Old 24th March 2005, 20:28   #1
Larry's M5
Larry's M5's Avatar
Garage: '02 Carbon Black E39 M5
Lacquer thinner on leather, good or bad? (in my case anyway)
Ok, here's the story... When I got my beast about 2 months ago, I had always thought it was all black sport seats, but as it turned out, the previous owner didn't like the original black/silverstone leather so he had someone sprayed a top black coat on the silverstone...
About a week after getting the car, I started to notice what seems to be leather cracks but in fact it's the top black paint that's cracking. I managed to scrub off all the paint on the door panels, but the black paint the seats are stuck on pretty good... I can scrub them off inch by inch by it will take forever and might not be a perfect clean. Should I try lacquer thinner? Will lacquer thinner hurt the original silverstone dye or the leather itself?
The guy who sprayed painted the interior did a very bad job, a lot of paint got on the plastic next to the leather on the door panel too... I'll be lucky if I can fix this mess On the brighter side, at least the leather underneath are kept in perfect condition I guess :P
02 ///M5 Carbon Black/Silverstone Sport
02 C32 /////AMG Brilliant Silver/Charcoal
08 328i Black/Black
Larry's M5 is offline
Old 24th March 2005, 21:20   #2
vndkshn
vndkshn's Avatar
Garage: 2005 M3 ZCP
Re: Lacquer thinner on leather, good or bad? (in my case anyway)
It likely would damage the silverstone as well, and do a number on the leather in the process.
Dan
vndkshn is offline
Old 24th March 2005, 22:05   #3
BKH
BKH's Avatar
Garage: 2000 BMW M5 Silverstone
Wow - that is unbelievable. FWIW, I wouldn't use lacquer thinner w/o testing it out first. It's too aggressive. If you try it and it really seems to leave the color and surface texture of the Silverstone inserts intact then you could probably proceed cautiously if it is the final step before conditioning. And - no matter what - you're using aggressive techniques regardless so I would make sure to get the proper conditioner for tanning process that the leather originally underwent. Is there a good shop? You could do the grunt work and turn it over to them...
BKH is offline
Old 24th March 2005, 22:15   #4
Philip
Garage: Pinto--Black
Send a message via ICQ to Philip
I use "Goof Off" to remove the painted warnings of the leather visor, and plastic visors of other cars. It removes the cured paint and leaves the surface intact. You may want to try this as I'm pretty sure it will not damage your interior leather and plactic. Lacquer is MUCH more agressive, and I would try less harsh solutions first.
Multiple applications of Goof Off may be required. Whatever you decide to use, follow up with a good leather conditioner since the paint stripping process is harsh to leather.
Philip is offline
Old 24th March 2005, 23:38   #5
mottati
mottati's Avatar
Garage: '91 M5 AlpineWhite II
if i were you, i'd go to www.leatherique.com and see if they have someone you can ask this question to. Since they make a leather dye, i'd imagine they know what you can and can not put on leather.
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 24th March 2005, 23:46   #6
Mrs_Struth
Mrs_Struth's Avatar
Garage: 2003 E39 Carbon Black
wow. why would anyone do that? keep us posted on how the restoration goes.
Mrs_Struth is offline
Old 25th March 2005, 15:19   #7
CSBM5
CSBM5's Avatar
Garage: 2001 M5 LeMans Blue
I would try mineral spirits before I would ever use lacquer thinner. I'm not sure of its effect on leather however, so trying a small section first is obviously in order. If you can get it to simply remove the sparyed on junk and not get worked into the leather itself, that should be the goal.
Current stable:
Ground Control camber plates
Stoptech front brake kit
Brake ducts opened
TC Design brackets
1996 Volvo 850R wagon
CSBM5 is offline
Old 25th March 2005, 17:39   #8
Greco
Greco's Avatar
Garage: 1998 E39 540 Biarritz Blue/Beige SPP
I second the leatherique post. Better get the opinion of a leather professional on that unless there's one on the board. I woulnd't even think about putting lacquer/thinner on the leather.
- Bill
>> Just an E39 540i/6 Biarritz Blue <<
Greco is offline
Old 25th March 2005, 21:54   #9
Larry's M5
Larry's M5's Avatar
Actually, I did write to Leatherique, it's them who recommended the lacquer thinner or prepping agent approach. They also mentioned that thinner is on the aggressive side and prepping agent might be a better idea.
But I just don't know, prepping agent is for removing the original dye in prepration for re-dyeing too right? This is really driving me nuts right now, the local pros are no help, they either said they never seen a case like this nor they just said to replace the leather.
I'm thinking about having someone to buff them out, just not sure if buffing will also remove the original dye as well. I just don't want to go thru the trouble of re-dyeing the whole thing if I don't have to
08 328i Black/Black
Old 25th March 2005, 21:59   #10
Greco
Greco's Avatar
Try a water'd down version of the prepping agent. Better off it not being as strng and taking longer to come off than it being strong and removing the original color as well.
- Bill
Greco is offline
BAD vs GOOD BMW DEALERS alpinadvl E39 M5 and E52 Z8 Discussion 42 14th February 2002 20:44
Sport vs. Luxury arm E39 M5 and E52 Z8 Discussion 15 4th January 2002 01:57
octane boosters? Good or Bad? AC M5 E39 M5 and E52 Z8 Discussion 3 6th October 2001 20:00
The good, The bad, and the Ugly (update on ME) fais2000 E39 M5 and E52 Z8 Discussion 21 15th June 2001 20:26
good news and bad news Dr.Mike E39 M5 and E52 Z8 Discussion 9 11th January 2001 07:41
Page generated in 0.16249 seconds with 11 queries
