Blackknight530i 530i6 -> M5 Conversion Build Thread - Page 6 - BMW M5 Forum and M6 Forums
 56Likes
post #51 of 127 Old 4th October 2016, 01:38 AM
gmak
gmak is offline
The Following User Says Thank You to gmak For This Useful Post:
blackknight530i (4th October 2016)
post #52 of 127 Old 4th October 2016, 01:40 AM Thread Starter
blackknight530i
blackknight530i's Avatar
Well, it looks like after a test drive, the alignment is totally wrong. I'm guessing that it is toed out quite a bit, so I'm hoping I can fit an alignment in before heading out tomorrow. If not, it's not the end of the world and I can just get it done next week, but at least I know I've fixed the problems.
Sent from my SM-N910V using Tapatalk
-Paul
2003 "M5" - S62/420g swap, M5 diff, M5 driveshaft, M5 brakes, M5 Traction Bars, Eibach Sway Bars, UUC Evo3/DSSR, Custom Exhaust,
BMW NBT Retrofit, M5 Gauge Cluster, Hella G4 Bi-Xenon Retrofit, M5 Extended Leather Interior Swap, APEX PS-7s, e60 Hubs, Koni Sports
Coming Soon - M5 Bumpers
530i 6-speed swap build thread
2003 530it6 - M54b30/S6S-420g swap, 3.15 540it diff, e60 SSK, VMR VB2 19" Wheels, M5 Gauge Cluster, Hella G4 Bi-xenon Retrofit, NBT Retrofit, Koni Sports, 540i Brakes
2001 749i6 - Retired and being parted out - M5Board Build Log
blackknight530i is offline
post #53 of 127 Old 9th October 2016, 01:05 AM Thread Starter
blackknight530i
Here are some more pictures from the HPDE at VIR:
And my friend got one of Brian's car as well:
-Paul
post #54 of 127 Old 9th October 2016, 01:46 AM
gmak
gmak is offline
blackknight530i (9th October 2016)
post #55 of 127 Old 11th October 2016, 02:40 AM
zaid
zaid's Avatar
zaid is offline
post #56 of 127 Old 11th October 2016, 07:42 PM Thread Starter
blackknight530i
Originally Posted by zaid View Post
Very nice. And I like how it's still look like 530.
It won't for too much longer. I've got a M5 rear bumper and the front one will be delivered in a few weeks. Both are used OE and will be painted black sapphire and installed. Then I'll be getting the custom exhaust done with quad tips and muffler delete with magnaflow resonators and x-pipe. I'll also be getting the OE M5 rear spoiler painted at the same time to complete it.
-Paul
post #57 of 127 Old 17th October 2016, 10:06 PM Thread Starter
blackknight530i
Last Saturday I took the "M5" up to Little Switzerland by way of Hwy 226, Hwy 80, BRP, and Old Hwy 18, which was an absolute blast. We had 11 cars with us and other than a few random slow pokes watching the leaves, we had pretty good pace. The scenery was beautiful and the roads spectacular. It was a wonderful day trip.
Before heading out on Saturday, I had received my ECS Tuning 10mm spacers that I was going to install to try to keep my tires from scrubbing the lower spring perches on the front struts, but discovered that they wouldn't seat fully flush and this caused bad vibrations, so I didn't end up using them. Unfortunately, this meant that my brand new front tire I had bought now has a channel carved out of it on the inside edge, but at least it didn't take out as much as when I first did the swap. After I got back, I decided to see what was causing the issues. It turns out that one of the spacers goes almost completely flush to the inside face of the wheels, but the other one has a mm gap or so when fully seated, meaning that as you tighten the lug bolts, it flexes the spacer and will cause vibrations. Here's a visual idea of what is going on:
The large gap between the two spacers that shouldn't be there:
Swapped them around and you can see it doesn't have as much of a gap, meaning that the back one sits more flush with the wheel than the other:
My understanding is that there shouldn't be any gap at all, so I don't know what's going on. I'm not sure how ECS is going to handle this yet, since they haven't responded to my email. Hopefully they have a way to resolve it, since these had big green stickers saying that they were non-returnable once installed.
-Paul
post #58 of 127 Old 17th October 2016, 10:49 PM
gsfent
gsfent's Avatar
This is a product defect, not a return. There are all kinds of implied warranties of fitness for a particular purpose that are in effect unless there is a prominent disclaimer (each state is a little different).
Just have them send a replacement set, with a return sticker and send back the defective ones. Obviously check the new ones before installing.
If you still have an issue, contact your credit card company.
Dinan Stage 3 suspension, SS jet coated headers, ESS SC kit w/ 1 range colder NGK's, 92mm pulley, 440 Big Greens, TTFS alpha N tune for meth, RK plenum plates, Sachs high performance PP and CCC proprietary clutch disc, stock DMFW, open brake ducts, Hamann front splitters, TEC cupholder, U.S.(Euro style) tilt/slide armrest, 6k HID fogs, 6k super white low beams, V1/Stealth1, dual head LI, 2.65 diff w/40% lockup/2x dynamic, compact spare, Euro trailer hitch, Mocal oil cooler, ACS type rear spoiler, Rogue custom SSK and tranny mounts, ST 355 BBK (fronts), BP sway bar brackets, Bluetooth retrofit, Speedhut boost gauge, Dinan TB's and VS, KB BAP, Howerton/HFS-3 Aquamist WI trunk setup.......
gsfent is offline
post #59 of 127 Old 19th October 2016, 07:36 PM Thread Starter
blackknight530i
They are going to send me a new set. My old set should arrive there tomorrow, so hopefully the new set doesn't have these issues. I'll update when I get them.
-Paul
post #60 of 127 Old 20th October 2016, 10:17 PM Thread Starter
blackknight530i
Another pic taken by BlindKenny on Hwy 80 on our trip last Saturday:
-Paul
M6 build thread! moonshiner180 E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 48 5th May 2015 02:15 AM
Yet Another Build Thread Mdirty9 E39 M5 and E52 Z8 Discussion 89 18th July 2014 06:07 AM
m6 build thread :) Sigm6 E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 20 4th May 2014 06:55 AM
M5 F10 to MH5 S Biturbo conversion build thread (pics inside) Manhart Racing F10 M5 Discussion 13 27th January 2013 09:34 PM
English conversion for Alpina Orig Build sheets GaAlpinaowner ALPINABoard.com | BMW Alpina Discussion 6 26th August 2004 10:07 PM
