Many of you will know my previous build threads. Here is the previous one:
http://www.m5board.com/vbulletin/e3...ion/492777-redshift-s-2003-m5t-sc-touring-build-thread-s-finally-happening.html
Recently, I hired Bimmer Performance Center here in Raleigh to reinforce my rear subframe, add methanol injection, and tune the car.
They did a great job, and in the process of working out the details, we ended up going with 60lb Bosch dual spray injectors along with an 88mm pulley. We also went with a Pro M 80 MAF so that the tune is very smooth and adaptable to all weather and humidity conditions.
We also tossed in a very low mile (25k) freshly re-sealed Dinan 3.45 LSD at the same time. To say the car pulls like mad is an understatement. Gears 1-3 can be useless depending on traction.
Here's the MAF I'm running:
Pro-M 80
I ran it at the track but it got a bit hotter than I'd like so I backed off after 10-15min of hot lapping. Ended up driving the M3 touring instead.
Here are some photos of the latest additions as well as a dyno chart.
Pro-M 80
