Old 8th February 2005, 01:21   #1
ContractR
ContractR's Avatar
Garage: Saphire Black M5
nav/radio question
i used to have it set up that the nav screen would show the navigation but when i changed the station from the steering wheel, it would change the screen to the radio for like 10seconds and then revert back to the nav. now, if i have it on the navigation and change station, the screen doesn't go from nav to radio and back to nav, it just stays on the nav screen. does anyone know how i can set that back to how it use to be. thanks
ContractR is offline
Old 8th February 2005, 01:30   #2
Digi
Digi's Avatar
Garage: 2006 M5 Silverstone II
Re: nav/radio question
A simple upgrade of the NAV operating system will probably correct this error. Your dealer will do it free if you complain of this problem if you are still under warranty. Otherwise, you may want to try it yourself.
Digi is offline
Rear EDC question London Mike E34 M5 Discussion 5 11th November 2004 14:37
Silly question: Which color do you use on your NAV? ngc5904 E39 M5 and E52 Z8 Discussion 10 30th June 2004 09:14
Next question: how reliable is the M5? bauhaus E39 M5 and E52 Z8 Discussion 3 3rd June 2004 19:23
speedometer error question HotWheels E39 M5 and E52 Z8 Discussion 7 6th December 2002 23:23
Do you want my Performance Meter AP22? Answer the question to get it! MEnthusiast E39 M5 and E52 Z8 Discussion 33 8th August 2001 05:14
Page generated in 0.11040 seconds with 11 queries
