Old 26th June 2000, 21:59   #1
Jean-Christophe
Radio and Service Modification menu
Radio Service Mode
For pulling out a nice Service Menu out of the Radio, do the following:
Switch the radio on
Push "TP" for at least 10 seconds
A "Service Menu" will appear. You will be informed about
Serial Number
SW Version (mine is from 15/94)
Seek Level ("I" for reception of strong radio transmitters, "II" for reception of all radio stations)
GAL (Geschwindigkeits Abhaengige Lautstaerkeregelung - speed dependent volume control). Set it to 1 for small volume increase when driving faster, and set it to 4 for even more volume when driving faster. Mine is set to "1" and still too much).
DSP (If your car is equipped with the HiFi Professional DSP, you will find an "1" here. Otherwise a "0" (like mine).
FM (some information about the radio station you are currently listening to. Includes also quality of reception.)
To get back from this menu, simply switch off the radio.
Service Mode Menu
If you have a MK2 Nav System (female voice), you can bring up a Service Mode Menu as following:
Set ignition to pos. II
go to "settings"
push the MENU button for at least 20 seconds
The service menu has some TV options, GPS Data and telematik.
Bye
Jean-Christophe is offline
Old 27th June 2000, 17:03   #2
dave
dave's Avatar
Garage: 2005 Alpine White 645i Coupe
Post
the us version does'nt have a "TP" button.
dave is offline
Old 29th June 2000, 07:10   #3
BrianC
BrianC's Avatar
Garage: E39 M5 Avus Blue
Post
Dave, it's not that my German is any better than yours, but through the brute force method, I found out that the TP button actually got translated into our RDS button.
And you can even pull this menu up while driving. However, our list of options seems difference than what Jean-Christophe has listed.
Jean-Christophe, can you please enlighten me on how to activate the Navigation Service menu?
I tried the ignition Pos II method and it only worked intermitently. I must have done something wrong most of the time and only get it right some of the time.
When I enter the car, put the key into position 0. Turn the key to Pos II and once the Code function is dimmed, I started pressing and holding the MENU button. Only some of the time the menu shows up. Did I do something wrong in the sequence?
BrianC is offline
Old 29th June 2000, 23:13   #4
Jean-Christophe
Taken from this page; http://home.t-online.de/home/
tom.martens/repair.htm
You will find more specifications on this site
Best regards
Old 1st July 2000, 19:22   #5
MarkM5Lauderdale
MarkM5Lauderdale's Avatar
Garage: 2002 Mini Cooper S
Great info!
Mark
MarkM5Lauderdale is offline
Figured out 2002 Service Menu 2002m5BGM E39 M5 and E52 Z8 Discussion 8 8th November 2001 19:32
readio service mode for 2001 burkey E39 M5 and E52 Z8 Discussion 9 17th August 2001 06:04
After 1200 mile service Trax E39 M5 and E52 Z8 Discussion 1 17th February 2001 06:50
Radio Service Mode dave E39 M5 and E52 Z8 Discussion 3 2nd October 2000 01:25
Page generated in 0.18532 seconds with 11 queries
