Old 12th February 2005, 22:52   #11
BRN64666
BRN64666's Avatar
Garage: BMW M5 E39
Re: M5 on a Drag strip
Originally Posted by boostmiser
Reaction time has no correlation to the outcome of your 1/4 mile time. It only matters if you are racing another vehicle to the finish line. Then it gets magnified towards the end.
That's True
BRN64666 is offline
Old 12th February 2005, 23:08   #12
BRN64666
BRN64666's Avatar
Garage: BMW M5 E39
More Details
Tires Condition: Need to be replace
Gas : Pump Gas 89
Engine Tep. : Warm
Sound System : Removed
what else ??!!
BRN64666 is offline
Old 12th February 2005, 23:12   #13
mottati
mottati's Avatar
Garage: '91 M5 AlpineWhite II
89 octane! is that calculated the same way as it is here in the US (R+M/2)? If so, that could be part of the problem. If the tires were really worn out, that could also cause some loss of grip off the line. Bald street tires are not like slicks!
Originally Posted by BRN64666
More Details
Gas : Pump Gas 89
Engine Tep. : Warm
what else ??!!
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 12th February 2005, 23:30   #14
Black M5
Black M5's Avatar
Garage: Black M5
BRN,
Get some freash tires and powerchip ECU upgrade add race fuels and lets see some high 12's
Im not convinced that Digi-Tech ECU Upgrade is giving you the HP gain you should get from all your mods
Black M5 is offline
Old 12th February 2005, 23:48   #15
boostmiser
boostmiser's Avatar
Garage: 2002 Alpine White M5
here are the information which you asked me ..
R/T .973
60' 2.261
330 6.063
1/8 9.106
KMH 133.36
1000 11.650
1/4 13.768
KMH 171.66
Tep. +11 C
For the tire pressure was 35 PSI on street stires ...
11C = 52F...that's perfect.
The 2.261 tells me that you did not get a great launch. You should probably be in the 1.9 range. Every 1/10th in 60' time translates to aprox. ... oh, from memory.... 2/10th's in the 1/4 mile...maybe more, I foget exactly. Lets use 2/10th with a 1.9 60' time. That eliminates 6/10th's putting you right in the low 13 second range where you should be.
171.66 kmh = 106.66 mph which is low. You should be at least in the 108 range (and that's stock). So, your shifts were probably not optimal and/or the gas you are using is too low octane. Again, not sure what your gas equates to but I'm sure your chip is optimized for high octane. The chip doesnt seem to be helping you too much.
OHHH...and your wheels. I just noticed you had 19's. You'll loose speed from them. First, they may be heavier than stock. If so, that's and increase in rotating mass. Also the 19" diameter will give you a bit more top end but hurt your sprints. That may be a 1/10th or 2/10th difference.
The Upgrades: Dinan Stg. 1 / Dinan RSB / TCD Sway Bar Brackets / UUC Evo III SSK / UUC DSSR / UUC Tranny mounts / MKIV Nav Unit / JL 500.1 Amp / JL 12w6v2 Sub
boostmiser is offline
Old 12th February 2005, 23:58   #16
BRN64666
BRN64666's Avatar
Garage: BMW M5 E39
You are right .... My ECU upgrade optimized for 99 octane and I was runinng on 89 which is really low octeans .....
for the wheels .... I was testing the car with stock wheels ...not with 19s
BRN64666 is offline
Old 13th February 2005, 00:01   #17
BRN64666
BRN64666's Avatar
Garage: BMW M5 E39
Originally Posted by Black M5
BRN,
I will change my tires and I will add race fuels ...... and we will see the results .....
BRN64666 is offline
Old 13th February 2005, 02:33   #18
phillym5
Garage: 01 Area 51 M5 Le mans.
One more thing too,
You got to have the revs higher..like 2000-2500.
Problem is you got to slip the clutch almost all of first. atleats a bit to really get a low 60'. Where is ELEVENS... He is the "drag master" in the M5.
Make sure those shifts have no delays. Fast shifts are real important.
good luck.
josh.
12.7@ 110mph
phillym5 is offline
Old 13th February 2005, 07:13   #19
Black M5
Black M5's Avatar
Garage: Black M5
and sort out the ecu too please
Black M5 is offline
Old 13th February 2005, 11:57   #20
Ahmed
Ahmed's Avatar
Garage: Ex- E39 M5
Here's BRN64666 in action!
2006 Sepang Bronze/Naturelle Brown E60 M5
Eisenmann Sport Mufflers
Miesterchaft Sections 1 & 2
Evosport Headers
Evosport Pulley
RPi RAM Scoops + Block Off Plates + BMC Filters
AL-Tuning Software
Eibach ProKit Springs
20" Breyton Race CS with Yokos
White Angel Eyes, 6000K HID's & LED Plate Lamps
ACS Roof Spoiler
Ahmed is offline
All BMW M5 E60 Press Releases + Official Pictures Gustav E60 M5 and E61 M5 Touring Discussion 73 20th July 2004 02:04
Big News: Official M5 E60 pics! Anymore coming with us to Geneva? Gustav E39 M5 and E52 Z8 Discussion 55 3rd March 2004 15:24
Your thoughts on the Z8 NO-MERCY E39 M5 and E52 Z8 Discussion 6 16th November 2001 06:26
Page generated in 0.17760 seconds with 12 queries
