Old 13th January 2005, 05:39   #1
a_ok2me
a_ok2me's Avatar
Garage: M5
Empty Switch Next To Fog Light Switch - E39
There is an empty switch slot next to the fog light switch. Does anyone know what this slot is for? I want to move my tire pressure switch to that location. However, the tire pressure switch is smaller than the empty slot. The tire pressure switch looks out of place in the factory location. I was hoping to buy a switch for the empty slot and rewire the tire pressure switch to it. Wondering if this is possible.
a_ok2me is offline
Old 13th January 2005, 09:25   #2
pkarmouche
pkarmouche's Avatar
Garage: M5/Anthracite/Black Lux
Re: Empty Switch Next To Fog Light Switch - E39
I'm going to use the empty spot for a switch for other gadgets.
You can see the wire harness from this hole so it should be easy to re-route that wire up to that spot.
Might I suggest you use a blade, drill or dremel to carefully route a hold out of that "blank hole cover" to mount the tire switch into?
You can buy replacement "blank hole covers" from your friendly BMW parts department for only a few dollars. Wise for if you slip while cutting. Also good if you want to go back to the way it was before.
My question to you is... what do you plan to do with the hole you create in the lower panel after removing the button?
Paul
pkarmouche is offline
Old 13th January 2005, 09:48   #3
Ashok Arora
Ashok Arora's Avatar
The blank plate is there because all instrument binnacles on E39 5 series cars are the same. On the lesser (non-M) models, there is a rotary switch in that position which controls the dip angle for the headlights. Since the M5 has auto-levelling lights, this is redundant and not used on our cars.
I would not recommend relocating the tpc switch. You can, use that space for a number of aftermarket switches. I have my Lidatek jammer switch installed there - here is a photo:
http://images.fotopic.net/?id=1553558&outx=600&oq=0
Ashok
Let me tell you what SMG stands for...
Ashok Arora is offline
Old 13th January 2005, 10:09   #4
pkarmouche
pkarmouche's Avatar
... That's similar to what I'm planning to use that space for, however I have found a semi-flush all-black plastic switch to use that will blend with the other panel switches... I'll try to post some pics when my project is done.
Oh, and by the way, you can use the tire pressure push-button as a momentary-contact button for any other device that requries a momentary contact (especially since we rarely have to use that button anyway). I plan to use a wire connector from a computer motherboard, one that usually connects the red & black speaker wire to the mobo (two pins) - it will plug right into the back of the tire pressure switch - the third pin on the switch is simply for 12v to light up the little tire icon at night. I left that pin open, no need to light up the tire icon, especially while the switch doesn't perform its usual function!
(leave the wire harness in the hole for periodic hook-up and usage as necessary when changing tire pressures).
Paul
Old 13th January 2005, 15:55   #5
Anzir
Anzir's Avatar
Garage: Silverstone 2000 M5
Lidatek for me too.. but I put the switch far under the dash.
Anzir is offline
Old 13th January 2005, 19:13   #6
a_ok2me
a_ok2me's Avatar
Garage: M5
You are a genius I have a spare center panel wood trim without a tire pressure hole.
a_ok2me is offline
Old 13th January 2005, 20:46   #7
pkarmouche
pkarmouche's Avatar
If it helps anyone - I have also spyed out a location to install gadget switches... In the blank panel to the left of the useless cupholders.
If you remove the front cupholders you will see that there is an opening leading under the dashboard at the upper part of that blank panel. This is a good location because if you make a mistake, or want to "uninstall" your switch(es) then you can simply replace the front cupholders and you're back to stock...
Paul
Old 14th January 2005, 04:36   #8
Amir M5
Amir M5's Avatar
Garage: 2000 Metallic Anthracite M5
I have the V1 remote volume/power control knob from Beastpower (AI Designs custom I believe) in that spot and I love it. Very subtle and exact color as the rest of the dash.
Amir M5 is offline
Old 14th January 2005, 06:00   #9
Mvious
Mvious's Avatar
Garage: 2001 Lemans Blue M5
Sales Feedback: (3)
Do you have any pic 's of it,
Marion
Marion
ACS Roof Spoiler
Tubi Style Cat Back Exhuast
Custom Painted HRE 549 19x9 front 19x10.5 Rear
UUC Evo III SSK & DSR
UUC Transmission Mounts
UUC Direct Fit Clutch
Supersprint Headers and Connecting pipes
Active Autoworks CAI
Discovery Automotive Powerchip 93 software
Lidetak LE-30
Valentine One
Dension Ice>Link:Plus
Beastpower Brackets
Evosport Power Pullies
Stealth-One
Mvious is offline
Old 14th January 2005, 10:16   #10
Amir M5
Amir M5's Avatar
Marion
Here you go. It goes great with the hardwired V1 in the upper right of the windshield and the V1 mirror from Beastpower as well.
Amir M5 is offline
M5 E39 Body Style S62 engine FACTS...Long V-10 4 Me E39 M5 and E52 Z8 Discussion 53 22nd March 2009 16:12
e39 m5 is the undisputed champ cebu E39 M5 and E52 Z8 Discussion 7 1st February 2008 07:28
M5 E39 '00' Xenon front light units pvapour For Sale or Wanted 5 16th March 2004 09:35
Dinan Exhaust AlbertM E39 M5 and E52 Z8 Discussion 5 6th October 2000 19:11
Page generated in 0.18448 seconds with 12 queries
