Re: What's covered in standard maintenance agreement
The scheduled maintanence plan covers normal scheduled services as outlined in your service/warranty book. Depending on the model year, it covers this for 3/36k or 4/50k (std on 03's or an optional upgrade on earlier years). You can also upgrade this to 6/100k, i believe. It covers normal maintanence, oilservices, inspections, brakes, brake fluid flushes and coolant changes, as told by the SI lights or the timing, depending on the item. Some say the clutch is covered too, as it is a wear item.
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
