I had my brakes bled for a routine schedule, but it still feels just as mushy as before. 27K miles on the car. Nothing serious, but it makes me wonder if the shop even did anything. I was expecting a stiff feel. It's all stock components. I bought the car used, so I'm not sure if this is the normal feeling as when it was new.
They may not have been bled properly, there is a very definate procedure that has to be followed if you want to get a firm pedal with BMW stock brakes.
See: http://www.zeckhausen.com/bleeding_brakes.htm for all you need to know. I would take the car back to whoever did the work for you with a printout of Dave Z's procedure and ask them to do it again. I have always been happy with the performance of stock BMW M brakes, they don't have the rock hard pedal of most good multi piston calipers but they slow the car down well with a good pad installed.
Regards
Jamie Howton
2006 M Roadster Interlagos Blue
2004 645Ci, Stratus Grey
1995 M3 Arctic Silver
I can tell you that the M5 is pretty mushy even when done right compared to some other cars. After I put SS lines in my M Roadster, the brakes felt SOOOO connected compared to the M5's and my M5 has SS lines, too.
Need4Spd
Is it a problem with the size of the master cylinder?
It's the relationship between the M5 master cylinder and the size of the caliper pistons. A proper bleed, stainless lines, and a high Cf pad like Axxis Ultimate can help. But it's not going to feel like a Porsche, or even an M3.
I'm working on a solution that might yield a very good pedal feel. That's all I can say for now. I hope to have an update within the next 3 or 4 weeks. I'll post photos and results when I've tested the solution on my car.
2001 540i 6-Speed
M5 3.15 Limited Slip Differential M5 Front Swaybar
Dinan Stage 3 Suspension
Dinan Front Strut Tower Brace
European Dash Conversion CDV Deleted (of course!)
Bluetooth, NAV-TV, DVD Player
2006 Chrysler 300C SRT8 w/StopTech ST-60 front/ST-40 rear BBK 2007 Corvette Z51 Coupe 6-Speed w/StopTech Trophy ST-60 front/ST-40 rear 2009 Honda Fit Sport w/NAV w/Acura Integra front calipers, StopTech floating rotors on order
This will be interesting to hear Dave. Just before i read your post, i was thinking "how about a difference MasterCylinder?"
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
Are you changing the rubber guide pin bushings with brass and SS guide pins? Does the M5 have this type of set up? I run this on my E30 M3 and the pedal is more firm and the pad wear is perfect with both Hawk HP+ and HT10's for the track. Very cost efective as well.
