Old 12th April 2005, 12:31   #11
m5 rus
m5 rus's Avatar
Garage: M5 Silverstone
Send a message via AIM to m5 rus Send a message via Yahoo to m5 rus
Re: I'm gonna hit the drag strip!
Originally Posted by Ahmed
Thank You Thank You Thank YOU!
Just one question, what are the chances of damaging diffs and drive shafts? Keep in mind that i have drag radials on.
I think the same as when you race others...
Misha...
211 E55K AMG Mod...620 HP and 900 NM
E39 M5...sold...
m5 rus is offline
Old 12th April 2005, 13:35   #12
MIB
MIB's Avatar
Garage: 03 M5 Steel Grey/Petrol-LMB/Ti
Send a message via Skype™ to MIB
Hey Ahmed,
Good luck. Remember if you start to get axel hop, ABORT, ABORT ABORT.
Most breakages are because people try and power through Axel HOP, do NOT do that in the beast, or you will break EVERYTHING.
As far as launch RPM"S there is a very good reason why so many different responses.
The People who start at a very LOW RPM, are actually increases revs as the clutch is coming out.
The ones that start at a higher RPM, are waiting until it hooks up before adding more RPM's.
Even though they may not be conscience that they are doing it.
If you truely launched a car at 1,000 RPM without gradualy adding as you let more clutch out, you would either BOG down, or have a very slow launch.
So basically Everyone CAN be Right.
You just have to match it with your own style.
If you have an itchy right foot, then start at a lower RPM.
If you have a rock solid right foot, then start higher.
IF you have a very good clutch ( ) Then you can slip it at the launch, and start with much higher RPM's.
If you have a stock clutch, DO not do this, as you will Toast it.
Last piece of advice, Don't forget to have FUN.
MIB is offline
M5 on a Drag strip BRN64666 E39 M5 and E52 Z8 Discussion 77 14th March 2005 01:10
Anyone in Dallas area interested in going to the drag strip tonight? Improviz_CLK55 E90 M3 Sedan, E92 M3 Coupe, E93 M3 Convertible, E46 M3 and E36 M3, Z4 M and Z4 M Coupe 0 15th November 2002 17:28
WHo want to go to drag strip (boston crew) Boston m57777 E39 M5 and E52 Z8 Discussion 13 25th July 2002 20:13
SMG autocross & drag strip results. [V long] Enigma E90 M3 Sedan, E92 M3 Coupe, E93 M3 Convertible, E46 M3 and E36 M3, Z4 M and Z4 M Coupe 2 29th March 2002 02:32
DRAG STRIP RESULTS!!!! Yupkwondo E39 M5 and E52 Z8 Discussion 23 13th June 2001 08:03
Page generated in 0.09761 seconds with 11 queries
