Engine Miss + SES = CPS? - Page 3 - BMW M5 Forum and M6 Forums
Old 17th March 2005, 15:41   #21
Greco
Greco's Avatar
Garage: 1998 E39 540 Biarritz Blue/Beige SPP
Re: Engine Miss + SES = CPS?
Don't know if its an issue with the S62, but M62 wear out the valve cover gaskets which can cause oil to leak into the spark plug chamber. I'd also check for oil on the plug or the end of the coil as well. I've had misfires due to oil in one of the chambers before.
- Bill
>> Just an E39 540i/6 Biarritz Blue <<
Greco is offline   Reply With Quote
Old 17th March 2005, 17:56   #22
gsfent
gsfent's Avatar
Garage: 01 M5 Black/caramel
Sales Feedback: (3)
Originally Posted by 2003 M5!!!
What is an exhaust CPS code? What part is being replaced?
My last code was exhaust efficiency . . . whatever that means I think I have had 3 on and off SESs in the last 2 years. I had a real problem before that -- once I had my x-pipe installed.
I recently had an exhaust efficiency code. Dealer says bad cat, to be replaced under warranty. The code is intermittant, (SES gone for the last 2 weeks until this morning). Might want to have the cats checked.
Old 17th March 2005, 18:02   #23
mottati
mottati's Avatar
Garage: '91 M5 AlpineWhite II 93 M5 3.8 Sterling Silber
This can be an issue on the s62 as well. I've had recent valve cover gaskets, but you never know. Replacing the plugs will of course let me make sure there's no oil in the recesses. I also had this happen on a previous e34 525.
mottati is offline   Reply With Quote
Old 18th March 2005, 05:21   #24
hudson
hudson's Avatar
Garage: 2000 M5 Anthracite/Black
Mike let us know what the problem was, if you find it.
Joe
hudson is offline   Reply With Quote
Old 18th March 2005, 07:41   #25
mottati
mottati's Avatar
Joe
The problem has not occured since the track event, where it happened twice, throwing a 'misfire with cylinder shutdown' code on two occasions. (the bmw gt1 computer shows the codes were set off at 4420 rpm, 74% load, 99C coolant temp, 99,642km, interesting data! and the fault occured once on cyl 8 and twice on cyl 1). They cleared the faults and said come back if it happens again! Day to day, the car is running just fine. I'm thinking i might put some new coils and plugs in, just for the heck of it, seems like a reasonable time for ignition solution plasma coils...
Old 31st March 2005, 08:13   #26
kjell
Garage: 1999 M5 Carbon black
As mentioned above, I have had some of the similar problems as you have. I have changed two CPS (bank 2), valve cover gaskets and plugs, still problems when cold and when driving it hard. The first couple of minutes after starting, it's running really rough. And it kind of hasitates when trying to drive it hard. Sometimes it goes into linkmode as well when pressing it hard in 2nd and 3rd gear.
That was until Yesterday. I ordered two MAFs from Pacific BMW in California for $253 ea (plus $130 UPS shipping!) and got them Yesterday. I installed them, no rough cold start and I finally have a BEAST!!
Thanks everyone on this board, most useful board I have ever used. Without it, I would have spent a lot of money at a BMW place and they would probably not have fixed it anyway (no MAF codes).
kjell is offline   Reply With Quote
Old 1st August 2005, 07:13   #27
mottati
mottati's Avatar
Bringing back this thread i started a few months ago. I replaced my plugs shortly after this incident with denso irridium plugs (hold on...) and ignition solutions plasma coils. I honestly notice no realy difference in performance with these mods, although my fuel economy did improve by 1.2mpg according to the obc.
I did a trackday at buttonwillow, no misses or issues, problem solved... but wait, it's not.
Last night, bedding in new pads and rotors, temp in the mid 70'sF. After my third slowdown, back in second, moderate acceleration, at around 4k rpm, misfire, ses light... ****. shut off, restart all is fine, and i drive the heck out of the car for the next 15 minutes, wot, 7k rpm, etc trying to get it to happen again, it doesn't. Peak reader says cyl 1 misfire.
I pulled the plugs today, looked carefully at the wiring, boots etc. All looked perfect. Because of the tales of horror and woe regarding non-oe plugs, i reinstalled a set of 5k mile old bmw/ngks, just for the heck of it. Interestingly, throttle responce seems a little sharper with the oe plugs, vs the irridiums.
Ok, the real reason i brought this back up was this other thread:
Engine problem
Read post number 8, by Pong. He had a misfire associated with brake pad bedding. My initial misfires at sears point were consistantly right after turn 7, a heavy braking hairpin...
What could cause a misfire after braking?
Old 1st August 2005, 08:01   #28
DavidS
DavidS's Avatar
Garage: 2000 M5 LeMans blue
Sales Feedback: (4)
You could very well be onto something here. How about if braking long and hard puts a bit of stress onto the fuel-supply system, so that a marginally working fuel pressure regulator after the braking does not supply full fuel pressure for a little while and this in turn causes the misfire.
I´d suggest to measure the fuel-pressure when idling, both with the vacuum hose connected and disconnected. When connected the fuel-pressure should be 5.0 bar and when disconnected 5.5 bar.
This is a low cost thing at any competent mechanic or dealer. You will not need a DIS or GT-1, just a fuel pressure gauge that fits BMW.
For good measure I would also check for any wiring that is loose from its cable-clamps, both in the engine compartment and under the car.
David
DavidS is offline   Reply With Quote
Old 1st August 2005, 08:05   #29
mottati
mottati's Avatar
thanks for the thoughts, David.
Old 1st August 2005, 19:07   #30
drallen
drallen's Avatar
Garage: M5 Jet Black
Engine problem
Mike,
That is so ironic....The exact same thing happened to me as I was bedding in my new Stoptechs....
I even called Bill at D/A in a panic...That was three months ago...I like you have beat the heck out of the motor (and the brakes) with out any repeat of the earlier brake bedding incident...
Mark
Super Sprint Headers (coated), X Pipe and mufflers
UUC V12 Power clutch and flywheel
Evo III SSK with DSSR and tranny mounts
Shadowman Velocity stacks and software
Shadowman (Quaife) rear differential with changed static and dynamic lock up, stock (3:15) ratio
275's on front with a dinan rear bar and Beastpower brackets
Hard wired V1
Dual transponder Lidatek LE-30
Eurodash
Evosport Pulleys
Ground Control coil overs with adjustable camber plates
AA CAI, with AFE filters...the K&Ns ripped open
Relocated IATS
StopTech BBK on front, slotted rotors, with SS brake lines on all four corners
Jet Black 2002 M5
drallen is offline   Reply With Quote
M5 E39 Body Style S62 engine FACTS...Long V-10 4 Me E39 M5 and E52 Z8 Discussion 63 5th June 2012 22:00
Nowack Tuning Report, The Truth (Long Version) CharlesW E39 M5 and E52 Z8 Discussion 90 2nd September 2011 09:49
BMW M6 Press Release no 1: World Debut of the new BMW M6 (short version). Gustav E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 5 24th April 2010 20:07
SES Light - Engine Misfire! x703jko E39 M5 and E52 Z8 Discussion 24 8th March 2005 19:49
New M Engine Info greggb E63 BMW M6 Forum and BMW M6 Convertible | m6board.com 34 8th August 2004 17:17
