I found that the rear floorboards were wet this week and started cussing, thinking that the door vapor seals had failed again. While coming back from an event with the kids in the back tonight, I gave it the beans a bit and my daughter exclaimed that a bunch of water poured out of the rear AC vents behind the console. Sure enough, I put my hand back there and the top of the tunnel was soaked. It has been hot and humid the last week, not sure I can do anything about this. Anyone else see this or know what can be done to avoid it other than not running the AC when it is hot? I'll put a some plastic down with a towel on top in the near term but I would think that others in the terminally hot and humid states would have run into this before.
After thinking about it, one thing that could be contributing is that I don't think the environmental control is working correctly. It doesn't seem to regulate the temp, just blows really cold and only way to regulate it seems to be with fan speed manually. If that is the culprit, where do I start?
