Old 2nd March 2005, 16:12   #1
M5BHP
M5BHP's Avatar
Garage: Carbon Black BMW E39 M5
What exactly are the MAF's?
I hear ppl talking about them but I haven't got a clue what they are.
2000 E39 M5 Carbon Black / Imola Red (SOLD, engine failure!)
2005 Mitsubishi Lancer EVO 8 MR FQ-400 (SOLD, complete nightmare in everyday use!)
2000 TVR Tuscan S 4.0l (SOLD, unreliable)
1999 BMW 323i Coupe (gave to the missus)
2001 Porsche 911 GT2 (993 mwah!)
M5BHP is offline
Old 2nd March 2005, 16:32   #2
DIPLOMAT
DIPLOMAT's Avatar
Garage: M5 Silver
Re: What exactly are the MAF's?
Mass Air Flow Sensors, they basically calculate the amount of air coming into the engine to accurately match the amount of gas. if you pop open your hood you will see a plug on each intake and those are your MAFs
DIPLOMAT is offline
Old 2nd March 2005, 16:58   #3
M5BHP
M5BHP's Avatar
thanks
M5BHP is offline
Old 3rd March 2005, 00:15   #4
Carrera2RS
Garage: M5
Mass air flow sensors measures the mass of air coming into the engine via a hot air film system or flap valve (not sure on the M5, I suspect a hot air film basis)
The engine management system then looks at the rpm and delivers the appropriate amount of fuel, via a programmed map. The advantages of mapping an engine (setting the fuelling) via these inputs is that the MAF sensor is self regulating to a degree - If the air is hot, the mass is less therefore less fuel, if the air pressure is less the mass is less therefore less fuel, etc
Race engines are mapped via throttle position and rpm with adjustments for air temp and pressure, this is much more responsive but not as emission friendly !
Carrera 2RS
Carrera2RS is offline
Old 3rd March 2005, 00:32   #5
de Witt
de Witt's Avatar
Garage: 1988 M5 (x2) 1991 M5 2008 M5
Send a message via AIM to de Witt
I would be hesitant to call the MAF self-regulating. It takes instantanous measurements of air mass and sends a signal to the computer based upon the voltage resistance measured at the wire. The MAF does not deliver feedback to regulate itself, the computer does all of the regulating work. The MAF cannot sense conditions that you describe, but it does send a signal to the computer that will regulate the injector pulse width. The MAF wont change anything to itself, but it will change the pulse width.
{o,o}
|)__)
The E28 M5 FAQ
The E34 M5 FAQ
The E24 M6/M635CSi FAQ
de Witt is offline
Cleaned My MAFS - The Beast Is Back / Torx Avail. at Sears Wrightsville Beast E39 M5 and E52 Z8 Discussion 11 21st November 2004 17:57
I'd like your opinion(s) and answer to my question, re: MAF's & Headers.... FAST 5 E39 M5 and E52 Z8 Discussion 10 11th July 2004 12:33
TECH: MAFS replacement question... BlueBomber E39 M5 and E52 Z8 Discussion 8 5th July 2004 21:30
What other staff can be used to clean the MAFS m5 rus E39 M5 and E52 Z8 Discussion 8 18th May 2004 08:32
E39 M5 MAFs pvapour For Sale or Wanted 2 15th March 2004 16:51
Page generated in 0.26153 seconds with 11 queries
