Old 25th March 2005, 02:39   #1
rhfong1
rhfong1's Avatar
Garage: 01 Dakar Yellow
M5 Spare Tire (Wheel) Question
My question is: Will the factory 18x8 M5 front wheel clear the brake caliper if mounted on the rear? I came accross a factory front wheel and am planning on mounting a full size tire to use as a spare but only if the wheel will fit the rear. I was told that this would work but not quite sure. Thought I'd consult with fellow Beast owners. Any help would be appreciated.
rhfong1 is offline
Old 25th March 2005, 03:00   #2
mr_bock
mr_bock's Avatar
Garage: 2002 M5, Sterling Gray
Re: M5 Spare Tire (Wheel) Question
Yes! the front stock wheel works on the rear. I have this in my car and had to use it on the rear. I am using a uni-directional tire that has a height slightly larger than stock. I can't remember the exact make or size right now.
Good Luck!
2002 Sterling Gray, Black and Aluminum interior
UUC Short Shifter & DSSR
UUC Clutch Stop
UUC Transmission Supports
UUC UltraSmooth CeraMetallic Clutch/LWF
Active Autowerks Cold Ram Air Intake - Modified
Air Plenum Heat Shield, 1700 degree black Jet-Hot coating
Alpine amp for JL Audio Sub Woofers
UFMotorsport S62 Intake Air Temp Sensor Relocation
Dinan Stage II Suspension
Dinan 3.45 Rear Diff. Gear Set
Dual JL Audio 10" Sub Woofers
K40/Laser Defuserplus, hidden install
K-Mac Adjustable Caster/Camber Plates
Kelleners Aluminum Sport Pedals & Foot Rest
MB Quart speaker replacement
NAV MKIV DVD
StopTech SS Brakelines
Axxis Ultimate Brake Pads
EvoSport Performance Underdrive Pulley Set
TubiStyle Cat-Back Exhaust
Power Chip 93 Gold - Modified & Sport 'On'
Perma-Cool Electric Engine Fan (no mechanical fan!)
Michelin Pilot Sport II Tires (front/rear stock sizes)
Royal Purple Synchromax Transmission Oil
Red Line 75W90 Differential Gear Oil
Sirius Radio receiver
SS Headers, EVO High Flow CATS
Zionsville Aluminum Radiator w/ Dual Speed Fan
My latest toy... a 2001 360 Modena Ferrari
My 'other' car is a supercharged 1996 911 C2 993
mr_bock is offline
Old 25th March 2005, 04:40   #3
Ducman69
Ducman69's Avatar
Garage: BMW M5 Blk/Blk
I would like to have a spare tire also, especially when taking the car on an extended trip. I have no confidence in the mobility kit, plus I don't want to deal with all of the gunk that gets inside the tire and all over the wheel.
I have the 15" Brembo BBK in Front and don't know if the stock 18" rim will work, although I have a feeling it will not. I was actually thinking of having a custom wheel made that would fit over my brakes and not take up too much space in the trunk. Possibly a 19" x 5". Could somethig like that work? Does any tire manufacturer make a narrow 19" tire? Something akin to the spare tire Porsche provides in the 993 would be great. A spare that takes up very little room deflated but can be easily inflated when needed for emergencies.
It would be great if there was enough interest that a group purchase was set up for this kind of spare tire.
James
2000 M5 Blk/Blk (FOR SALE!!!)
  • AC Schnitzer - 19" Type III 2-Piece Wheels, Short Shift Kit, Pedal Kit, Handbrake, Shift Knob
  • Brembo Brakes - 15"/380mm Front w/4-Piston Caliper & 13.5"/330mm Rear w/4-Piston Caliper, Silver Calipers
  • EvoSport - 3.45 LSD and Power Pulleys
  • Dinan - Front Strut Tower Brace and Rear Sway Bars (Hard)
  • SuperSprint - X-Pipe and Exhaust
  • Powerchip - ECU and Software
  • Hella Angel Eye Xenon Headlights with clear reflector and blinkers
  • Misc - Koni FSD Shocks, TCD Sway Bar Brackets, Smoked Tail Lights, ProShow Window Tint
2003 Ford Excursion LTD - PowerStroke Diesel (FOR SALE)
2006 Ford F250 PSD - Custom w/too many mods to list.
2005 Honda CRF450X
2006 Custom Yamaha Rhino - Shown at SEMA Show
2004 VW Phaeton
Ducman69 is offline
Old 25th March 2005, 08:41   #4
Beamer_usa
Beamer_usa's Avatar
Garage: explosive ford pinto
I'm interested in a space saver spare
Beamer_usa is offline
Old 25th March 2005, 08:56   #5
gsfent
gsfent's Avatar
Garage: 01 M5 Black/caramel
I don't know if the non M5 E39's have a space saver spare, but if so, that might be a good starting point.
gsfent is online now
Old 25th March 2005, 18:27   #6
rhfong1
rhfong1's Avatar
Good Luck!
Thanks Mr Bock. Appreciate your help. Yeah, the wheel I acquired is a factory M5 wheel. Looks like this will work out perfect. Don't like using goop and waiting for the tow truck if it doesn't work. I'm planning on using a Sumitomo HTR uni-directional tire, same size as the original fronts. I currently have Michelin Sports all around. The diameter of the Sumitomo is the same as the Pilot 245/40x18. Happy Easter!
Rick
rhfong1 is offline
Old 25th March 2005, 19:39   #7
mottati
mottati's Avatar
Garage: '91 M5 AlpineWhite II
Nope, full size spare on non M e39's. Depending on brakes, the smallest OE wheel you could use would be the 17x8 style 66, which will clear oe m5 brakes, as well as stoptechs. You'd save a little space in the trunk.
I'm also in for any GB on a space saver. The front wheel/tire combo takes up a lot of trunk space, and is not light!
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 25th March 2005, 20:06   #8
mr_bock
mr_bock's Avatar
I too would be interested in a GB on a 'real' space saver combo, but untill one is identified, I will keep a spare, jack, lug wrench in the trunk.
LOL
UUC Clutch Stop
NAV MKIV DVD
mr_bock is offline
Old 26th March 2005, 03:06   #9
dmccrary90025
dmccrary90025's Avatar
Garage: 2005 GT3 White/Black
Where did you find it? I too would like to have one around in case (for driving schools and long drives- in case I get a flat and need to limp home). thanks
dmccrary90025 is offline
2 weeks old: My impressions of the SL 55 vs. M5 (very long) Rezf E39 M5 and E52 Z8 Discussion 34 30th September 2006 02:30
IMPORTANT FOR E34 M5 OWNERS! Old M5 Messageboard Archive. Help Needed! Gustav E34 M5 Discussion 6 25th February 2006 17:28
Anyone with a spare 18"X8" wide M5 wheel want to trade for a rear 18"X9.5" Orinoccom5 For Sale or Wanted 0 21st August 2003 20:11
Your thoughts on the Z8 NO-MERCY E39 M5 and E52 Z8 Discussion 6 16th November 2001 06:26
Page generated in 0.14127 seconds with 11 queries
