Old 5th February 2005, 00:12   #1
LA M5
LA M5's Avatar
Garage: 2001 Le Mans Blue M5
Cam Shaft Sensors need replacing - Extended warranty won't cover
Just found out that my cam shaft sensors, banks 1 and 2 (apparently the ones on the exhaust side), need to be replaced. My extended (not BMW) warranty company is declining to cover the replacement based on an exclusion for "emission components". Does this seem right? It seems like the cam shaft sensors are important for several reasons, not just emission components. Do I have a leg to stand on if I try to fight this?
I would greatly appreciate any advice.
LA M5 is offline
Old 5th February 2005, 00:20   #2
M500PMW
M500PMW's Avatar
Garage: E39 M5 2000 MY Avus Blau
Re: Cam Shaft Sensors need replacing - Extended warranty won't cover
Hi LA M5,
rekon your warranty company are trying it on. Just about any engine elctrical component that goes faulty will subsequently cause an emissions related fault. The camshaft position sensors are essential for correct timing/running. If they go faulty the exact positions will not be registered and substitute values are employed, this will result in poor performance and efficiency. Ask them to explain how the sensors are connected to the emissions system??
Regards
Peter.
M500PMW is offline
Old 5th February 2005, 02:22   #3
stever
if the cam sensors are considered emissions components, the BMW 8/80k warranty on emissions components should cover this (as it does oxygen sensors and MAFs)
stever is offline
Old 5th February 2005, 06:35   #4
JEM
JEM's Avatar
Garage: Silverstone MY2000 E39 M5
Check out:
http://www.epa.gov/otaq/consumer/warr95fs.txt
The only components required to be covered to 8yr/80K by the Feds are the cat and the ECU (and OBD system if that's independent of the ECU.)
Still, unless there's a specific clause in the warranty excluding coverage for sensors or engine electronics, I'd think the warranty carrier is urinating into the wind.
JEM is offline
Old 5th February 2005, 06:44   #5
hwj
hwj's Avatar
Garage: 2001 M5, LeMans Blue
Sorry to hear.
Who is your extended warranty provider?
hwj is offline
Old 5th February 2005, 16:33   #6
gsfent
gsfent's Avatar
Garage: 01 M5 Black/caramel
Originally Posted by M500PMW
Hi LA M5,
Regards
Peter.
I agree. And note just because you have a bad CPS does not mean your car is necessarily out of emissions compliance. I bet the CPS is not included in the emissions systems on the dealers parts sections lookups. Most states construe any ambiguity in an insurance policy against the insurance company. If one portion seems to cover it and one portion seems to exclude it (as opposed to a specific exclusion), it should be covered. Ask the company to show you specifically where the part is excluded.
gsfent is offline
Extended warranty question via a company called "Dealer Services" ngc5904 E39 M5 and E52 Z8 Discussion 0 6th October 2004 06:53
Extended warranty question via a company called "Dealer Services" ngc5904 Off Topic Forum 0 6th October 2004 06:43
Another Extended Warranty Question TCM E39 M5 and E52 Z8 Discussion 20 1st May 2004 05:49
Adding MODS to your car and warranty being possibly affected................ FAST 5 E39 M5 and E52 Z8 Discussion 1 6th November 2003 22:44
"Aftermarket vs. Factory Warranty" NJ M5 E39 M5 and E52 Z8 Discussion 2 12th April 2003 21:47
Page generated in 0.17676 seconds with 11 queries
