Old 12th February 2005, 19:46   #1
BRN64666
BRN64666's Avatar
Garage: BMW M5 E39
M5 on a Drag strip
Hi guys and Girls
Last Thursday on 10th Feb. 2005 I joined a test and tune to check my M5 on a drag strip.
I was kind of upset with my time coz I couldn’t hit my target because a stock M5 suppose to run in mid 13s
With my modification on the car I couldn’t even run that time …….. God Help Me
Unfortunately I ran 13.76 @ 171 KM which I’m not happy with
I’m planning to buy new slicks tries + using the racing gas
And I hope to run high 12s ….
BRN64666 is offline
Old 12th February 2005, 20:27   #2
Tin
Tin's Avatar
Garage: M5 - Avus Blue
Re: M5 on a Drag strip
Originally Posted by BRN64666
Hi guys and Girls
hmm.. I'll be doing this hopefully next week, have similar mods to you, what rpm where you launching at? where you using normal road tyres?
some tips here in my earlier thread on the topic
Kelleners ECU remap, Kelleners uprated Sport Camshafts, Kelleners Custom 3.45 Rear Diff, ACS DFC Suspension, 19" ACS TypeIII's, Brembo GT Kit (F:8pot/380mm front,R:4pot/345mm), Supersprint RHD headers,100cel sport cats,x-pipe and 90mm backboxes, ACS Rear Diffuser, Evosport lightweight pullies, Dinan Front & Rear Strut Bars, Dinan Rear SwayBar,ACS pedals & handbrake, GruppeM induction kit, AA CAI,IgnitionSolution PlasmaCoils, Rouge SSK with weighted rod, BeastPower brackets, NAV-Tv, MKIV Widescreen retrofit,2x10" M-Audio Subs, Hardwired V1,Xenon interior lights
Tin is offline
Old 12th February 2005, 20:44   #3
BRN64666
BRN64666's Avatar
Garage: BMW M5 E39
Yes I was runing on a street tyres and launching at 1200 RPMs
If I lunch it more than that it will wheel hops alot + wheel spins
+ I forgot to switch the power botton ON
BRN64666 is offline
Old 12th February 2005, 20:46   #4
greg
greg's Avatar
Garage: 2000 Anthracite
To get the factory/magazine test numbers you'll need:
1) an engine running properly, of course
2) minimum 93 octane fuel and enough time for the engine computer to have adapted to it
3) favorable temperature, humidity and atmospheric pressure
4) cool engine (see all the previous articles about heat soak - not an issue for steady-state driving like road course but a big power robber in the first few minutes of operation after sitting with a warm engine)
and finally
5) a lot of practice - there is a very fine line between not enough and too much clutch slip - and even the "right" amount is practically guaranteed to ruin a stock M5 clutch in fairly short order. A couple of "wrong" amounts, where you have engine power on full before the clutch is locked up, your clutch will be toast.
Good luck!
greg is offline
Old 12th February 2005, 20:48   #5
BRN64666
BRN64666's Avatar
Garage: BMW M5 E39
Thanks for the tips ..........I missed that
BRN64666 is offline
Old 12th February 2005, 22:03   #6
boostmiser
boostmiser's Avatar
Garage: 2002 Alpine White M5
What was your 60 ft. time? That will tell you a lot. What was your tire pressure? Generally you lower the rear and increase the front. I'd bet the heat played a factor as well. From what I've read on the board, the exhaust is not good for any gains. So that leaves the ecu as the only hp gain you have.
The Upgrades: Dinan Stg. 1 / Dinan RSB / TCD Sway Bar Brackets / UUC Evo III SSK / UUC DSSR / UUC Tranny mounts / MKIV Nav Unit / JL 500.1 Amp / JL 12w6v2 Sub
boostmiser is offline
Old 12th February 2005, 22:20   #7
warhaven
warhaven's Avatar
Garage: 2002 M5 Jet Black
Indeed. this plus check you reaction time numbers. You'll be absolutely amazed how a 10th of a second in reaction time gets magnified downsteam. it's almost like compounding interest. I am sure some smart person has a formula but by nailing the reaction time/ stock tires/ cool engine/ 20lbs pressure in rear tires i did 12.97 1/4 mile
Warhaven's 2002 Dinan S2 M5
11/22/04 Dyno: 336.2RHP/329.2T (Exhaust only)
03/15/05 Dyno: 334.38HP/326.24T (+CAI)
06/22/06 Dyno: 348.76HP/331.33T (+ MAF)
Jet Black/Black
Super Sprint X-pipe
AA Front Grill
TC Racing Pedals
TCD Sway bar brackets
MK4 V28.1 NAV upgrade
Zenon 8000K Stage II upgrade
warhaven is offline
Old 12th February 2005, 22:26   #8
boostmiser
boostmiser's Avatar
Reaction time has no correlation to the outcome of your 1/4 mile time. It only matters if you are racing another vehicle to the finish line. Then it gets magnified towards the end.
Old 12th February 2005, 22:43   #9
warhaven
warhaven's Avatar
Awesome... didn't think about that. It makes sense. But then again I was more worried about beating the vette next to me than my own 1/4 mile time.
Jet Black/Black
Super Sprint X-pipe
AA Front Grill
TC Racing Pedals
warhaven is offline
Old 12th February 2005, 22:51   #10
BRN64666
BRN64666's Avatar
Garage: BMW M5 E39
here are the information which you asked me ..
R/T .973
60' 2.261
330 6.063
1/8 9.106
KMH 133.36
1000 11.650
1/4 13.768
KMH 171.66
Tep. +11 C
For the tire pressure was 35 PSI on street stires ...
BRN64666 is offline
All BMW M5 E60 Press Releases + Official Pictures Gustav E60 M5 and E61 M5 Touring Discussion 73 20th July 2004 02:04
Big News: Official M5 E60 pics! Anymore coming with us to Geneva? Gustav E39 M5 and E52 Z8 Discussion 55 3rd March 2004 15:24
Your thoughts on the Z8 NO-MERCY E39 M5 and E52 Z8 Discussion 6 16th November 2001 06:26
Page generated in 0.27223 seconds with 12 queries
