Old 26th January 2005, 19:21   #1
lsdvm
lsdvm's Avatar
Garage: 2001 M5, silver/imola red extended leather
Update on clutch/tranny problem...
Hey guys and gals, so yesterday, just to satisfy my curiosity, I checked the car again, and this time, when I put it into gear it moved...back, and forth...however, there was this God awful groaning sound coming from the back end...as if the e-brake was holding?? But this time it stalled when I took my foot off the clutch...
A couple folks (Dick Roberts and Greg) had mentioned that this didn't sound like a clutch problem, but rather something hydraulic, or wiht the tranny...which I suspect it may be. I'm having it towed to the dealer tomorrow, so I'll hopefully know more then.
If it is a lubrication problem as with some of the M3's, or a throwout bearing that leads to a clutch problem, is this something I should press BMW about fixing at no cost to me??
Your thoughts...??
lsdvm is offline
Old 26th January 2005, 19:46   #2
Greco
Greco's Avatar
Garage: 1998 E39 540 Biarritz Blue/Beige SPP
Re: Update on clutch/tranny problem...
If its coming from the back i'd say its the diff....
If it was the throwout bearing gone bad, you would hear a squeeking sound every time you press/depress the clutch pedal.
- Bill
>> Just an E39 540i/6 Biarritz Blue <<
Greco is offline
Old 27th January 2005, 01:11   #3
lsdvm
lsdvm's Avatar
Re: Interesting...
Hey Bill, thanks for the input. I had one of the diff seals changed a few months back at the dealership because it was leaking...I'm hoping that's a relatively minor repair.
Why would it affect the cluthc mechanism though??
When the problem first happened I was able to taek my foot off the clutch with the car in gear and it wouldn't stall or lurch forward or anything????
lsdvm is offline
Old 27th January 2005, 06:05   #4
Greco
Greco's Avatar
Re: Interesting...
My best guess is that when it first happened the driveshaft was spinning freely thus no movement on the car's part. Since then something probably moved and is coming into contact with the gear attached to the driveshaft not allowing it to turn. I wouldn't do anymore tests on your car other than taking it to the dealer. Don't risk a transmission if its only the diff. I'm not a diff expert but all the symptoms point to a faulty diff.
Greco is offline
Vanos problem ilundber E39 M5 and E52 Z8 Discussion 15 3rd November 2005 01:30
"AUX" mode (lack-of) volume problem for I-PODs & DVD movies........ FAST 5 E39 M5 and E52 Z8 Discussion 8 16th September 2004 09:06
Gas problem Ruffinit E39 M5 and E52 Z8 Discussion 10 25th August 2004 15:47
Terminal problem with my B10? B10Ken ALPINABoard.com | BMW Alpina Discussion 16 15th August 2004 22:03
Radio Problem Solved? paulbondy E39 M5 and E52 Z8 Discussion 9 7th August 2004 20:27
Page generated in 0.20052 seconds with 11 queries
