Old 21st February 2005, 01:10   #1
M5_in_MD
M5_in_MD's Avatar
Garage: Carbon Blk 2000 M5
How many of you have used the M-mobility kit?
Folks,
We had a recent previous thread that discussed several options for a spare. Daniel of Beastpower indicated he'd looked into designing a lightweight space-saver spare for M5 owners, but never took it to completion. Consensus seemed to be that getting a snow tire or other full-size tire was the only way to go.
That all said, I'd like to get a survey of folks who've used the M-mobility inflate-a-tire system that comes with the car. I've never been very impressed with it, and would like to find out how many have used it, and how well did it work.
Cheers,
Rich
2000 M5
Carbon Black/Caramel
S/S brake lines w/ Motul fluid
UUC Ultimate Clutch
UUC Short Shifter kit
V1 Radar Warning Rcvr
M5_in_MD is offline
Old 21st February 2005, 01:19   #2
Ashok Arora
Ashok Arora's Avatar
Re: How many of you have used the M-mobility kit?
I've had a couple of punctures in my time. I was very reluctant to use the expanding foam in the M-Blow-Me system as it means paying for a new tyre and a new mobility kit (at something like £150!!). Since they were slow punctures I simply used the pump to inflate the tyre until I could drive to a tyre shop for a repair.
Ashok
Let me tell you what SMG stands for...
Ashok Arora is offline
Old 21st February 2005, 01:54   #3
KevinM
KevinM's Avatar
Garage: 2002 E39 M5, Sterling Gray/Caramel
I've never used it, but wonder when the sealant needs to be replaced...mine is now 3 years old.
Kevin
2007 M Coupe, Silver/Black
KevinM is offline
Old 21st February 2005, 02:07   #4
mr_bock
mr_bock's Avatar
Garage: 2002 M5, Sterling Gray
Never used it either.... I carry a full size front tire/rim that can be used on any corner. I used that once and it was quick and easy.
2002 Sterling Gray, Black and Aluminum interior
UUC Short Shifter & DSSR
UUC Clutch Stop
UUC Transmission Supports
UUC UltraSmooth CeraMetallic Clutch/LWF
Active Autowerks Cold Ram Air Intake - Modified
Air Plenum Heat Shield, 1700 degree black Jet-Hot coating
Alpine amp for JL Audio Sub Woofers
UFMotorsport S62 Intake Air Temp Sensor Relocation
Dinan Stage II Suspension
Dinan 3.45 Rear Diff. Gear Set
Dual JL Audio 10" Sub Woofers
K40/Laser Defuserplus, hidden install
K-Mac Adjustable Caster/Camber Plates
Kelleners Aluminum Sport Pedals & Foot Rest
MB Quart speaker replacement
NAV MKIV DVD
StopTech SS Brakelines
Axxis Ultimate Brake Pads
EvoSport Performance Underdrive Pulley Set
TubiStyle Cat-Back Exhaust
Power Chip 93 Gold - Modified & Sport 'On'
Perma-Cool Electric Engine Fan (no mechanical fan!)
Michelin Pilot Sport II Tires (front/rear stock sizes)
Royal Purple Synchromax Transmission Oil
Red Line 75W90 Differential Gear Oil
Sirius Radio receiver
SS Headers, EVO High Flow CATS
Zionsville Aluminum Radiator w/ Dual Speed Fan
My latest toy... a 2001 360 Modena Ferrari
My 'other' car is a supercharged 1996 911 C2 993
mr_bock is offline
Old 21st February 2005, 02:22   #5
Ashok Arora
You will find a label with the expiry date attached to the canister.
Ashok
Old 21st February 2005, 02:48   #6
Beamer_usa
Beamer_usa's Avatar
Garage: explosive ford pinto
There is an expiration date on the cannister, also a good rule of thumb is changing the cannister approx. every three years.
Beamer_usa is offline
Old 21st February 2005, 02:52   #7
Beamer_usa
Beamer_usa's Avatar
How do you anchor the tire and jack in the trunk, cargonet? Velcro?
Old 21st February 2005, 03:45   #8
Stem
Garage: 2000 M-5 Royal Red/Caramel
Used it but it was ineffective as the hole in the tire was too big. Had a second tire rupure after hitting a pot hole and drove it to a parking lot and just replaced the tire. The juice would not have worked on this one either. a
A spare would have saved me in both cases. Had to have the car towed on the first one!
Stem is offline
Old 21st February 2005, 03:59   #9
khiroshima
khiroshima's Avatar
Garage: 2001 M5 silver
I had successful results with a fully flat tire after taking on a nail. I was reluctant at first to use the kit, but it was more than capable to refill my tire, plug the hole and get me to a nearby Wheel Works. Sure, it's not the most elegant solution, especially for the tire guy, but I ended up only having slightly dirty fingers. Again, not my favorite, but in this instance, effective.
YMMV, Kevin
khiroshima is offline
Old 21st February 2005, 05:10   #10
Gorilla Beast
Guest
Gorilla Beast's Avatar
Garage: E39 M5 Silverstone
Send a message via AIM to Gorilla Beast
I used Fix a Flat, worked fine. I may be wrong, but I think the system BMW provides is just a more expensive version of fix a flat, same concept. I have not priced how much to recharge the kit if empty or expired, I am sure its not as cheap.
Gorilla Beast is offline
StopTech front kit on sale for $2095 ($500 off) for the next 24 hours DZeckhausen M5 E39 Group Buy Forum and Sponsor Discussion and Offerings 0 2nd January 2005 00:03
new brembo 380mm kit tfung E39 M5 and E52 Z8 Discussion 13 9th August 2003 03:00
StopTech E39 4-Wheel brake kit details DZeckhausen E39 M5 and E52 Z8 Discussion 26 20th March 2003 07:11
TECH: "M" blow me kit VanCooper E39 M5 and E52 Z8 Discussion 25 12th May 2002 21:30
470HP kit and 500HP kit due soon! Quad_exhaust E39 M5 and E52 Z8 Discussion 32 24th March 2002 00:55
Page generated in 0.14112 seconds with 11 queries
