Thinking of spacing the front wheels out ? - BMW M5 Forum and M6 Forums
Old 27th February 2005, 10:34   #1
Carrera2RS
Garage: M5
I have looked around for some rears to fit on the front and do what a lot of other members have done and run 9.5 x 18all round.
I am considering increasing the front track as there is plenty of clearance and it will hopefully increase the front track, add a little weight to the steering and dial out any mild understeer. Plus look more agressive.
Doing the maths I think I could run 15mm spacers or possibly 20mm at the front. Anyone done this ? I have heard of people running 10mm at the front. I would love to see some piccies as I wouldn't want it to look too 'boy racer'.
Anyone run spacers at the back ?
It might be possible to run 3mm back and 15mm front or even 20mm front and 10mm back ?
Any suggestions ?
Carrera 2RS
Carrera2RS is offline   Reply With Quote
Old 27th February 2005, 12:32   #2
Ahmed
Ahmed's Avatar
Garage: Black C63 AMG P31
Sales Feedback: (4)
Re: Thinking of spacing the front wheels out ?
When I bought my M5, the first thing I noticed was how inward the front wheels were. I had a 2000 model MB CLK and I loved how my 18 inch wheels were inline with the front fender edges!!!! Something that the M5 didnt have! But I am sure the folks at ///M knew what they were doing when they built this car ( stability wise and handling characteristics)
Anyways, the first thing I did was order a pair of 10mm spacers fro Rogue Engineering and this was the result! I like it, good enough for me!
2006 E60 M5 Sepang Bronze/Natural Brown/Olive Ash (RIP)
2013 C63 AMG P31 Magnetite Black/Classic Red & Black/Carbon Fibre
Ahmed is offline   Reply With Quote
Old 27th February 2005, 12:38   #3
Ahmed
Ahmed's Avatar
Sales Feedback: (4)
And in case you're wondering how it would look with slightly lowered suspension?
Here you go!
Old 27th February 2005, 12:43   #4
Ahmed
Ahmed's Avatar
Sales Feedback: (4)
OK I just noticed something!
The two pics look almost the same! I mean, the first one is when I had stock shocks on, and the second one is when I installed the Hamann's!
They look almost identical!!!
Sorry, i dont wanna turn this thread into "Ahmed showin off his M5" thread... but I just feel the need to justify this through another visual representation!!!!!
Now lets seee.... this should do it!
Old 27th February 2005, 12:48   #5
Carrera2RS
Garage: M5
Ahmed,
Thanks heaps, I love the CAI grill as well, it looks way better with an extra 10mm, Im assuming it has no clearance issues ?
Would you try 15mm spacers or stick with 10's ?
Old 27th February 2005, 13:09   #6
Ahmed
Ahmed's Avatar
Sales Feedback: (4)
The more you space out your front tires, the more wear you will get on the inside of those tires!!! Thats the problem I'm having right now!
Old 27th February 2005, 13:27   #7
Carrera2RS
Garage: M5
OK, tks !
Old 27th February 2005, 13:50   #8
M500PMW
M500PMW's Avatar
Garage: E39 M5 2000 MY Avus Blau
I am thinking of doing this mod aswell, I may have got the wrong end of the stick but from what I have read: Fitment of OEM rear wheels to the front can only be done if wheel correctly spaced AND to alleviate tyre scrub camber correction top mounts fitted (available from Dinan). 275's all round?
Any board members that have this setup or similar? Comments welcomed, I don't want to get it all wrong!
Best Regards
Peter.
M500PMW is offline   Reply With Quote
Old 27th February 2005, 15:11   #9
gsfent
gsfent's Avatar
Garage: 01 M5 Black/caramel
Sales Feedback: (3)
Best Regards
Peter.
In order to keep the proper alignment, you need 3mm spacers in the front with 18x9.5 rears. I think Lscman or RRoberts has addressed this in another post. If you change the geometry by using the wrong size spacers, you will affect stability (at least at higher speeds), including more tramlining (the car tends to wander and pull from side to side over small road imperfections instead of going straight). The BMW engineers are pretty good at what they do, so while acknowledging most things are a compromise, I wouldn't make radical changes from the stock setup unless you or someone working with you really knows what they are doing. A couple of mm for appearance may not have a big effect, just monitor what you do. 3mm is relatively small, but 10mm is about a 1/4 inch, which is pretty big for wheel offset IMHO. BTW, I have a spare set of 18x9.5's and 3mm spacers to put them on front, but my car handles so well on the street with Dinan 3 suspension and stock wheels, I don't see the need.
Old 27th February 2005, 15:43   #10
Carrera2RS
Garage: M5
Ahmed,
How does the car handle in comparison ? Weightier steering and more sensitive ?
Not sure why the inner tyres should wear more, anyone make suggestions ?
Anybody Run 18 Inch front and 19" rear wheels? Jayson E39 M5 and E52 Z8 Discussion 1 26th February 2005 06:51
I need two front wheels! CM5GO E39 M5 and E52 Z8 Discussion 1 5th December 2002 02:35
I'm thinking of painting the inside of my front lights. Fury E39 M5 and E52 Z8 Discussion 11 9th May 2001 10:28
Alpina Softline or Flatline wheels? Danish ALPINABoard.com | BMW Alpina Discussion 5 19th March 2001 11:14
