DIY: INPA for Windows 10- - Page 3 - BMW M5 Forum and M6 Forums
 18Likes
post #21 of 97 Old 8th March 2016, 01:41 AM
mgdmb
mgdmb's Avatar
mgdmb is offline
The Following 2 Users Say Thank You to mgdmb For This Useful Post:
masri87 (8th March 2016)
post #22 of 97 Old 8th March 2016, 03:08 AM Thread Starter
masri87
Originally Posted by ProdigyPlayer View Post
I have the pacman style connector under the hood of my e39 m5. From what I've read so far, it seems I can only connect INPA through the 20 pin connector.
Will this set up work with these installation files?
20 pin -> 16 pin adapter -> K-Line -> USB
I have the same connector.
I imagine it would be Pacman adapter to obdii to usb (laptop).
You may need to find other drivers to make it work, as i have not tested that portion yet, and as far as i know, the Pacman connector would be only needed if you are doing DIS. (someone more experienced can chime in)
masri87 is offline
post #23 of 97 Old 8th March 2016, 03:13 AM
mgdmb
mgdmb's Avatar
The drivers are all the same, the 20 --> 16 pin is just an adapter. You need to use the engine bay port for INPA/DIS/PASoft, etc (any module coding or advanced tests). About the only thing you can do with the under dash port is tune the car, and read readiness monitors with a bluetooth or wireless adapter and iOS / Android devices.
mgdmb is offline
ProdigyPlayer (8th March 2016)
post #24 of 97 Old 8th March 2016, 04:03 AM
ProdigyPlayer
ProdigyPlayer's Avatar
Thanks for the info. I've been searching around for the correct setup and ran into this (E46Fanatics - View Single Post - Please help, PA Soft 1.4.0 Scanner)
Has anyone tried to jump Pins 2->17, and 2->20 to get around the 20 pin adapter?
ProdigyPlayer is offline
post #25 of 97 Old 8th March 2016, 04:24 AM
mgdmb
mgdmb's Avatar
mgdmb is offline
post #26 of 97 Old 9th March 2016, 06:30 PM
enzoR
Thanks for this! I had it installed the old way in the past but since getting a new laptop with windows 10 I havent gotten it working until now!
In your search for this package, did you stumble across an easier DIS installer as well?
enzoR is offline
post #27 of 97 Old 9th March 2016, 07:57 PM Thread Starter
masri87
No problem!
I have not searched for DIS whatsoever, as i have actually been playing around with ISTA\D-P instead.
Ill do some more research and post anything i find regarding DIS for windows 10
@enzoR
Try this https://mega.nz/#F!eM5nRD6Q!qELe6ic8bcRydhhlHP_I3A
Just download the dis 7zip file and the installation manual. if you're on windows 10 you'll need VMWorkstation 10 to get it to work.
If anyone else has any other ideas or experiences getting DIS to work with 10, i'd appreciate your chiming in.
enzoR if you're successful plz report back
masri87 is offline
post #28 of 97 Old 9th March 2016, 10:53 PM
enzoR
thanks! i'll give it a go. With DIS you can run more tests than with INPA. For example vanos tests.
enzoR is offline
post #29 of 97 Old 9th March 2016, 10:59 PM Thread Starter
masri87
Yeah I've ran those before on DIS, but i thought Rheingold (ISTAP\ISTAD) has the same options?
masri87 is offline
post #30 of 97 Old 9th March 2016, 11:04 PM
enzoR
oh I see, INSTAD replaces DIS. I'd like to try that instead then. Can you please upload that?
enzoR is offline
Currently Active Users Viewing This Thread: 8 (0 members and 8 guests)
Need INPA or what and where do get...??? Sfbimmerman E60 M5 and E61 M5 Touring Discussion 16 2nd June 2016 09:28 PM
INPA rosakirk12 E39 M5 and E52 Z8 Discussion 3 6th January 2016 05:58 AM
Inpa cable robertstrendell E60 M5 and E61 M5 Touring Discussion 4 22nd September 2015 06:23 PM
Looking for a Windows/INPA guinea pig chuffykow E39 M5 and E52 Z8 Discussion 10 26th September 2014 07:58 PM
Need help installing Inpa Uriel626 E39 M5 and E52 Z8 Discussion 16 1st April 2013 04:50 AM
