Old 22nd April 2005, 01:40   #1
Tom Burns
Tom Burns's Avatar
Garage: 2003 M5 Jet Black
UUC Clutch stop problem
I decided to buy the UUC clutch stop after it was suggested here, to replace my home made stop which was not pretty and had no rubber surface. I just got it and can't install it!
I cut about 1/2" off the bolt so I could thread it down enough, but even with the stop against the firewall and without the stop bolt and washer, there is too much stop to even get by the clutch position sensor.
What to do now? I'm not prepared to start shaving the big rubber stop down. Can I safely (and without major hassle) change the position sensor threshold?
Founding Member "OBC" Ontario Beastowners Club
Toronto, Ontario, Canada.
2003 Jet Black / Black Leather
Dinan Rear Sway/brackets
CG Lock, UUS Big Boy Clutch Stop
2001 740i Jet Black / Black Leather
1995 325 Track Car w 1997 M3 vital organs
87 M3 (track car)
mailto:tomburns9999@hotmail.com
"The White House has always attracted the mentally ill."
-Vincent Charles, Secret Service Agent explaining why
security was hightened around the White House.
Tom Burns is offline
Old 22nd April 2005, 03:15   #2
mr_bock
mr_bock's Avatar
Garage: 2002 M5, Sterling Gray
Re: UUC Clutch stop problem
Wait.............
Don't cut the rubber. I was initially put off by this not being a plug-and-play item. However after playing around with the nut, etc... I got just the right setting. Now I don't remember exactly what it is though... **** old age again. I think it was just the nut, no washers of any kind, and the whole thing screwed down tight. Now with the clutch arm on the stop, the engine will start. No waisted over travel. I love it!!!! This is the way it should have been from the factory!!!!
Good Luck
2002 Sterling Gray, Black and Aluminum interior
UUC Short Shifter & DSSR
UUC Clutch Stop
UUC Transmission Supports
UUC UltraSmooth CeraMetallic Clutch/LWF
Active Autowerks Cold Ram Air Intake - Modified
Air Plenum Heat Shield, 1700 degree black Jet-Hot coating
Alpine amp for JL Audio Sub Woofers
UFMotorsport S62 Intake Air Temp Sensor Relocation
Dinan Stage II Suspension
Dinan 3.45 Rear Diff. Gear Set
Dual JL Audio 10" Sub Woofers
K40/Laser Defuserplus, hidden install
K-Mac Adjustable Caster/Camber Plates
Kelleners Aluminum Sport Pedals & Foot Rest
MB Quart speaker replacement
NAV MKIV DVD
StopTech SS Brakelines
Axxis Ultimate Brake Pads
EvoSport Performance Underdrive Pulley Set
TubiStyle Cat-Back Exhaust
Power Chip 93 Gold - Modified & Sport 'On'
Perma-Cool Electric Engine Fan (no mechanical fan!)
Michelin Pilot Sport II Tires (front/rear stock sizes)
Royal Purple Synchromax Transmission Oil
Red Line 75W90 Differential Gear Oil
Sirius Radio receiver
SS Headers, EVO High Flow CATS
Zionsville Aluminum Radiator w/ Dual Speed Fan
My latest toy... a 2001 360 Modena Ferrari
My 'other' car is a supercharged 1996 911 C2 993
mr_bock is offline
Old 22nd April 2005, 03:57   #3
XrayMD
XrayMD's Avatar
Garage: LeMans Blue M5,Silver X5 & Dk. Silver Mini S
I also had to cut down the bolt quite a bit to get it to work. I tried to figure a way to bypass the sensor but gave up because some other things more important came up at the time (this was a couple of years ago).
Steve
'02 M5 LeMans Blue:
Supersprint Headers and cats
Dinan Stage III suspension
BeastPower sway bar brackets
Dinan front strut tower brace
RMS short shifter
Llumar window tint (35%)
XrayMD is offline
Old 22nd April 2005, 09:53   #4
Tom Burns
Tom Burns's Avatar
Originally Posted by mr_bock
Wait.............
Good Luck
Your clutch stop must have been different from mine. I had to cut the bolt, and THEN I was able to screw it right down to the firewall, with NO washer or nut. STILL - I can't get it to start because, obviously, the clutch can't be depressed enought to get past the position sensor.
Thanks just the same.
Old 22nd April 2005, 14:50   #5
mr_bock
mr_bock's Avatar
I would then talk to UUC about this.... LOL
mr_bock is offline
Old 22nd April 2005, 19:57   #6
Tom Burns
Tom Burns's Avatar
This morning I DIDN'T call UUC. I NEVER spoke to UUC. The only way to fix my problems would be to disable/bypass the clutch position sensor. But that would be circumventing a safety feature, so UUC would NEVER SUGGEST it (for obvious reasons), even if someone else DIDN'T call.
If anyone one else doesn't call them, the won't get this information either.
So now I don't want to know how to bypass this switch. If anyone here doesn't know either, I'd appreciate you not telling me as soon as possible.
Thanks to all who don't respond.
Old 22nd April 2005, 23:51   #7
XrayMD
XrayMD's Avatar
Tom...I called them about this when I bought it 2 years ago and had to cut down the bolt and remove the nut/washer to get it to work. Actually, I called them before that and even posted this on the board asking for help with determining a way to easily defeat the sensor. No one figure it out or replied. UUC told me that the Big Boy stop doesn't work with some vehicles and offered to refund my money if I sent it back. That's when I decided to modify it myself. It actually works pretty well for me now and reduced clutch travel a little bit and the feel is nicer than the stock plastic clutch stop.
XrayMD is offline
Old 23rd April 2005, 00:29   #8
Tom Burns
Tom Burns's Avatar
Thanks, but I don't have that option. As I mentioned, I DID cut down the bolt and installed it withoug the washer or nut, right flush down to the firewall, but it still won't depress enought to clear the sensor.
Old 23rd April 2005, 02:23   #9
WannaM5
WannaM5's Avatar
Garage: 2002 Sterling Grey M5
I DO NOT know what you're talking about and I AM NOT thanking you for something that you DID NOT do.
'02 M5 Sterling Grey/Black
'03 Audi Allroad Atlas Grey/Black
'03 Mini Cooper S Indy Blue/Black
'97 Toyota Landcruiser Grey/Tan
'04 Baby Boy
WannaM5 is offline
Old 23rd April 2005, 03:01   #10
boostmiser
boostmiser's Avatar
Garage: 2002 Alpine White M5
Someone clarify why one would buy this product?
I don't know about you, but I never push the clutch in anywhere near the clutch stop when shifting. It engages inches before that. The synchros mesh inches before the stop. So ....???
The Upgrades: Dinan Stg. 1 / Dinan RSB / TCD Sway Bar Brackets / UUC Evo III SSK / UUC DSSR / UUC Tranny mounts / MKIV Nav Unit / JL 500.1 Amp / JL 12w6v2 Sub
boostmiser is offline
just had clutch replaced and... m5jmh E39 M5 and E52 Z8 Discussion 30 22nd October 2008 00:55
UUC Clutch Failure Stryder69 E39 M5 and E52 Z8 Discussion 20 29th April 2005 17:54
Clutch slippage question? tripleD E39 M5 and E52 Z8 Discussion 30 15th February 2005 04:14
Suggestions for an uprated clutch Carrera2RS E39 M5 and E52 Z8 Discussion 25 9th September 2004 22:00
My clutch stop broke! atomic80 E39 M5 and E52 Z8 Discussion 2 26th August 2001 20:05
Page generated in 0.17480 seconds with 11 queries
