ALAS, the headers are on the way! I cant wait!!!!
The sound, the power!!!
You will be very pleased!! Make sure you get the ECU remapped, or you will be running way too lean and potentially do damage if you get on it!
I need to get on the horn and get that software on the move!!!!!!
No rush. Cables are usually availble on a couple of days notice. You then have to read the current program from the OBDII diagnostic port and email it to PC. They usually email back the revised program within 24 hours. (If you don't have a laptop, they provide a loaner). In theory you could upload before you do the header install, but you will be running very rich. I suggest you time the cables to arrive the day after the install is supposed to be done. That will minimize the time you need the cables. Driving gently for a few days won't hurt anything. The install will take a few hours and it may be done over a couple of days, so check with your installer about timing.
GSFENT; Who are you talking to at PC? When I called Evosport, they told me I had to remove the ECU from my car and send it to them to be reprogrammed. They told me that the laptop/cable method was several months away. WTF???
PCUT
I like to start at the top, talk to Wayne. I just did the ECU reflash for headers in December. I did the original reflash about 1.5 years ago. Unless there is a problem, I can't imagine why the ECU has to be removed. If you know what you are doing, the reflash takes about 15 minutes, including time to get the laptop to the car, hook up the cables, etc. Try wbesanko@powerchipgroup.com. Tell Wayne hi!! PM me if you have any more questions.
