Changing Old style to new style rear lights - BMW M5 Forum and M6 Forums
Old 18th March 2005, 00:21   #1
rigsby
Garage: M5 Carbon Black
Hi, I have a pre facelift e39 M5. I want to change the rear lights to the facelifted version with the strip lights. Can I just buy a set of second hand facelifted lights and bolt them on? One mechanic I spoke to said I could but would need to file a small amout off the mounting point, another said I would need a ballast pack for the rear lights? Has anyone out there done this?? will the wiring connectors fit the new lights???? Any advice welcome. Thanks in advance.
rigsby is offline   Reply With Quote
Old 18th March 2005, 00:37   #2
mottati
mottati's Avatar
Garage: '91 M5 AlpineWhite II 93 M5 3.8 Sterling Silber
Re: Changing Old style to new style rear lights
if you get a hella retrofit kit, there is some minor filing and drilling involved. The hella kit also includes the ballasts. If you try to go with OE bmw lamps, there is quite a bit more metal cutting involved to get them to fit, and yes you still need ballasts. I had put the hella kit on a previous 528, it was a pretty straightforward install.
mottati is offline   Reply With Quote
Old 18th March 2005, 09:43   #3
rigsby
Does anyone know where the best place to get the Hella retro fit kit from is??.....ie the cheapest!!!
rattle/knock noise from rear solved! Jacob Lee E39 M5 and E52 Z8 Discussion 4 14th April 2009 20:08
Rear Fog lights installed in 4 hours... MarkM5Lauderdale E39 M5 and E52 Z8 Discussion 1 4th February 2001 21:36
views on 2001 rear clear (white-out) facelift lights steveB E39 M5 and E52 Z8 Discussion 14 10th January 2001 03:23
Facefilft for rear lights (butt lift?) 1C00lVC E39 M5 and E52 Z8 Discussion 2 5th January 2001 18:27
Rear Fog lights Parkerfe E39 M5 and E52 Z8 Discussion 6 17th September 2000 20:11
