• Latest threads
    • Custom feed
      • News
        • Updates
          Old 29th April 2005, 11:59   #1 (permalink)
          DavidS
          DavidS's Avatar
          Germany: shock absorber (damper) testing
          German board members, when you take the M5 to Dekra (or similair establishments) for compulsory road safety checkup they run a vibration test of the shock absorbers (stossdämpfern). They usually print the test results. On my car when it had around 60000 kms it was about 80-86% shock absorber damping on all wheels.
          As a comparison, would you like to post your mileage and damper test results here, please?
          David
          DavidS is offline
          Old 29th April 2005, 18:18   #2 (permalink)
          ard
          ard's Avatar
          Re: Germany: shock absorber (damper) testing
          This gets at a topic I've often wondered about: how can one determine, quantitatively, when shocks/struts are worn out or getting worn... sure, bounce on the fender, look for oil, but when does a shock start to loose it's damping ability as compared to new?
          On the above test, is it 80-86% of new...or is it 80-86% of the government set value for all schocks?
          A
          ard is offline
          Old 29th April 2005, 22:43   #3 (permalink)
          DavidS
          DavidS's Avatar
          I haven´t got a clue really, but would guess the figure means 86% harmonic damping per cycle of suspension "bounce".
          The apparatus they use is a vibrating plate that shakes the wheel vertically, and then stops shaking.
          David
          http://www.m5board.com/vbulletin/showthread.php?t=54788
          http://www.m5board.com/vbulletin/showthread.php?t=88323
          DavidS is offline
          Forum Jump
          Is Germany going Downhill? jamesnj Off Topic Forum 18 30th July 2004 17:54
          Q for the specialists: Shock absorber testing / specification? DavidS E39 M5 and E52 Z8 Discussion 0 26th March 2004 19:24
          French Wars rwolfcastle Off Topic Forum 8 26th March 2003 04:56
          Tech: Dinan suspension install (long) M5Joe M5 E39 and E60 tips & tricks 1 26th January 2003 05:34
          TECH: suspension question petesamprs E39 M5 and E52 Z8 Discussion 4 18th September 2002 05:40
          Page generated in 0.22597 seconds with 11 queries
