #1 of 98 Old 26th October 2016, 10:28 PM Thread Starter
vallibirgiss
I got the B9 Exhaust camshaft vanos position control code
So far i replaced the exhaust cps , switch sides to confirm it's working and it is
Checked the vanos solenoids and board , also confirm that it's not that by switching sides
Any ideas?
vallibirgiss is offline
post #2 of 98 Old 27th October 2016, 09:06 AM
ard
Super Moderator
ard's Avatar
Check the wiring from the sensor to DME?
ard is offline
post #3 of 98 Old 27th October 2016, 11:32 AM Thread Starter
vallibirgiss
post #4 of 98 Old 27th October 2016, 05:23 PM
mech9t8
mech9t8's Avatar
mech9t8 is offline
post #5 of 98 Old 27th October 2016, 07:05 PM Thread Starter
vallibirgiss
No changed both exhaust , no change still error on bank 1 , so i switched cps to see if code would move from bank 1 to bank 2 but no luck still bank 1
post #6 of 98 Old 28th October 2016, 12:13 AM Thread Starter
vallibirgiss
post #7 of 98 Old 28th October 2016, 05:01 AM
xrviz
xrviz's Avatar
You don't want to test the sensor itself since it's new, you want to test the circuit with the sensor plugged in. Use wire-piercing probes, put the voltmeter on AC volts. Pull out the fuel pump relay so the car doesn't start. Have someone crank the engine while you watch the meter. You should see about 1 volt.
xrviz is online now
post #8 of 98 Old 29th October 2016, 07:59 AM
Sailor24
Sailor24's Avatar
When you get position control alone it is usually a failed diode on the board. The solenoids will still work but the diode will not be absorbing the produced electricity so the solenoid does not close exactly when it should. If all your diodes are fine then it is likely a leaking solenoid. Sometimes they leak for mechanical failure and all the cleaning in the world will not help, you just have to replace it. Dis vanos test will point you to the correct cause.
Sailor24 is online now
post #9 of 98 Old 8th November 2016, 07:49 PM Thread Starter
vallibirgiss
Still no solution , checked the wiring everything seems good
Sailor24 , yes i understand but shoulndt the error code switch from bank 1 to 2 if i switched the boards?
I'm starting to think that i may be some vanos piston issues / timing ?
post #10 of 98 Old 9th November 2016, 09:38 AM
Sailor24
Sailor24's Avatar
My bad. I re read your first post and got it wrong the first time.You replaced a CPS and switched it side for. Then you swapped the boards side for? Through all this the code has remained the same? You have cleared the codes in between? I assume yes.
Could be hydraulic but finish checking the wiring first. There is this strange ground fault, it is located in the injector wire housing, but you need not go there just jump a wire to the grounds of the boards. A temp wire with a couple of alligator clips. Find a good/easy bolt and clip there then to the ground wire on the board. If no change then think hydraulic.
If it is hydraulic with that code it would be piston seals failed, unusual but there is a kit for it. Many posts on the system, I have no experience with it. In all the cars I have seen I have never seen anything but board failure.
If you want to read about the failure. It was first posted by one of the Aussies put vinegar in your search as this is how he cleaned it. Sorry don't remember who but the Aussies like to start their names with M5.
B8 (Intake camshaft VANOS position control" VANOS Passes All Tests thekurgan E39 M5 and E52 Z8 Discussion 12 15th November 2015 09:32 PM
Vanos exhaust position control and exhaust retard valve technician117 E39 M5 and E52 Z8 Discussion 10 31st October 2014 01:54 AM
Exhaust camshaft VANOS Position control, Cly #5-8 mubarak E39 M5 and E52 Z8 Discussion 8 18th September 2014 01:39 PM
Code b9 "Exhaust Camshaft 1Vanos Position Control murph550 E39 M5 and E52 Z8 Discussion 3 28th January 2009 03:02 PM
Is it safe to drive the M with an Intake Camshaft Vanos Position Control Error? Stickman E39 M5 and E52 Z8 Discussion 6 29th June 2006 12:51 AM
