Re: Quick fog light removal question
If you're talking about just the black cover, it's held in place by a few clips. You might have to pull harder than you think.
Don't worry, it shouldn't break. Mine took alot of force to get off as well, and it was a pain, but once you get the right feel for it, taking off the cover should be much easier. Then just use an 8mm socket wrench to remove the screw holding the actual housing in place and it just slides out easily.
