Transmission Fluid Change - Royal Purple - BMW M5 Forum and M6 Forums
 9Likes
post #1 of 42 Old 17th July 2016, 09:48 PM Thread Starter
rickc007
Ok, decided to do the change myself.
Read it made changes smoother, and after doing it, it's a nice and noticeable change.
Almost consider it a Must Do.
Couldn't really grasp by what people meant by "smoother" ,but much akin to going to the dealer and shifting a new car. Almost.
There was definitely an "oh wow" on the first shifts.
17mm socket
Grab a breaker bar, I tried without, and it was really firm.
Not an issue at all with a Breaker Bar.
Mine's 18 inches.
(Don't get a chance to say "Mine's 18 inches" often, wasn't going to pass it up)
Used 2 bottles of the Royal Purple
And a Plews 5501 Quart Pump , which is under $8.00
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Nice quick easy change.
Final Note
Royal Purple looks nice, sounds nice ... does not smell nice. It Stinks
rickc007 is offline
post #2 of 42 Old 18th July 2016, 12:02 AM
thrty8street
thrty8street's Avatar
Did you use the entire two bottles?
01 LeMans Blue/blue sport interior
BC Racing coilovers
thrty8street is offline
post #3 of 42 Old 18th July 2016, 12:21 AM Thread Starter
rickc007
You would/could say that ... I bought 3 bottles, and the pump at the link above.
Neither of the first 2 bottles "completely" emptied so I used part of the 3rd ...
When finished, I poured the remains from the first 2 bottles , into the 3rd, and it fit.
Depends how much you spill, if you're really neat, and have a better thing that that pump.
Two bottles would do.
That pump was usable, but the hose that goes inside the bottle, did not go all the way to the bottom of the Royal Purple bottle.
rickc007 is offline
post #4 of 42 Old 18th July 2016, 09:16 AM
Thumper600
Thumper600's Avatar
great to hear you're having a success and what I'm wondering about is the long term affect of using Royal Purple, thanks to anyone who can share this information.
Thumper600 is offline
post #5 of 42 Old 18th July 2016, 10:25 AM
Sailor24
Sailor24's Avatar
Why not try a search? Do advanced and throw the username LSCMan in that box. There is very detailed info on tranny oil already posted by experts who no longer post.
Sailor24 is online now
The Following User Says Thank You to Sailor24 For This Useful Post:
Thumper600 (18th July 2016)
post #6 of 42 Old 18th July 2016, 08:31 PM
zaid
zaid's Avatar
Hi Sailor24
i always used royal purple in manual transmissions. glad you like it.
i tried to message you here but i'm not sure if messaging are going thru.
i need help starting the m5 engine i swapped in to the 540 wagon
had ews and clutch switch deleted but still no start no click, nothing. but all lights comes on and there is fuel.
i'm located east end Toronto, almost Pickering. best way to reach me is text at four one six 828 9122
thanks, Zaid
zaid is offline
post #7 of 42 Old 18th July 2016, 08:39 PM Thread Starter
rickc007
I consider you an expert Sailor24 ... would you use Royal Purple in your car ?
rickc007 is offline
post #8 of 42 Old 18th July 2016, 09:55 PM
M5Quest
Did you do it in your home garage? Did you jack up the car and let it sit on 4 jack stands? How did you jack the rear? I'm afraid of ruining the rear diff...
Thank you.
M5Quest is offline
post #9 of 42 Old 18th July 2016, 10:06 PM
zaid
zaid's Avatar
Thank you.
jack it up from the differential gently. but avoid jacking from the cooling fins at the rear of the differential
zaid is offline
post #10 of 42 Old 18th July 2016, 10:43 PM
Joe_stack
I've read that royal purple is ok in the differential but to never use it in the m5 transmission....long term effects are bad...I think it's from the additives or the high levels of zinc or magnesium in the royal purple....don't remember exactly reasons but if you search on Google you will see
Joe_stack is online now
Transmission Fluid: Royal Purple vs Redline vs AMSOil? AskDrTodd E60 M5 and E61 M5 Touring Discussion 15 21st April 2013 07:01 PM
Arghhh...Failed Attempt to Change Transmission Oil with Royal Purple Synchromax blks4 E39 M5 and E52 Z8 Discussion 10 29th August 2011 08:59 PM
Royal Purple Synchromax manual tranny fluid - Who carrys 'em (Bay Area)? UltFamCar E34 M5 Discussion 1 3rd May 2006 06:02 AM
Correct Royal Purple transmission oil? isellbeachhomes E39 M5 and E52 Z8 Discussion 2 2nd January 2006 08:44 AM
Transmission and Diff Fluid Change/Coolant Flush/Change - When? x703jko E39 M5 and E52 Z8 Discussion 3 3rd April 2004 01:51 AM
