Old 5th March 2005, 19:19   #1
Ridgeback_Pilot
Ridgeback_Pilot's Avatar
Garage: 2000 Carbon Black/Caramel Dinan M5
Send a message via AIM to Ridgeback_Pilot
Resetting SES & Airbag Lights?
I'm concerned about resetting my SES and airbag lights with the Peake tools. The manuals say to make sure and correct whatever faults are present BEFORE resetting the lights. Does that mean the fault codes are erased once you reset the lights, never to return? If something is really wrong, wouldn't the fault codes recur and the lights come back on?
I recently resent my airbag warning light after retrofitting a new steering wheel to my '00 M5. Before I reset the light, the Peake tool displayed three fault codes:
11: Seat belt buckle switch, passenger
16: Sensor, side airbag, right, parameter fault
1A: Seat occupancy detector, passenger: Coding data
These codes would seem to indicate a problem (or problems) with the passenger airbag system. But ever since I reset the airbag light, it hasn't come on again. Does that mean the fault codes were a false alarm? Or does the system assume that I have corrected those faults if the light has been reset?
Thanks, Mike
1986 E24 635CSi "Shark"
2004 Volvo XC70
2000 Ford F150
1981 Cessna Turbo Centurion
2000 Dinan M5 Carbon Black/Caramel (Sold)
Ridgeback_Pilot is offline
Old 5th March 2005, 22:05   #2
Teutonaddict
Teutonaddict's Avatar
Garage: '00 Carbon Black/Black All-Leather/Sportive
Re: Resetting SES & Airbag Lights?
If the airbag system is anything like the DME, then if there is a real problem it will present itself again, and your SRS light will illuminate. No harm I can see in resetting your light.
I do not KNOW this to be true, but am extrapolating my experience in having SES codes reset. 90% of the time it was a one-time, unexplainable occurence, with no performance impact. Lesson learned at ~3K miles when my SES light went on, car went into limp mode, I pulled over and called the Roadside Assistance flatbed. Car gets to dealer, DME reads 'cylinder fault, Bank 1' and dealer says 'it reset itself after cycling the ignition. you can come pick it up now.' All that hassle, and the flatbed operator attempted to use huge meat hooks on suspension bits to tie down the car; no need to assume that kind of risk again!
So I gotta question for you, Mike. Do you own TWO Peake tools, one for SRS and one for SES?
My airbag light is illuminated at the moment, and the dealer told me it was the passenger seat sensor (without specifying which exact codes). Wanted something north of $600 to fix it. SA told me it wasn't absolutely necessary, as the default inoperable mode is airbag 'active'. I would NEVER allow one of my kids to ride up front, so I'm not concerned about the seat sensor not working.
As always, YMMV.
-Dave
BOTH SOLD!!
#101421
Teutonaddict is offline
Old 5th March 2005, 22:37   #3
hudson
hudson's Avatar
Garage: 2000 M5 Anthracite/Black
Mike I have a snapon scanner that I use to reset the air bag & SES lights after repairs. Being able to figure out which are the hard codes and which are the intermittent codes sometimes is a challenge. Some of the codes as Dave mentioned do recycle when you turn the ignition off and then back on again. If the problem is gone or intermittent the light will go out but it will leave a code in the control module. If the problem doesn't show up again in about 50 ignition cycles it will be erase from the memory of the control unit.
So you could see sometimes there is a stack of codes in the memory that are mostly intermittent. I always reset, any hard codes will come right back. The intermittent one's will be gone.
Hope this helps
Joe
hudson is offline
Old 6th March 2005, 07:55   #4
Ridgeback_Pilot
-Dave
Thanks, guys, for your advice. My SRS (airbag) light hasn't come on again since I reset it a couple of days ago. So perhaps the faults that I read were old ones. We'll see!
Yes, I own two Peake tools. You need the R5/FCXII to read the SES fault codes and reset the SES light and the oil service lights. You need the R5 SRS tool to read the SRS codes and reset that light. One wonders why they couldn't combine those features into a single tool, since the tools are of identical size and plug into the same receptacle!
2004 Volvo XC70
2000 Ford F150
Old 6th March 2005, 15:38   #5
jjc1843
jjc1843's Avatar
Garage: 2000 M5 Carbon Black
Send a message via AIM to jjc1843
Mike:
I believe it's intended audience is different. The SRS tool is aimed at body shops. The scan tool at mechanics.
Joe
'00 E39 S62 ///M5 Carbon Black/Caramel
AA CAI
UFM IATS Relocation Kit
SuperSprint Headers
Bassani Racing Cats-Custom Tubing
Tubi Cat Back System
Powerchip 93
UUC Lightweight Flywheel
UUC Stage III Clutch
Rogue Engineering Tranny Mounts
3.45 Diff KMS Ring & Pinion Swap
TC Designs Rear Swaybar Brackets
Royal Purple Syncromax Tranny Fluid
UUC SSK
UUC DSSR
'95 525i Black/Parchment 195K Eibach/Billstien/Power Chip [Sold!!!!]
jjc1843 is offline
anyone around Redwood City that can read SES lights and nothing to do on Sat? jkarp E39 M5 and E52 Z8 Discussion 1 31st October 2004 19:19
Z8s also have the SES blues... si-valleyman E39 M5 and E52 Z8 Discussion 0 17th April 2003 09:43
How many SES Lights you get in a week? RAREM5 E39 M5 and E52 Z8 Discussion 8 24th October 2002 20:00
Please Help! New Celis head lights will not...... POWER5 E39 M5 and E52 Z8 Discussion 1 20th May 2001 16:28
LED based tail lights - Obsrvations.. 1C00lVC E39 M5 and E52 Z8 Discussion 13 9th January 2001 05:21
Page generated in 0.12903 seconds with 11 queries
