Old 12th February 2005, 12:48   #1
Amir M5
Amir M5's Avatar
Garage: 2000 Metallic Anthracite M5
00 to 01+ Steering Wheel upragde & Euro Dash conversion pics
I finally got around to completing this.
First I wanted to thank all the great people here that shared their knowledge.
Here are some links I used for more information and help:
http://www.zeckhausen.com/Eurodash.htm
http://www.e39garage.com/eurodash.htm
http://www.bmwtips.com/tipsntricks/S...eringwheel.htm
http://www.x5world.com/m_wheel_retrofit.htm
The uprgade of the steering wheel from 00 to 01+ was pretty straightforward:
-Turne key to acc to be able to move steering wheel, then turn off
-Disconnect battery
-Loosen two torx screws behind wheel to remove airbag, disconnect airbag
-Use 16mm socket with extension to remove bolt in the center of the steering wheel
-Remove steering wheel
-Place new steering wheel on (there is a mark on the steering wheel and steering column that helps line it up perfectly)
-Tighten the 16mm bolt, using a Torque wrench set to 80 Nm (59 Ft-Lbs).
-Finally, pop the new air bag in and you're all done.
I worked on converting to the Euro Dash while I had the old steering wheel removed so I could work easier around that area. I followed the procedures listed on e39garage.com and it was not too difficult. If you're planning on doing this, make sure when you're cutting the metal to make sure it is cut enough for the new storage bin to fit.
Here are some before and after shots:
BEFORE
AFTER
-Amir
Amir M5 is offline
Old 12th February 2005, 13:25   #2
Tin
Tin's Avatar
Garage: M5 - Avus Blue
Re: 00 to 01+ Steering Wheel upragde & Euro Dash conversion pics
ah, cool, nice one Amir, looking good!
Could I ask where you got the cf trim?
Kelleners ECU remap, Kelleners uprated Sport Camshafts, Kelleners Custom 3.45 Rear Diff, ACS DFC Suspension, 19" ACS TypeIII's, Brembo GT Kit (F:8pot/380mm front,R:4pot/345mm), Supersprint RHD headers,100cel sport cats,x-pipe and 90mm backboxes, ACS Rear Diffuser, Evosport lightweight pullies, Dinan Front & Rear Strut Bars, Dinan Rear SwayBar,ACS pedals & handbrake, GruppeM induction kit, AA CAI,IgnitionSolution PlasmaCoils, Rouge SSK with weighted rod, BeastPower brackets, NAV-Tv, MKIV Widescreen retrofit,2x10" M-Audio Subs, Hardwired V1,Xenon interior lights
Tin is offline
Old 12th February 2005, 13:53   #3
Ahmed
Ahmed's Avatar
Garage: Sepang Bronze E60 M5
Sales Feedback: (3)
Looks like AC Schnietzer to me!
2006 Sepang Bronze/Naturelle Brown E60 M5
Eisenmann Sport Mufflers
Miesterchaft Sections 1 & 2
Evosport Headers
Evosport Pulley
RPi RAM Scoops + Block Off Plates + BMC Filters
CA Auto/AL-Tuning Custom Stage 2 DME Upgrade
Eibach ProKit Springs
20" Breyton Race CS with Yokos
White Angel Eyes, 6000K HID's & LED Plate Lamps
ACS Roof Spoiler
Matte Black Kidney and Fender Grills
StopTech BBK 6 Piston Front & 4 Piston Rear
Ahmed is offline
Old 12th February 2005, 18:33   #4
warhaven
warhaven's Avatar
Garage: 2002 M5 Jet Black
Awesome upgrade. I would hav never believed that it was that different. Now I am going to have to check mine out.
Sweet.
Warhaven's 2002 Dinan S2 M5
11/22/04 Dyno: 336.2RHP/329.2T (Exhaust only)
03/15/05 Dyno: 334.38HP/326.24T (+CAI)
06/22/06 Dyno: 348.76HP/331.33T (+ MAF)
Jet Black/Black
Super Sprint X-pipe
AA Front Grill
TC Racing Pedals
TCD Sway bar brackets
MK4 V28.1 NAV upgrade
Zenon 8000K Stage II upgrade
warhaven is offline
Old 12th February 2005, 18:46   #5
mottati
mottati's Avatar
Garage: '91 M5 AlpineWhite II
great pics. more and more temptation to do the steering wheel. I also love the euro dash, i did that about a year ago with the wide screen nav as well. Nice CF trim..
08 535i / 6 speed
Engine:
Suspension:
Interior/Misc:
mottati is offline
Old 12th February 2005, 18:52   #6
Gustav
Administrator
Gustav's Avatar
The CF panels looks great! One of the most nicest Ive seen! Which company did the CF and what did they go for?
Gustav is offline
Old 12th February 2005, 21:54   #7
Amir M5
Amir M5's Avatar
Thanks Everyone.
The CF is made by AC Schnitzer and was around $2200.
Amir M5 is offline
Old 13th February 2005, 02:34   #8
watchme
watchme's Avatar
Garage: '00 M5 Titanium Silver, 1992 Mustang GT (Someone please take this thing off my hands!)
Amir...
Do you still have the titan line trim? If so, are you interested in selling it?
watchme is offline
Old 13th February 2005, 02:54   #9
Amir M5
Amir M5's Avatar
Originally Posted by watchme
Amir...
Actually I do, pm me and I can send you some pics if you like.
Amir M5 is offline
Old 13th February 2005, 08:04   #10
BeastPower
Guest
Very nice job!
The CF trim is available here.
Cheers, Daniel.
00 --> 01 Front Headlight Conversion Instructions brparker E39 M5 and E52 Z8 Discussion 14 17th November 2008 21:43
M5 00 vs 01 VinMan E39 M5 and E52 Z8 Discussion 14 15th July 2003 11:05
Need part number for steering wheel/airbag 01 M5 Alaris E39 M5 and E52 Z8 Discussion 1 29th May 2003 07:22
'00 steering wheel for '01 steering wheel?? steveB E39 M5 and E52 Z8 Discussion 14 17th April 2002 18:35
new airbag in 01 steering wheel? steveB E39 M5 and E52 Z8 Discussion 4 14th August 2001 21:02
Page generated in 0.15675 seconds with 11 queries
