DIY: Replace Front Window Regulator POV Video - BMW M5 Forum and M6 Forums
 2Likes
  • 2 Post By M5Quest
post #1 of 3 Old 15th June 2016, 03:31 PM Thread Starter
M5Quest
Hello guys,
I changed my front passenger side window regulator couple weeks ago and took a video. I used URO Parts Premium as a replacement part... The premium is supposed to be redesigned to last longer so hopefully it lives up to the claim. I also think it has lifetime warranty? I'm not 100% but I thought it did when I bought it.
Anyways, I hope you find this video helpful!
Cheers
[YOUTUBE]
https://youtu.be/bj2wlHcOxUI[/YOUTUBE]
M5Quest is offline
The Following User Says Thank You to M5Quest For This Useful Post:
chowdah (18th June 2016)
post #2 of 3 Old 15th June 2016, 10:00 PM
gzig5
Mine broke yesterday. Passenger front stays open three inches. Can't tell yet if its the lift or somehow the window came loose from the mechanism. Will watch the vid tonight. I use a Dorman part on the rear door last year and it's been OK but the motor is louder than stock.
Where did you get the part from, link?
_____________
2000 M5 Carbon Black
Dinan 3.45 Differential
Evolve Tune
Dinan Springs w/ Koni Yellow Sport shocks
Dinan Rear Sway Bar
E60 545 SSK
275 PSS on OEM 9.5" all around
Home-built Muffler Delete
gzig5 is online now
post #3 of 3 Old 16th June 2016, 12:18 AM Thread Starter
M5Quest
I believe I got it from AutohausAZ but I am not 100% certain. So here are two places I usually compare prices:
BMW Parts and BMW Accessories | Bavarian Autosport
Then search part number: 51 338252394PRM. The link from that page isn't going to take you directly to the part I was looking it but it's $109.95 and it says lifetime warranty to original purchaser.
http://www.autohausaz.com/pn/51338252394U
This one doesn't say lifetime warranty but it is about $15 cheaper and ships for free...
Mine is quiet... Main differences between it and OEM is that the motor will use only 4 screws out of the 5 used to hold it to the fram of the regulator. And the glass pads/receivers where the bottom of the glass sits is a little bit different than OEM. I guess it's not oriented the same way but it still works and will hold it just fine.
Let me know if you have questions that aren't answered in the video! You might need butyl tape to apple under the vapor shield but mine had another layer from a previous fix looks like and I just used a heat gun to lightly heat it and it stuck there just fine.
Oh you also might need some of those plastic pins that hold the door panel to the door frame (I forgot what they are called)... I bought a bunch on eBay but they were cheap Chinese crap. One of them broke when I put back the panel so you might want to invest in OEM ones...
M5Quest is offline
gzig5 (16th June 2016)
E39 Want to buy: front window regulator stija Parts / Other For Sale or Wanted 2 26th February 2016 10:50 PM
DIY: Front Window Regulator Replacement (video) zed.inc E39 M5 and E52 Z8 Discussion 8 24th September 2015 12:28 AM
E39 M5 Front Window Regulator Adjustment skippystahl E39 M5 and E52 Z8 Discussion 0 27th May 2015 03:22 AM
E39 Want to buy: Looking for a used front right window regulator with motor for '01 e39 540i. Dob3rman Parts / Other For Sale or Wanted 3 9th July 2013 02:27 AM
Driver's window clunk/regulator problem - new regulator time? doc$holliday E39 M5 and E52 Z8 Discussion 26 8th July 2013 08:18 PM
