Old 11th February 2005, 18:14   #1
Tin
Tin's Avatar
Garage: M5 - Avus Blue
Tips for 1/4 mile sprints?
Going to be hopefully doing some 1/4mile sprints in the beast next week, anyone have any tips? (take out all, but the bare essentials)?.
is there an optimum rev to launch the car? have experimented between 1000 and 1800 a few times, trying to minimise wheel spinning
Whats a realistic time for the M5? 12/12.5secs? or is that too optimistic?
Cheers
Tin
Kelleners ECU remap, Kelleners uprated Sport Camshafts, Kelleners Custom 3.45 Rear Diff, ACS DFC Suspension, 19" ACS TypeIII's, Brembo GT Kit (F:8pot/380mm front,R:4pot/345mm), Supersprint RHD headers,100cel sport cats,x-pipe and 90mm backboxes, ACS Rear Diffuser, Evosport lightweight pullies, Dinan Front & Rear Strut Bars, Dinan Rear SwayBar,ACS pedals & handbrake, GruppeM induction kit, AA CAI,IgnitionSolution PlasmaCoils, Rouge SSK with weighted rod, BeastPower brackets, NAV-Tv, MKIV Widescreen retrofit,2x10" M-Audio Subs, Hardwired V1,Xenon interior lights
Tin is offline
Old 11th February 2005, 19:27   #2
M5BHP
M5BHP's Avatar
Garage: Carbon Black BMW E39 M5
Re: Tips for 1/4 mile sprints?
I've found that 1400 rpm is about the best launch point, you get every such a little bit of spin and then your off. Anything over that and the tyres will spin, or worse the clutch will slip.
Cheers
Tin
2000 E39 M5 Carbon Black / Imola Red (SOLD, engine failure!)
2005 Mitsubishi Lancer EVO 8 MR FQ-400 (SOLD, complete nightmare in everyday use!)
2000 TVR Tuscan S 4.0l (SOLD, unreliable)
1999 BMW 323i Coupe (gave to the missus)
2001 Porsche 911 GT2 (993 mwah!)
M5BHP is offline
Old 11th February 2005, 19:48   #3
Jayson
Jayson's Avatar
Garage: m5
Send a message via AIM to Jayson
haha yeah 12 and 12.5 is to optimistic, it's rated at 13.3 from factory with some good driving you can get that...other have done some really good runs down to i think 12.6 but that takes some great 60' times.
If your really good and have done it b4 than you can dip to the 12's stock if not be happy with anything close to 13.3...watch for axle hop and wheel spin. Squeeze out each gear. Remove little things is fine but not that big of deal, 1/4 tank of gas and lower tire pressure to around 15 to 20lbs.
I ran a 13.5 with other people in the car and 3/4 tank of gas so that was fun just injoy it.
You can also do a search this is well covered.
Jayson is offline
Old 11th February 2005, 19:58   #4
Tin
Tin's Avatar
thanks guys, clutch isn't a problem (got a UUC). Just hope everything else is ok
13.3 in stock form.... cool think I'm going to aim for 13's, that should be a good time I'm happy with, any less
Tin is offline
Old 11th February 2005, 20:14   #5
ELEVENS
Garage: '03 M5 LMB/LMB&Al
2000rpm worked best for me (stock clutch). Less and I bogged. More and the tires go up in smoke. If I had a UUC, I'd try higher (~3000) and ride the clutch to get going.
30-32psi in the rears worked best for me.
Everyone/thing is different, you gotta experiement. Expect high 13's for starters, then once you get things dialed in, you'll do better.
Good luck and let us know. Better yet, come back with pics!
ELEVENS is offline
Old 11th February 2005, 20:45   #6
CSBM5
CSBM5's Avatar
Garage: 2001 M5 LeMans Blue
Over at bimmerforums, Silverstreak has many thousands of runs down the 1/4 under his belt, and he sticky'd this thread that you may find of interest:http://forums.bimmerforums.com/forum...ad.php?t=47538
Current stable:
Ground Control camber plates
Stoptech front brake kit
Brake ducts opened
TC Design brackets
1996 Volvo 850R wagon
CSBM5 is offline
Old 11th February 2005, 21:37   #7
ELEVENS
Be careful with the above-mentioned thread, it's not an M5! (4500-4800 rpm launch)
Removing weight is also questionable. I'm not convinced that's the way to go with the traction-challenged M5. On street tires, my Vette was quicker with a passenger aboard.
Do a search on M5board.com for M5-specific advice.
ELEVENS is offline
Old 11th February 2005, 22:01   #8
CSBM5
CSBM5's Avatar
Absolutely...this thread was about a supercharged Z3 3.0! However, many of the facets of the thread are very useful.
Current stable:
Brake ducts opened
TC Design brackets
CSBM5 is offline
Old 12th February 2005, 02:26   #9
HBRAMSTEDT
In stock form 13.0 is easily achievable with a 2001 and up M5. Motor Trend magazine showed 13.0 in tests conducted in 2001 and 2002. With good technique, 12.7 and 12.8 is achievable. Car and Driver tested the M5 at 13.2 in 2002.
The fastest guys on the board leave at 1800-2000 r.p.m.s which allows a sharper step into 2nd. Member ELEVENS has a lot of experience as do a couple of others. The concensus is at least 1800 r.p.m.s, but probably 2000 is better.
HBRAMSTEDT is offline
Old 12th February 2005, 02:28   #10
Tin
Tin's Avatar
thanks guys, 4500rpm starts, i think might give too much wheel spin!
I'm fairly good at traffic light starts, but under the pressure of a 1/4 strip, it gets all serious one slight gear change mishap and its screwed
Whats the top speed in 3rd gear? would I need to shift into 4th before the end of the sprint?
Tin is offline
Anyone know which exhaust tips are these? :) E39 M5 and E52 Z8 Discussion 10 7th June 2004 05:07
Popular Mechanics does the 1/4 mile Pete E39 M5 and E52 Z8 Discussion 3 6th April 2004 02:21
Fatter tips for TubiStyle Exhaust bbloch1114 E39 M5 and E52 Z8 Discussion 15 7th June 2003 13:41
1500 mile report (long) apt333 E39 M5 and E52 Z8 Discussion 5 2nd August 2002 02:38
Used the G-Tec today.... 1st 1/4 mile run got 13.7 @116mph... Apples E39 M5 and E52 Z8 Discussion 21 11th July 2002 23:10
Page generated in 0.15693 seconds with 11 queries
